Results 1 to 4 of 4
Thread: lps22hb pressure sensor
    Aug 2016
    150
    these days i tested the pressure sensor lps22hb,the pressure measured is 43 hpa lower than it should,that is it show 970 hpa while it should show 1013 hpa.
    I read in st community that and others have this problem(thread) but some solution was not given.
    Has anyone tried it this sensor?
    Sep 2013
    Alps, Switzerland, (middleof)
    18
    Quote Originally Posted by thanos View Post
    What height above sea level do you take the measuring? Could it be that you are approx (8x43=424m) above sea level and take QNH as reference?
    Aug 2016
    150
    I'm at the 37 meter altitude,i measured with the bmp180 and gives me the correct pressure.
    Sep 2013
    18
    Ok, was just a guess. According to datasheet it should be more accurate than BMP. Maybe some error in the used Library?
