Hi all,
I am really new to this board and I am still learning and finding and figuring out the ways this board works, I am somewhat new to arduino as well but I have made a few projects as well but this one has got me I am currently trying to get a seeed CAN-BUS v2.0 shield to work with this board but I cant get the board to pass the "enter setup mode" it fails everytime. I am wondering to start with can someone point me in the right direction on what pins actually need to be connected, I can get this to work on an uno just not this board. I did reroute the sck pin to 14 due to the LED already using this pin. Any advise and or picture/hand holding would be great.
From what I have seen in the pin_arduino.h the pins should be the same as the UNO which make me think I am missing something. Here is a picture below to show what pins I have were.
here is my code below
This is the error I get this also has a screen attached, sorry for the excess.
// You can use any (4 or) 5 pins for OLED screen
#define sclk 2
#define mosi 3
#define dc 4
#define cs 5
#define rst 6
// Color definitions
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1351.h>
#include <arduino.h>
#include <gfxfont.h>
#include <mcp_can.h>
#include <mcp_can_dfs.h>
// Option 1: use any pins but a little slower
Adafruit_SSD1351 tft = Adafruit_SSD1351(cs, dc, mosi, sclk, rst);
#define COMMAND 0xFE
#define CLEAR 0x01
#define LINE0 0x80
#define LINE1 0xC0
#define COMMAND2 0x7C
//#define DOUBLE_CLICK_DELAY 100
#define NR_OF_CHANNELS (sizeof(channel)/sizeof(data_channel))
/* Define Joystick connection pins */
#define UP A1
#define DOWN A3
#define LEFT A2
#define RIGHT A5
#define CLICK A4
//the cs pin of the version after v1.1 is default to D9
//v0.9b and v1.0 is default D10
const int SPI_CS_PIN = 9;
const int LED = 8;
boolean ledON = 1;
MCP_CAN CAN (SPI_CS_PIN); //set CS Pin
enum {
MIN,
MAX,
RUNTIME
struct data_channel {
char *name;
int multiplier;
int divisor;
int offset;
int min_value;
int max_value;
int value;
int a,b,c,d,current;
int page_type = RUNTIME;
unsigned int last_click = 0;
int flip_request;
data_channel channel[] = {
// name, multiplier, divider, offset
{ "ECT", 1, 1, -50, 9999 },
{ "AFR", 1,1, 0 , 9999 },
{ "TPS", 1, 1, 0 , 9999 },
{ "MGP", 1, 1, -100, 9999 },
{ "IaT", 1, 1, -50, 9999 },
{ "Ign", 1, 1, 0, 9999 },
{ "Fup", 1, 1, 0, 9999 },
{ "Idc", 1, 1, 0, 9999 },
void flip_page () {
flip_request = 1;
//delay(250);
tft.fillScreen(BLACK);
SPI.setSCK(14);
SPI.setMOSI(11);
SPI.setMISO(12);
Serial.println("ECU Reader"); /* For debug use */
delay(10);
tft.begin();
Serial.println("initializing can");
if (CAN_OK != CAN.begin(CAN_500KBPS)) //Init can bus : Baudrate = CAN_500KBPS, Swapped for mcp_can begin
tft.setTextSize(1);
tft.setTextColor(GREEN);
tft.print("Can Init Screwed"); //Swapped for TFT
delay(2000);
tft.setTextSize(2);
tft.print("Can init ok");
tft.fillScreen(BLACK); //swapped for TFT
current = 0;
//Initialize analog pins as inputs
pinMode(UP,INPUT);
pinMode(DOWN,INPUT);
pinMode(LEFT,INPUT);
pinMode(RIGHT,INPUT);
pinMode(CLICK,INPUT);
//Pull analog pins high to enable reading of joystick movements
digitalWrite(UP, HIGH);
digitalWrite(DOWN, HIGH);
digitalWrite(LEFT, HIGH);
digitalWrite(RIGHT, HIGH);
digitalWrite(CLICK, HIGH);
tft.setCursor(25, 8);
tft.setTextSize(1);
tft.print(channel[current].name);
tft.setCursor(90, 8);
tft.setTextSize(1);
tft.setTextColor(WHITE);
tft.print(channel[current+1].name);
//tft.print(channel[current+2].name);
//tft.print(channel[current+3].name);
//tft.fillScreen(BLACK);
//tft.setCursor(0, 5);
//tft.setTextColor(RED);
//tft.setTextSize(1);
void read_channel()
unsigned char len = 0;
unsigned char buf[8];
//for(int i = 0; i<len; i++)
if(CAN_MSGAVAIL == CAN.checkReceive()) //check if data is on the bus
CAN.readMsgBuf(&len, buf); // read data, len: data length, buf: data buf
// organize data for more resolution and accuracy
a = (buf[1] + buf[0]);
b = (buf[3] + buf[2]);
c = (buf[5] + buf[4]);
d = (buf[7] + buf[6]);
if(a*3 < NR_OF_CHANNELS ) process_value(a*3,b);
if(a*3+1 < NR_OF_CHANNELS ) process_value(a*3+1,c);
if(a*3+2 < NR_OF_CHANNELS ) process_value(a*3+2,d);
void process_value( int ch, int val )
int value = val * channel[ch].multiplier / channel[ch].divisor + channel[ch].offset;
channel[ch].value = value;
if (value > channel[ch].max_value ) channel[ch].max_value = value;
if (value < channel[ch].min_value ) channel[ch].min_value = value;
void display_page() {
//static int old_page;
//if(old_page!=current); //Tft.fillScreen();
//old_page=current;
int disp_values[4];
for ( int i = 0; i < 4; i++ )
switch (page_type) {
case MIN:
disp_values[i] = channel[current+i].min_value;
case MAX:
disp_values[i] = channel[current+i].max_value;
default:
disp_values[i] = channel[current+i].value;
tft.setCursor(0, 17);
tft.setTextSize(3);
tft.print(disp_values[0]);
//tft.drawNumber(disp_values[1],130,90,3,RED);
//tft.drawNumber(disp_values[2],130,180,3,YELLOW);
//tft.drawNumber(disp_values[3],130,270,3,BLUE);
for(int i=0;i<NR_OF_CHANNELS;i++ ) read_channel();
if (millis()-500 > last_click && flip_request )
current+=4;
if (current > NR_OF_CHANNELS - 4) current=0;
last_click = millis();
flip_request = 0;
flip_request = 0;
display_page();
//delay(30);
//Tft.fillRectangle(130, 8, 80,25,BLACK);
//Tft.fillRectangle(130, 88, 80,25,BLACK);
//Tft.fillRectangle(130, 178, 80,25,BLACK);
//Tft.fillRectangle(130, 268, 80 ,25,BLACK);
print_to_serial();
if (digitalRead(CLICK) == 0)
flip_page();}
void print_to_serial()
Serial.print(millis());
for( int i = 0; i < NR_OF_CHANNELS ; i++ ) {
if(i) Serial.print(",");
else Serial.print(":");
Serial.print(channel[i].name);
Serial.print("=");
Serial.print(channel[i].value);
//void clear_lcd(void){
//sLCD.write(COMMAND);
//sLCD.write(CLEAR);
initializing can
Enter setting mode failed
