* Example-Code that emulates a DS18B20
* Tested with:
* - https://github.com/PaulStoffregen/OneWire --> DS18x20-Example, atmega328@16MHz as Slave
* - DS9490R-Master, atmega328@16MHz and teensy3.2@96MHz as Slave
#include "OneWireHub.h"
#include "DS18B20.h" // Digital Thermometer, 12bit
constexpr uint8_t pin_led { 13 };
constexpr uint8_t pin_onewire { 15 }; // <------------------------ ADC pin
auto hub = OneWireHub(pin_onewire);
auto ds18b20 = DS18B20(DS18B20::family_code, 0x00, 0x00, 0xB2, 0x18, 0xDA, 0x00); // DS18B20: 9-12bit, -55 - +85 degC
auto ds18s20 = DS18B20(0x10, 0x00, 0x00, 0xA2, 0x18, 0xDA, 0x00); // DS18S20: 9 bit, -55 - +85 degC
auto ds1822 = DS18B20(0x22, 0x00, 0x00, 0x22, 0x18, 0xDA, 0x00); // DS1822: 9-12bit, -55 - +125 degC
bool blinking(void);
Serial.println("OneWire-Hub DS18B20 Temperature-Sensor");
Serial.flush();
pinMode(pin_led, OUTPUT);
// Setup OneWire
hub.attach(ds18b20);
hub.attach(ds18s20);
hub.attach(ds1822);
// Test-Cases: the following code is just to show basic functions, can be removed any time
Serial.print("Test - set Temperatures to -56 degC (out of range): ");
ds18b20.setTemperature(int8_t(-56));
Serial.println(ds18b20.getTemperature());
Serial.print("Test - set Temperatures to -55 degC: ");
ds18b20.setTemperature(int8_t(-55));
ds18s20.setTemperature(int8_t(-55));
Serial.print(ds18b20.getTemperature());
Serial.print(", ");
Serial.println(ds18s20.getTemperature()); // ds18s20 is limited to signed 9bit, so it could behave different
Serial.print("Test - set Temperatures to 0 degC: ");
ds18b20.setTemperature(int8_t(0));
ds18s20.setTemperature(int8_t(0));
Serial.print(", ");
Serial.print("Test - set Temperatures to 21 degC: ");
const int8_t temperature = 21;
ds18b20.setTemperature(temperature);
ds18s20.setTemperature(temperature);
ds1822.setTemperature(temperature);
Serial.print(", ");
Serial.print("Test - set Temperatures to 85 degC: ");
ds18b20.setTemperature(int8_t(85));
ds18s20.setTemperature(int8_t(85));
Serial.print(", ");
Serial.print("Test - set Temperatures to 126 degC (out of range): ");
ds1822.setTemperature(int8_t(126));
Serial.println(ds1822.getTemperature());
Serial.println("config done");
// following function must be called periodically
hub.poll();
// this part is just for debugging (USE_SERIAL_DEBUG in OneWire.h must be enabled for output)
if (hub.hasError()) hub.printError();
// Blink triggers the state-change
if (blinking())
// Set temp
static float temperature = 20.0;
temperature += 0.1;
if (temperature > 30.0) temperature = 20.0;
Serial.println(temperature);
bool blinking(void)
constexpr uint32_t interval = 1000; // interval at which to blink (milliseconds)
static uint32_t nextMillis = millis(); // will store next time LED will updated
if (millis() > nextMillis)
nextMillis += interval; // save the next time you blinked the LED
static uint8_t ledState = LOW; // ledState used to set the LED
if (ledState == LOW) ledState = HIGH;
else ledState = LOW;
digitalWrite(pin_led, ledState);
return 1;
return 0;
