Results 1 to 18 of 18
Thread: Teensy ARM Memory Map and CRC Build Utility
    Aug 2018
    Southern California
    9
    Hello Teensy Lovers!
    I created a Teensy memory map and CRC generator for the Teensy Arduino build process that will put a nicely formatted memory map in the Arduino build output (verbose compile output). Currently, it only works for Windows [ I know right?!]. I invite anyone to update/modify the source and please share your application. I am using this to work on an advanced terminal program for Teensy ARM.
    Here is a link to the Git repository:
    https://github.com/jchurchwell/Teensy-Memory-Map
    To get setup after downloading the source code:
    This assumes you have Arduino and the Teensy Arduino Add-In
    1. Compile the VB.NET source to the release directory
    2. Navigate to the Arduino hardware tools directory
    3. Re-name the file 'teensy_post_compile.exe' to 'REAL_teensy_post_compile.exe'
    4. Copy the file 'teensy_post_compile.exe' from the release directory and place it in the Arduino-hardware-tools directory
      i.e. 'C:\Program Files (x86)\Arduino\hardware\tools'
    5. Verify, through the Arduino IDE preferences (File->Preferences), that the 'Show verbose output during compile’ is checked
    6. Test the memory map generation Using the Arduino IDE and note that it displays the memory map in the compile output window
    And here is an example output:
    Variable Name
    Memory Address Segment : Memory Address Offset
    SizeInBytes
    7,992
    Awesome for Windows! I just installed VS17 so I wanted something to build.
    It did:
    1>------ Build started: Project: teensy_post_compile, Configuration: Release Any CPU ------
    1>T:\T_Downloads\Teensy-Memory-Map-master\Teensy-Memory-Map-master\teensy_post_compile\teensy_post_compile\tee nsy_post_compile\Module1.vb(155,43): warning BC42024: Unused local variable: 'M'.
    1> teensy_post_compile -> T:\T_Downloads\Teensy-Memory-Map-master\Teensy-Memory-Map-master\teensy_post_compile\teensy_post_compile\tee nsy_post_compile\bin\Release\teensy_post_compile.e xe
    ========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
    But I don't see a map - just the prior RAM/FLASH use numbers?
    Did I miss something? I downloaded the Zip - and the solution was in another zip I extracted in the folder and it built.
    Aug 2018
    Southern California
    9
    It's cool to see someone interested so soon!
    I am happy to help... Did you follow the 6 steps outlined in the README.md (also included above)?
    I am using Windows 7... BTW
    -Joe
    7,992
    Win 10 here. Resultant EXE was 12KB versus REAL of 25KB.
    I did my best to read and follow the steps.
    -a---- 6/7/2018 4:53 PM 25600 REAL_teensy_post_compile.exe
    -a---- 8/15/2018 4:12 PM 12288 teensy_post_compile.exe
    OH WAIT … I'm using TyCommander - it may replace/subvert the post_compile process … loading the TeensyLoader IDE ...
    Now just missing one step :: find 'avr-objdump.exe'
    'avr-objdump.exe' is not recognized as an internal or external command,
    operable program or batch file.
    ***************** CRC CALCULATIONS *******************
    ELF CRC = F02561E
    HEX CRC = 41DD9B45
    MAP CRC = 0
    **************** END CRC CALCULATIONS ****************
    <edit>: I build from here :: T:\arduino_1.8.5_142\hardware\tools
    Aug 2018
    Southern California
    9
    Awe Snap! I think I'll have to add another step in the required steps. Try to add WinAVR to your path variable. If you don't have WinAVR then I suppose you will have to get that too. This is what is the pertinent information in my path variable: "C:\WinAVR-20100110\bin;C:\WinAVR-20100110\utils\bin"
    If you don't want to set the path variable you can change the VB program to be more explicit on where to look for avr-objdump.exe.
