Hello all,
I am using the teensy 3.2 with Teensy audio board to recreate this project with some of my own modifications. I am having trouble with getting sound out of a speaker unless I plug in headphones also. I have included a Fritzing diagram of my circuit and the main code (minus the TeensyAudioDesignTool.h and the note_frequency.h) that I am using. One thing to note is that I will be using an I2C screen and as such this is what is in the Fritzing diagram, however the code is still set-up as per my prototype that was using the teensy-view.
What I want to have is a toggle switch to toggle between using the speaker and the 1/4in line out for sound but always still have the headphones producing sound (like in the link). I am using a mono amp for this which is the same as the sparkfun tutorial one.
Any help would be appreciated,
  Digital Handpan V2 Code for Teesny
  Joel Bartlett @ SparkFun Electronics
  Original Creation Date: December 16, 2017
  Modified Code: David Cool
  Modify Date: January 12, 2017
  Modified further by Asha Ward
  Modify Date: 4th April 2018
  This sketch produces polyphonic notes when any number of eight capacitive touch pads are
  touched, thus replicating a Handpan (or Hang) steel drum. This sketch
  makes use of the Teensy Audio Shield (https://www.sparkfun.com/products/12767)
  as well as the Teensy Audio System Design Tool (http://www.pjrc.com/teensy/gui/).
  All capactive touch sensing is handled by the Teensy's built in Touch Sense Pins.
  Hardware:
    Teensy 3.2 Dev Board (https://www.sparkfun.com/products/13736)
    Teensy Audio Board (https://www.sparkfun.com/products/12767)
    Teensy View OLED Screen (https://www.sparkfun.com/products/14048)
    Various buttons and potentiometers
  Development environment specifics:
    IDE: Arduino IDE V 1.8.5 with the Teensyduino Add-on installed V Teensy Loader V1.30
  This code is beerware; if you see me (or any other SparkFun
  employee) at the local, and you've found our code helpful,
  please buy us a round!
  Distributed as-is; no warranty is given.
//These libraries are included by the Teensy Audio System Design Tool
#include <SerialFlash.h>
#include <Bounce.h>
#include <TeensyView.h>
#include <MAX17043GU.h>
#define MAX17043_ADDRESS 0x36// Battery Fuel Gauge
#include "note_frequency.h"
#include "TeensyAudioDesignTool.h"
//Alternate (Audio) Teensy View Setup
#define PIN_RESET 2
#define PIN_DC    21
#define PIN_CS    20
#define PIN_SCK   14
#define PIN_MOSI  7
#define volKnob A13 //grey wire
#define decayKnob A10//black wire
MAX17043GU battery;
TeensyView oled(PIN_RESET, PIN_DC, PIN_CS, PIN_SCK, PIN_MOSI);
//an array to define each of the eight touch sense pins,
//all other touch sense pins are used by the Teensy Audio Shield (16,17,18,19)
int pinTouch[] = {0, 1, 15, 16, 17, 25, 32, 33}; //25 = white, 32 = yellow, 33 = blue
int scale_index = 0;//var to keep track fo which scale is being used
int note_index = 57;//starting note value (A)
int octave_index = 0;
int wave_index = -1;//var to keep track of which wave is being used
int numOfWaves = 4;//5-1=4
int dcVal = 0;//value to control the decay of each note
int padNumber = 0;//debug for printing pad values to OLED
////////////////////CHANGE THIS WHEN ADDING MORE SCALES
int numOfScales = 13;//indexed at zero (subtract 1)
int scale[8];
//buttons for incrementing or decrementing through each scale
Bounce button0 = Bounce(4, 15);
Bounce button1 = Bounce(3, 15);
Bounce button2 = Bounce(29, 15);
//buttons for incrementing or decrementing the octave
Bounce foot0 = Bounce(5, 30);
Bounce foot1 = Bounce(8, 30);
float vol = 0;
float voltage;
float percentage;
int counter = 0;
bool debug = false;
  //initialize buttons
  pinMode(4, INPUT_PULLUP);
  pinMode(3, INPUT_PULLUP);
  pinMode(5, INPUT_PULLUP);
  pinMode(8, INPUT_PULLUP);
  pinMode(29, INPUT_PULLUP);
  button0.update();
