Results 1 to 3 of 3
Thread: AudioInputUSB - AudioAnalyzePeak
    Apr 2018
    3
    Hello Everyone
    Here my very simple Test-Code (Board: Teensy 3.2):
    PHP Code:
    #include <Audio.h>
    #include <Wire.h>
    #include <SPI.h>
    #include <SD.h>
    #include <SerialFlash.h>
    // GUItool: begin automatically generated code
    AudioInputUSB            usb1;           //xy=101,107
    AudioAnalyzePeak         peak1;          //xy=308,101
    AudioConnection          patchCord1(usb10peak10);
    // GUItool: end automatically generated code
    void setup() {
    AudioMemory(10);
    void loop() {
      if (
    peak1.available()) {
    Serial.println(peak1.read());
    "Peak1.available()" never retuns true, no matter if there is some signal (music) from USB or not.
    If I only use "Serial.println(peak1.read())", I got some values when music is on. If there is no music or signal, it returns 1 (instead of 0).
    Anyone knows the reason?
    Thanks for help
    Stephan
    17,886
    You need at least one hardware input or output, even if unused without any signal connected.
    See the docs here: (right side panel)
    https://www.pjrc.com/teensy/gui/?info=AudioInputUSB
    USB input & output does not cause the Teensy Audio Library to update. At least one non-USB input or output object must be present for the entire library to update properly.
    Apr 2018
    3
    Thanks Paul
    Now it works.