    7,992
    I rebuilt to use::
    shell_output = "cmd /c t:\tmp\objdump.exe -t " & output_path & "\" & output_file & ".elf" & " > " & output_path & "\" & output_file & ".map"
    {from the ARM toolchain - not the AVR- version}
    and copied to t:\tmp from :: "T:\arduino_1.8.5_142\hardware\tools\arm\arm-none-eabi\bin\objdump.exe"
    T:\arduino_1.8.5_142\hardware\teensy/../tools/teensy_post_compile -file=DebugTest.ino -path=T:\TEMP\arduino_build_115913 -tools=T:\arduino_1.8.5_142\hardware\teensy/../tools -board=TEENSY36 -reboot -port=usb:0/140000/0/1/1 -portlabel=COM10 (Teensy 3.6) Serial -portprotocol=Teensy
    __brkval                                                        1fff:0750               4
    __fdlib_version                                                 1fff:080e               1
    __global_locale                                                 1fff:0c3c             364
    __malloc_av_                                                    1fff:0da8            1032
    __malloc_current_mallinfo                                       1fff:16a4              40
    __malloc_max_sbrked_mem                                         1fff:169c               4
    __malloc_max_total_mem                                          1fff:1698               4
    __malloc_sbrk_base                                              1fff:11b4               4
    __malloc_top_pad                                                1fff:16a0               4
    __malloc_trim_threshold                                         1fff:11b0               4
    __mprec_bigtens                                                 0000:8970              40
    __mprec_tens                                                    0000:88a8             200
    _ctype_                                                         0000:87a0             257
    _Ftype                                                          1fff:0730              28
    _global_impure_ptr                                              0000:878c               4
    _impure_ptr                                                     1fff:0c38               4
    _VectorsFlash                                                   0000:0000             464
    _VectorsRam                                                     1fff:0200             464
    _ZN11MillisTimer10listActiveE                                   1fff:1340               4
    _ZN11MillisTimer11listWaitingE                                  1fff:1350               4
    _ZN14EventResponder10firstYieldE                                1fff:1348               4
    _ZN14EventResponder13lastInterruptE                             1fff:133c               4
    _ZN14EventResponder14firstInterruptE                            1fff:1338               4
    _ZN14EventResponder16runningFromYieldE                          1fff:134c               1
    _ZN14EventResponder9lastYieldE                                  1fff:1344               4
    DebBack                                                         1fff:11d8              42
    DebCnt                                                          1fff:11d4               4
    DebInfo                                                         1fff:1208              40
    DebSer                                                          0000:8500               4
    digital_pin_to_info_PGM                                         0000:8508             512
    errno                                                           1fff:16e0               4
    flashconfigbytes                                                0000:0400              16
    last_func                                                       1fff:1204               4
    Serial                                                          1fff:0754              16
    string0                                                         1fff:07f4               4
    systick_millis_count                                            1fff:1238               4
    usb_buffer_memory                                               1fff:03d0             864
    usb_cdc_line_coding                                             1fff:16d4               8
    usb_cdc_line_rtsdtr                                             1fff:1334               1
    usb_cdc_line_rtsdtr_millis                                      1fff:16dc               4
    usb_cdc_transmit_flush_timer                                    1fff:1324               1
    usb_configuration                                               1fff:131c               1
    usb_descriptor_list                                             0000:8734              84
    usb_endpoint_config_table                                       0000:8730               4
    usb_reboot_timer                                                1fff:12a5               1
    usb_rx_byte_count_data                                          1fff:16cc               8
    usb_rx_memory_needed                                            1fff:1311               1
    usb_string_manufacturer_name_default                            1fff:0780              24
    usb_string_product_name_default                                 1fff:07dc              22
    usb_string_serial_number_default                                1fff:07f8              22
    	ELF CRC = 53C0B59D
    	HEX CRC = 7FB23C1E
    	MAP CRC = C9741A17
    That worked quick and dirty.
    To confirm the TyCommander edits to platform.txt comments out the teensy_post_compile lines.
