i would send packets of RGB message via UDP from max to my teensy 3.5.
I tried many ways like sadam.udpsender external and all the data arrive but when i send more messages at 30 ms frame rate the system crash. For example if i send a message of 60 Bytes at 30 ms. rate arrive wrong data (different numbers) or Teensy stop working.
I use Mini W5100 LAN Ethernet Shield.
I send 660 Bytes every 25 ms. via serial port and all go fine. I think wouldn't be a problem send the same data via ethernet....
I attached my sketch and other stuff of my setup
THX
THX
