My goal is to send text messages and data back and forth between two Teensies. I'm looking for a library that parses incoming messages and does callbacks when messages are received.
CmdMessenger does this but is normally used for communicating between an Arduino and a host computer over USB. I'm hoping it also works over a UART serial link.
The first question is does CmdMessenger Run on Teensy? This listing of Teensy supported libs says CmdMessenger doesn't run on any version of the Teensy:
https://www.pjrc.com/teensy/td_libs.html
But on the CmdMessenger Github page it says it does run on Teensy:
https://github.com/thijse/Arduino-CmdMessenger
Assuming the listing is not up to and and CmdMessenger runs on Teensy does anyone know if it can be used to communicate between two Teensys over a TTL serial link (UART)?