    Aug 2018
    Southern California
    9
    Cool! I wonder if there is any difference between the toolchains. I'll have to try it both ways and do a diff. ;-)
    7,992
    Hopefully the same read of the HEX (?) file gice the same results. But the ARM code should come with Teensy and always be in that spot.
    If you are going to really hope to make an 'advanced terminal program for Teensy ARM' you should work with TyCommander. Koromix may or may not be looking to develop that further - I haven't had issues in some time to ask him about where he has been most responsive in past years. But that is an robust and exemplary piece of work that makes using Teensy and the IDE way more awesomer than it is without it! It does program loading as well as SerMon to one or more devices in one or more windows with a pleasing GUI. His code is on github and I believe open. He had noted ideas in past about doing more with it. His code is all 'c' and builds for him not on Windows - but there is a way to do that. TyComm reads the HEX and parses it to confirm the type of Teensy at hand - he could easily construct this DUMP on an info page.
    Aug 2018
    Southern California
    9
    That seems cool but a bit more complicated than what I wanted to do. Either way I'll check it out. Thanks.
    7,992
    Paul: I added this to my TeensyDuino 1.42 IDE and I'm now seeing ::
    Now able to open COM10 (Windows said this port was ready before it was actually ready...)
    That prints as the building starts and after it completes:: Unable to open COM10
    After the build the upload worked and the T_sermon connected just fine.
    Perhaps it is to be expected if the 'teensy_post_compile.exe' program has some other code not replicated?
    <edit>: removed private teensy_post_compile.exe - and behavior above goes back to normal without those notes.
    7,992
    Scanning the code I see the problem might be :: Const TEENSY_POST_COMPILER As String = "REAL_teensy_post_compile.exe" ' "C:\Program Files (x86)\Arduino\hardware\tools\REAL_teensy_post_comp ile.exe"
    That is not where my tools dir is. So it was failing to call that REAL_ exe.
    Aug 2018
    Southern California
    9
    Actually the "REAL_teensy_post_compiler" is a relative path. I had this hard coded to my path before and left my path in there for commenting purposes. So it is actually a relative path where the single quote, in VB, is a comment.
    However, the "REAL_teensy_post_compiler.exe" file should be in the same path as the generated exe "teensy_post_compile.exe"
    Does that help? The whole thing is kind of a hack 😁
    Aug 2018
    Southern California
    9
    Cool
    Okay... I updated the Git repository to find the objdump.exe file using a directory recursive search. This will try to find the ARM version and if it can't find that version it will use the first one found. It will search the directories and sub-directories based on the directory which contains the generated VB console EXE.
    Thanks for the help defragster!
    I also checked the memory map output to make sure the AVR and ARM version work the same and they do!
    7,992
    Was nice to have my VS install get used and work. I'll update again in coming days and let you know what I find.
    Would be nice to be able to turn it off - could you search for a specific item in the list and not generate the MAP output it is didn't exist?
    Not sure if something like this would work?:: uint32_t IDE_SHOW_MAP = 100;
    The bad part is I tend to use my TyCommander install because it offers a much improved build and debug environment.
    > Sermon output can be static across compiles and devices
    > Allows cut and paste before during and after compile - doesn't lock out or drop saved text
    > More easily select one or more devices to program
    > Have multiple device open in Sermon at a time from single IDE
    > GUI offers RESET and Bootloader button
    Aug 2018
    Southern California
    9
    Yeah... No worries if you use the TyCommander. It sounds like a really cool tool set. Can you still use it when there is no USB connected? I would love to see some documentation to read through.
    I think of this "tool" as just a low level easy thing to get people thinking about where their stuff actually goes in memory and what is using it all. I don't plan to make it able to turn off for my purpose since it doesn't really do anything other than display information. Also, if you de-select the verbose output from the Arduino settings then it won't display but it also won't display much of anything at that point.
