i want to examine output from teensy before connecting it to the main apparatus .
the output is being drawn from a sFIFO and sent to port D every 30 mcsec via timer function.
until now i used Serial.print everytime the output was sent but it slows down the process , i want to assign the output into an array and than print it all at once with a pushbutton .
i add the code , mylist is an empty array which is assigned with the output (GPIOD_PDIR) everytime the output is being overwritten .
the current code is not good , i can't track the exact problem but it is not consistent , i'm lost in a swirl of errors and corrections not really sure where am i getting . most of the time nothing is printed , but sometimes it prints out weird results , the counter j reaches 143 and most of the output is zeros .
i am looking for an alternative approach to testing the output , maybe a better way of assigning values to a list inside a function which is called by timer ?
if there's no better way . maybe someone can point out programming errors such as wrong declaration if variables ?
thank you
the code
thank you
the code
#include <Bounce.h>
//make sure the libraries are downloaded to CPU
#define SIMPLEFIFO_LARGE
#include <SimpleFIFO.h>
// PTA (12 15 16) = [3 27 28] // ready signal , switch and push buttons for manual reward
// PTB (0 1 2 3) = [16 17 19 18] // For address bits
// PTC (0 1 2 3 4 5 6 7 8 9 10 11) = [15 22 23 9 10 13 11 12 35 36 37 38] // For digital inputs from NI cards
// PTD (0 1 2 3 4 5 6 7 15) = [2 14 7 8 6 20 21 5 54] //for digital output to plexon and one strobe signal
// PTE (25) = [34] // reward
byte inputPins[] = {3, 4, 16, 17, 19, 18, 15, 22, 23, 9, 10, 13, 11, 12, 35, 36, 37, 38};
byte outputPins[] = {2, 14, 7, 8, 6, 20, 21, 5, 54, 34};
byte mylist[100] = {};
unsigned int j=0;
bool isCharOn = false; //set to true when fifo bit was sent , to false when port cleared
unsigned int rewardON ;
elapsedMicros charTime;
elapsedMillis rewardTime;
int onDur = 1;
const int rewardPosition = 25;
const int Dready = 3 ;// data ready pin number
const int buttonPin = 28;
const int buttonPin2 = 27;
Bounce pushbutton = Bounce(buttonPin, 10);
Bounce switchbutton = Bounce(buttonPin2, 10);
IntervalTimer myTimerOne;
IntervalTimer myTimerTwo;
IntervalTimer myTimerThree;
//define a fifo
SimpleFIFO <long, 255> sFIFO;
//strobe_charOff func waits for ready signal to turn low and receive strobe signal on port B , than inserts value of port C to fifo . independently , checks onDur time passed since charOn turned high and turns it low . (better results recorded for a joint timer than seperate timers for strobe and charOff)
void strobe_charOff(void) {
if (GPIOB_PDIR == 7) {
sFIFO.enqueue(GPIOC_PDIR & 0xFF);
//Serial.println("check port C");
//Serial.println(GPIOC_PDOR & 0xFF);
//charout sends out the first fifo value in line and initializes timer
void charOut() {
if (sFIFO.count() > 0){
if (GPIOD_PDOR == 0x00) {
GPIOD_PDOR = sFIFO.dequeue()|0x8000;
//Serial.println("check port D");
//Serial.print(char(GPIOD_PDOR & 0xFF));
mylist[j] = GPIOD_PDIR & 0xFF;
j=j+1;
isCharOn=true;
charTime = 0;//timer
else {
sFIFO.flush();
//manual reward checks if buttons have been pressed- two buttons , one for quick 25 milisecond dosage ,
//other for drain . drain sets the reward pin high for 7 second (more than neccesary) with an additional press setting it back low.
//method is similar to other functions , set pin high ,initialize timer and set timer threshold.
void ManualReward(void) {
if (pushbutton.update()) {
if (pushbutton.risingEdge()) {
rewardON = 25;
GPIOE_PDOR= 0x2000000;
rewardTime = 0;//start counting until stop
Serial.print("j=");Serial.print(j);
for (unsigned int k = 0; k < j; k++) {
Serial.println(char(mylist[k]));
Serial.println(mylist[k]);
if (switchbutton.update()) {
if (switchbutton.fallingEdge()) {
//if (GPIOE_PDOR == 0x00 ){
rewardON = 7000;
else {
rewardON = 25;
rewardTime = 0;
Serial.begin(9600);while(!Serial);
pinMode(buttonPin, INPUT_PULLUP);
pinMode(buttonPin2, INPUT_PULLUP);
for (int pinnum = 0; pinnum < 18; pinnum++) {
//pinMode(inputPins[pinnum], INPUT_PULLDOWN);
pinMode(inputPins[pinnum], INPUT);
for (int pinnum = 0; pinnum < 10; pinnum++) {
pinMode(outputPins[pinnum], OUTPUT);
//setting timers , strobe recalls every 1 microsecond since the strobe input is the fastest.
//charOut is second in priority , but recalls every 100000 micros since every letter needs 'onDur' time to be sent
//manual reward recalles every 10000 micros (insignificant) but least in priority so to not override any loops that collect or send data .
attachInterrupt(digitalPinToInterrupt(Dready), strobe_charOff , FALLING);
myTimerTwo.priority(1);
myTimerTwo.begin(charOut,30);
myTimerThree.priority(16);
myTimerThree.begin(ManualReward,10000);
sFIFO.flush();
//loop functions set pins back low . duration of output signal can be changed in the setup section . (onDur)
if (isCharOn && charTime > onDur) {
GPIOD_PDOR = 0x00;
isCharOn = false;
if ( GPIOE_PDOR>>rewardPosition && rewardTime > rewardON) {//if the reward output is being sent for the input time
//digitalWriteFast(34,LOW);
GPIOE_PDOR = 0x0;//stop reward
