Results 1 to 10 of 10
Thread: OneWire library does not work on analog pin, but OnWireHub library does
    Aug 2018
    8
    Please check, examples with DS18B20 temperature sensor, and OneWireSearch do not work on pins that have ADC function.
    I do not have other One Wire devices, only 4 DS18B20, which on digital pins work properly with the OneWire library.
    But another library (OneWireHub) works with these ADC pins.
    What do I need to configure for this OneWire library to work with pins that have ADC function, such as Arduino UNO over A0 and A1 (D14 and D15)?
    Reference for OneWireHub:
    https://github.com/orgua/OneWireHub
    Thank you.
    Aug 2018
    8
    OneWire does not work:
    //    FILE: oneWireSearch.ino
    //  AUTHOR: Rob Tillaart
    // VERSION: 0.1.02
    // PURPOSE: scan for 1-Wire devices + code snippet generator
    //    DATE: 2015-june-30
    //     URL: http://forum.arduino.cc/index.php?topic=333923
    // inspired by http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
    // Released to the public domain
    // 0.1.00 initial version
    // 0.1.01 first published version
    // 0.1.02 small output changes
    #include <OneWire.h>
      Serial.println("//\n// Start oneWireSearch.ino \n//");
      for (uint8_t pin = 2; pin < 15; pin++) // <----------- from 13 to 15
        findDevices(pin);
      Serial.println("\n//\n// End oneWireSearch.ino \n//");
    uint8_t findDevices(int pin)
      OneWire ow(pin);
      uint8_t address[8];
      uint8_t count = 0;
      if (ow.search(address))
        Serial.print("\nuint8_t pin");
        Serial.print(pin, DEC);
        Serial.println("[][8] = {");
        do {
          count++;
          Serial.println("  {");
          for (uint8_t i = 0; i < 8; i++)
            Serial.print("0x");
            if (address[i] < 0x10) Serial.print("0");
            Serial.print(address[i], HEX);
            if (i < 7) Serial.print(", ");
          Serial.println("  },");
        } while (ow.search(address));
        Serial.println("};");
        Serial.print("// nr devices found: ");
        Serial.println(count);
      return count;
    Aug 2018
    8
    // OneWire DS18S20, DS18B20, DS1822 Temperature Example
    // http://www.pjrc.com/teensy/td_libs_OneWire.html
    // The DallasTemperature library can do all this work for you!
    // https://github.com/milesburton/Arduino-Temperature-Control-Library
    OneWire  ds(A1);  // on pin (a 4.7K resistor is necessary)  // <------------ from 10 to A1
    void setup(void) {
    void loop(void) {
      byte i;
      byte present = 0;
      byte type_s;
      byte data[12];
      byte addr[8];
      float celsius, fahrenheit;
      if ( !ds.search(addr)) {
        Serial.println("No more addresses.");
        ds.reset_search();
        delay(250);
        return;
      Serial.print("ROM =");
      for( i = 0; i < 8; i++) {
        Serial.write(' ');
        Serial.print(addr[i], HEX);
      if (OneWire::crc8(addr, 7) != addr[7]) {
          Serial.println("CRC is not valid!");
          return;
      // the first ROM byte indicates which chip
      switch (addr[0]) {
        case 0x10:
          Serial.println("  Chip = DS18S20");  // or old DS1820
          type_s = 1;
        case 0x28:
          Serial.println("  Chip = DS18B20");
          type_s = 0;
        case 0x22:
          Serial.println("  Chip = DS1822");
          type_s = 0;
        default:
          Serial.println("Device is not a DS18x20 family device.");
          return;
      ds.reset();
      ds.select(addr);
      ds.write(0x44, 1);        // start conversion, with parasite power on at the end
      delay(1000);     // maybe 750ms is enough, maybe not
      // we might do a ds.depower() here, but the reset will take care of it.