    Anyway... I want to make my own protocol for my omnidirectional robot that has low overhead for communication using a binary format. The higher level robot will use heuristic processing with this protocol and query by named value.
    7,992
    Pulled the zip - and unzipped the internal zip and VS gave me a 15 KB .exe that worked to run. Second compile still generates the noted abnormal PJRC text notes.
    Map looks like this. This has a library call that adds a 22KB hit that doesn't show in any way on the map. Is that something that could be pulled out and displayed? You can get the sketch from this thread <LINK>. And the notes in the follow posts.
    T:\arduino_1.8.5_142\hardware\teensy/../tools/teensy_post_compile -file=sketch_aug12a.ino -path=T:\TEMP\arduino_build_476769 -tools=T:\arduino_1.8.5_142\hardware\teensy/../tools -board=TEENSY36 -reboot -port=usb:0/140000/0/1/1 -portlabel=COM10 (Teensy 3.6) Serial -portprotocol=Teensy
                                 MEMORY MAP OUTPUT
                                  Version 1.0.0.1
    The Map Generator Tool Found = 3 matching executables in T:\arduino_1.8.5_142\hardware\tools\
    T:\arduino_1.8.5_142\hardware\tools\objdump.exe
    T:\arduino_1.8.5_142\hardware\tools\avr\avr\bin\objdump.exe
    MEMORY MAP GEN USING T:\arduino_1.8.5_142\hardware\tools\arm\arm-none-eabi\bin\objdump.exe
    .hidden                                                         1fff:0000             160
    .hidden                                                         1fff:0748              16
    .hidden                                                         1fff:0758              22
    .hidden                                                         1fff:11f4               4
    .hidden                                                         1fff:12cd               1
    .hidden                                                         1fff:12ce               1
    .hidden                                                         1fff:12cf               1
    .hidden                                                         1fff:12d0               1
    .hidden                                                         1fff:12d1               1
    .hidden                                                         1fff:12d2               1
    .hidden                                                         1fff:12d3               1
    .hidden                                                         1fff:12d4               1
    .hidden                                                         1fff:12d5               1
    .hidden                                                         1fff:12d6               1
    .hidden                                                         1fff:12d7               1
    .hidden                                                         1fff:12d8               1
    __global_locale                                                 1fff:0c1c             364
    __malloc_av_                                                    1fff:0d88            1032
    __malloc_current_mallinfo                                       1fff:15f0              40
    __malloc_max_sbrked_mem                                         1fff:15e8               4
    __malloc_max_total_mem                                          1fff:15e4               4
    __malloc_sbrk_base                                              1fff:1194               4
    __malloc_top_pad                                                1fff:15ec               4
    __malloc_trim_threshold                                         1fff:1190               4
    __mprec_bigtens                                                 0000:6a88              40
    __mprec_tens                                                    0000:69c0             200
    _ctype_                                                         0000:6abc             257
    _global_impure_ptr                                              0000:69a8               4
    _impure_ptr                                                     1fff:0c18               4
    errno                                                           1fff:1618               4
    	ELF CRC = B3BBB29E
    	HEX CRC = 915F91DC
    	MAP CRC = DD7FAE7E
                               END MEMORY MAP OUTPUT
    7,992
    Quote Originally Posted by JoeChurchwell View Post
    TyCommander was TyQt before - there is a thread for it with history and notes for anything that isn't self explanatory.
    It takes USB wire to connect - it supports HID or USB Serial if that is what you mean. It serves up SerMon data and incorporates programming as well.
    It would be handy for reference. I use IDE with Verbose - and this adds a double dump of that text cluttering the output on each compile - once as console then again as the output. makes it too easy to scroll past warnings - though I suppose it won't be called on errors.
    Good lulck with the robot.
