Hello all.
I'm new here. I just got my first Teensy board (Teensy 3.6). I have been playing around with Arduino for a while now, but I recently got a project that I needed something that was faster.... which is giving me some troubles...
I want to sample a signal (500Hz to 9KHz), calculate the frequency with an FFT and then output a voltage proportional to the frequency.
I found some FFT routines from a website in Norway... I think it's Norway... (https://www.norwegiancreations.com/2017/08/what-is-fft-and-how-can-you-implement-it-on-an-arduino/) and it works very well... it takes a single tone and outputs the frequency.
My problem is that I'm not getting the voltage to change at all with the frequency. I have wired a single pole filter on the output to 'smooth' the PWM to a DC signal... but.. I'm not getting any change in voltage...
I'm sure it's some totally newb thing that I'm missing... If anybody has any ideas, I'd really appreciate it...
Here's my source code;
#include "arduinoFFT.h"
#define SAMPLES 128 //Must be a power of 2
#define SAMPLING_FREQUENCY 20000 //Hz, must be less than 10000 due to ADC
// setup the variables
arduinoFFT FFT = arduinoFFT();
unsigned int sampling_period_us;
unsigned long microseconds;
double vReal[SAMPLES];
double vImag[SAMPLES];
unsigned int pwm_op;
int cnt = 0;
int state = 0;
int analogBits = 1350;
// set up the board
sampling_period_us = round(1000000*(1.0/SAMPLING_FREQUENCY));
//set up the board LED to show that it's running
pinMode(LED_BUILTIN, OUTPUT);
// set resolution to 12 bytes
analogWriteResolution(12);
cnt++;
if (cnt>100) // toggle LED every 100 samples to show it's running
cnt=0;
if (state==0){
state=1;
else{
state=0;
digitalWrite(LED_BUILTIN, state);
else{ // otherwise, just grab a new sample.
for(int i=0; i<SAMPLES; i++){
microseconds = micros(); //Overflows after around 70 minutes!
vReal[i] = analogRead(0);
//vImag[i] = analogRead(1);
vImag[i] = 0;
while(micros() < (microseconds + sampling_period_us)){
// FFT -- get dominant frequency
FFT.Windowing(vReal, SAMPLES, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
FFT.Compute(vReal, vImag, SAMPLES, FFT_FORWARD);
FFT.ComplexToMagnitude(vReal, vImag, SAMPLES);
double peak = FFT.MajorPeak(vReal, SAMPLES, SAMPLING_FREQUENCY);
//map freq
pwm_op = map(peak,0,9000,0,4095);
//dump to monitor for plotting/viewing
Serial.println(pwm_op);
// set A14 to voltage
analogWrite(A14,pwm_op); // write to A14
delay(10); //Repeat the process every .01 seconds OR:
//while(1); //Run code once
