I am playing with the DAC on Teensy 3.6 and I notice that there is a spike in the reading after the Teensy is reprogrammed for about 1-2 seconds. I am using DAC0 to control a big DC blower and this results in a very high current draw on startup after I reprogram the micro-controller. Below is a simplified version of the code the exhibits the problem. Once the program is running inside the main loop it is all fine.
Please let me know if you have any idea of how this might be fixed.
//set DAC resolution
analogWriteResolution(12);
// Set DAC0 to zero
analogWrite(A21, 0);
//generate step function
for (int i = 0; i < 100; i++) {
analogWrite(A21, 20 * i);
// Set DAC0 to zero
delay(10000);