    Aug 2018
    Southern California
    9
                                 MEMORY MAP OUTPUT
                                  Version 1.0.0.1
    .hidden                                                         1fff:11f4               4
    .hidden                                                         1fff:12cd               1
    .hidden                                                         1fff:12ce               1
    .hidden                                                         1fff:12cf               1
    .hidden                                                         1fff:12d0               1
    .hidden                                                         1fff:12d1               1
    .hidden                                                         1fff:12d2               1
    .hidden                                                         1fff:12d3               1
    .hidden                                                         1fff:12d4               1
    .hidden                                                         1fff:12d5               1
    .hidden                                                         1fff:12d6               1
    .hidden                                                         1fff:12d7               1
    .hidden                                                         1fff:12d8               1
    errno                                                           1fff:1618               4
    	ELF CRC = B3BBB29E
    	HEX CRC = 915F91DC
    	MAP CRC = DD7FAE7E
    If the compile doesn't compile all the way then the map won't be correct.
    This is what my output looks like:
                                 MEMORY MAP OUTPUT
                                  Version 1.0.0.1
    The Map Generator Tool Found = 2 matching executables in C:\Program Files (x86)\Arduino\hardware\tools\
    C:\Program Files (x86)\Arduino\hardware\tools\avr\avr\bin\objdump.exe
    C:\Program Files (x86)\Arduino\hardware\tools\arm\arm-none-eabi\bin\objdump.exe
    MEMORY MAP GEN USING C:\Program Files (x86)\Arduino\hardware\tools\arm\arm-none-eabi\bin\objdump.exe
    __brkval                                                        1fff:0738               4
    __global_locale                                                 1fff:0c24             364
    __malloc_av_                                                    1fff:0d90            1032
    __malloc_current_mallinfo                                       1fff:15ec              40
    __malloc_max_sbrked_mem                                         1fff:15e4               4
    __malloc_max_total_mem                                          1fff:15e0               4
    __malloc_sbrk_base                                              1fff:119c               4
    __malloc_top_pad                                                1fff:15e8               4
    __malloc_trim_threshold                                         1fff:1198               4
    __mprec_bigtens                                                 0000:7078              40
    __mprec_tens                                                    0000:6fb0             200
    _ctype_                                                         0000:6ea8             257
    _global_impure_ptr                                              0000:6e94               4
    _impure_ptr                                                     1fff:0c20               4
    _ZN11MillisTimer10listActiveE                                   1fff:12c8               4
    _ZN11MillisTimer11listWaitingE                                  1fff:12d8               4
    _ZN14EventResponder10firstYieldE                                1fff:12d0               4
    _ZN14EventResponder13lastInterruptE                             1fff:12c4               4
    _ZN14EventResponder14firstInterruptE                            1fff:12c0               4
    _ZN14EventResponder16runningFromYieldE                          1fff:12d4               1
    _ZN14EventResponder9lastYieldE                                  1fff:12cc               4
    errno                                                           1fff:1628               4
    Serial                                                          1fff:0740              16
    string0                                                         1fff:07dc               4
    systick_millis_count                                            1fff:11c0               4
    test                                                            1fff:0730               8
    usb_cdc_line_coding                                             1fff:161c               8
    usb_cdc_line_rtsdtr                                             1fff:12bc               1
    usb_cdc_line_rtsdtr_millis                                      1fff:1624               4
    usb_cdc_transmit_flush_timer                                    1fff:12ac               1
    usb_configuration                                               1fff:12a4               1
    usb_descriptor_list                                             0000:6e40              84
    usb_endpoint_config_table                                       0000:6e3c               4
    usb_reboot_timer                                                1fff:122d               1
    usb_rx_byte_count_data                                          1fff:1614               8
    usb_rx_memory_needed                                            1fff:1299               1
    usb_string_manufacturer_name_default                            1fff:0768              24
    usb_string_product_name_default                                 1fff:07c4              22
    usb_string_serial_number_default                                1fff:07e0              22
    	ELF CRC = 8BE49286
    	HEX CRC = CF0370D3
    	MAP CRC = F6C713DD