      present = ds.reset();
      ds.select(addr);
      ds.write(0xBE);         // Read Scratchpad
      Serial.print("  Data = ");
      Serial.print(present, HEX);
      Serial.print(" ");
      for ( i = 0; i < 9; i++) {           // we need 9 bytes
        data[i] = ds.read();
        Serial.print(data[i], HEX);
        Serial.print(" ");
      Serial.print(" CRC=");
      Serial.print(OneWire::crc8(data, 8), HEX);
      // Convert the data to actual temperature
      // because the result is a 16 bit signed integer, it should
      // be stored to an "int16_t" type, which is always 16 bits
      // even when compiled on a 32 bit processor.
      int16_t raw = (data[1] << 8) | data[0];
      if (type_s) {
        raw = raw << 3; // 9 bit resolution default
        if (data[7] == 0x10) {
          // "count remain" gives full 12 bit resolution
          raw = (raw & 0xFFF0) + 12 - data[6];
        byte cfg = (data[4] & 0x60);
        // at lower res, the low bits are undefined, so let's zero them
        if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
        else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
        else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
        //// default is 12 bit resolution, 750 ms conversion time
      celsius = (float)raw / 16.0;
      fahrenheit = celsius * 1.8 + 32.0;
      Serial.print("  Temperature = ");
      Serial.print(celsius);
      Serial.print(" Celsius, ");
      Serial.print(fahrenheit);
      Serial.println(" Fahrenheit");
    Aug 2018
    8
    OneWire  ds(15);  // on pin (a 4.7K resistor is necessary) // <---------- from 10 to 15
    void setup(void) {
    void loop(void) {
      byte i;
      byte present = 0;
      byte type_s;
      byte data[12];
      byte addr[8];
        ds.reset_search();
        delay(250);
        return;
        Serial.write(' ');
          return;
      switch (addr[0]) {
        case 0x10:
          type_s = 1;
        case 0x28:
          type_s = 0;
        case 0x22:
          type_s = 0;
        default:
          return;
      ds.reset();
      ds.select(addr);
      ds.select(addr);
      Serial.print(" ");
        Serial.print(" ");
      if (type_s) {
    Aug 2018
    8
    OneWireHub works:
     *    Example-Code that emulates a DS18B20
     *    Tested with:
     *    - https://github.com/PaulStoffregen/OneWire --> DS18x20-Example, atmega328@16MHz as Slave
     *    - DS9490R-Master, atmega328@16MHz and teensy3.2@96MHz as Slave
    #include "OneWireHub.h"
    #include "DS18B20.h"  // Digital Thermometer, 12bit
    constexpr uint8_t pin_led       { 13 };
    constexpr uint8_t pin_onewire   { 15 }; // <------------------------ ADC pin
    auto hub    = OneWireHub(pin_onewire);
    auto ds18b20 = DS18B20(DS18B20::family_code, 0x00, 0x00, 0xB2, 0x18, 0xDA, 0x00); // DS18B20: 9-12bit, -55 -  +85 degC
    auto ds18s20 = DS18B20(0x10, 0x00, 0x00, 0xA2, 0x18, 0xDA, 0x00);                 // DS18S20: 9   bit, -55 -  +85 degC
    auto ds1822  = DS18B20(0x22, 0x00, 0x00, 0x22, 0x18, 0xDA, 0x00);                 // DS1822:  9-12bit, -55 - +125 degC
    bool blinking(void);
        Serial.println("OneWire-Hub DS18B20 Temperature-Sensor");
        Serial.flush();
        pinMode(pin_led, OUTPUT);
        // Setup OneWire
        hub.attach(ds18b20);
        hub.attach(ds18s20);
        hub.attach(ds1822);
        // Test-Cases: the following code is just to show basic functions, can be removed any time
        Serial.print("Test - set Temperatures to -56 degC (out of range): ");
        ds18b20.setTemperature(int8_t(-56));
        Serial.println(ds18b20.getTemperature());
        Serial.print("Test - set Temperatures to -55 degC: ");
        ds18b20.setTemperature(int8_t(-55));
        ds18s20.setTemperature(int8_t(-55));
        Serial.print(ds18b20.getTemperature());
        Serial.print(", ");
        Serial.println(ds18s20.getTemperature());   // ds18s20 is limited to signed 9bit, so it could behave different
        Serial.print("Test - set Temperatures to 0 degC: ");
        ds18b20.setTemperature(int8_t(0));
        ds18s20.setTemperature(int8_t(0));
        Serial.print(", ");
        Serial.print("Test - set Temperatures to 21 degC: ");
        const int8_t temperature = 21;
        ds18b20.setTemperature(temperature);
        ds18s20.setTemperature(temperature);
        ds1822.setTemperature(temperature);
        Serial.print(", ");
        Serial.print("Test - set Temperatures to 85 degC: ");
        ds18b20.setTemperature(int8_t(85));
        ds18s20.setTemperature(int8_t(85));
        Serial.print(", ");
        Serial.print("Test - set Temperatures to 126 degC (out of range): ");
        ds1822.setTemperature(int8_t(126));
        Serial.println(ds1822.getTemperature());
        Serial.println("config done");
        // following function must be called periodically
        hub.poll();
        // this part is just for debugging (USE_SERIAL_DEBUG in OneWire.h must be enabled for output)
        if (hub.hasError()) hub.printError();
        // Blink triggers the state-change
        if (blinking())
            // Set temp
            static float temperature = 20.0;
            temperature += 0.1;
            if (temperature > 30.0) temperature = 20.0;
            Serial.println(temperature);
    bool blinking(void)
        constexpr  uint32_t interval    = 1000;          // interval at which to blink (milliseconds)
        static uint32_t nextMillis  = millis();     // will store next time LED will updated
        if (millis() > nextMillis)
            nextMillis += interval;             // save the next time you blinked the LED
            static uint8_t ledState = LOW;      // ledState used to set the LED
            if (ledState == LOW)    ledState = HIGH;
            else                    ledState = LOW;
            digitalWrite(pin_led, ledState);
            return 1;
        return 0;
    Aug 2018
    8
    OneWireHub works:
     *    Tested with:
    constexpr uint8_t pin_onewire   { A1 }; // <-------------------- ADC pin
        Serial.flush();
        // Setup OneWire
        hub.attach(ds1822);
        Serial.print(", ");
        Serial.print(", ");
        Serial.print(", ");
        Serial.print(", ");
        hub.poll();
        if (blinking())
            // Set temp
            temperature += 0.1;
    bool blinking(void)
            return 1;
        return 0;
    20,551
    Quote Originally Posted by rtek1000 View Post
    Please post a photo showing how you've actually connected the hardware.
    Aug 2018
    8
    Attachment 14419
    I am using a 1R resistor in Vcc (5V) with the objective to operate as a fusistor and 4k7 in the bus (pull-up to 5V).
    Links wires have been redirected to the digital pins, so I can continue my testing.
    I am now using pins D7 and D8 instead of A0 and A1.
    I know I can operate on only 1 wire, but each DS18B20 sensor is on a pin because I need to read different temperatures, and in the future I do not want to have to reconfigure each sensor that is defective, so I can only change the sensor.
    I just want to warn you that something went wrong here when trying to use this library, with the Arduino Pro Mini (with UNO bootloader).
    I am reprogramming the ATmega328 via wireless connection to the IDE, with the help of ESP8266 (with esp-link firmware).
    Thank you.Click image for larger version.
    20,551
    I tested just now, using Arduino Uno R3 and the code from msg #3 (using "A1" pin). It seems to work properly here.
    Perhaps your hardware has a defect?
    Aug 2018
    8
    Oh no!
    Is my sensor failing?
    I'm going to buy new sensors to test.
    For now, thank you very much!