  button1.update();
  button2.update();
  foot0.update();
  foot1.update();
  //initialize Serial
  // Start I2C
  Wire.begin();
  battery.restart();
  //set aside audio memory
  AudioMemory(64);
  //initialize audio settings
  sine1.begin(WAVEFORM_SQUARE);
  sine1.amplitude(0.125);
  sine1.frequency(440);
  sine2.begin(WAVEFORM_SQUARE);
  sine2.amplitude(0.125);
  sine2.frequency(440);
  sine3.begin(WAVEFORM_SQUARE);
  sine3.amplitude(0.125);
  sine3.frequency(440);
  sine4.begin(WAVEFORM_SQUARE);
  sine4.amplitude(0.125);
  sine4.frequency(440);
  sine5.begin(WAVEFORM_SQUARE);
  sine5.amplitude(0.125);
  sine5.frequency(440);
  sine6.begin(WAVEFORM_SQUARE);
  sine6.amplitude(0.125);
  sine6.frequency(440);
  sine7.begin(WAVEFORM_SQUARE);
  sine7.amplitude(0.125);
  sine7.frequency(440);
  sine8.begin(WAVEFORM_SQUARE);
  sine8.amplitude(0.125);
  sine8.frequency(440);
  dc1.amplitude(0);
  dc2.amplitude(0);
  dc3.amplitude(0);
  dc4.amplitude(0);
  dc5.amplitude(0);
  dc6.amplitude(0);
  dc7.amplitude(0);
  dc8.amplitude(0);
  //initialize volume
  sgtl5000_1.enable();
  sgtl5000_1.volume(0.8);
  sgtl5000_1.lineOutLevel(5);
  //Initialize the OLED
  oled.begin();
  // clear(ALL) will clear out the OLED's graphic memory.
  // clear(PAGE) will clear the Arduino's display buffer.
  oled.clear(ALL);  // Clear the display's memory (gets rid of artifacts)
  // To actually draw anything on the display, you must call the
  // display() function.
  oled.display();
  // Give the splash screen some time to shine
  changeScale();//start off at middle C
  volumeCheck();//check the volume knob
  touchCheck();//check if any of the capacitive pads have been touched
  dcValCheck();//check the decay knob
  buttonCheck();//check for button presses to change the scale
 /* counter++;
  if (counter == 10000); //don't check battery all the time, slows opperation
    getBattery();
    counter = 0;
  oledPrint();//print to TeensyView
/*void getBattery()
  // Get the values
  voltage = battery.voltageLevel();
  percentage = battery.fuelLevel();
void oledPrint()
  oled.clear(PAGE);
  oled.setCursor(0, 0);
  oled.print("Scale =");
  if (note_index == 60)
    oled.print("C ");
  if (note_index == 61)
    oled.print("C# ");
  if (note_index == 62)
    oled.print("D ");
  if (note_index == 63)
    oled.print("D# ");
  if (note_index == 64)
    oled.print("E ");
  if (note_index == 65)
    oled.print("F ");
  if (note_index == 66)
    oled.print("F# ");
  if (note_index == 67)
    oled.print("G ");
  if (note_index == 68)
    oled.print("G# ");
  if (note_index == 57)
    oled.print("A ");
  if (note_index == 58)
    oled.print("A# ");
  if (note_index == 59)
    oled.print("B ");
  if (scale_index == 0)
    oled.print("Major");
  if (scale_index == 1)
    oled.print("Minor");
  if (scale_index == 2)
    oled.print("Akebono");
  if (scale_index == 3)
    oled.print("Pygmy");
  if (scale_index == 4)
    oled.print("Equinox");
  if (scale_index == 5)
    oled.print("Sapphire");
  if (scale_index == 6)
    oled.print("Gypsy");
  if (scale_index == 7)
    oled.print("SlvrSpring");
  if (scale_index == 8)
    oled.print("Integral");
  if (scale_index == 9)
    oled.print("Dorian");
  if (scale_index == 10)
    oled.print("GldArcadia");
  if (scale_index == 11)
    oled.print("PentMaj");
  if (scale_index == 12)
    oled.print("PentMin");
  if (scale_index == 13)
    oled.print("Blues");
  oled.setCursor(0, 8);
  oled.print("Volume =");
  int newVol = map(vol, 0.0, 0.8, 0, 100);
  oled.print(newVol);
  oled.print("%  ");
  if (wave_index == 0)
    oled.print("Sine");
  if (wave_index == 1)
    oled.print("Saw");
  if (wave_index == 2)
    oled.print("Square");
  if (wave_index == 3)
    oled.print("Triangle");
  if (wave_index == 4)
    oled.print("Sample");
  oled.setCursor(0, 16);
  oled.print("Decay = ");
  oled.print((int)dcVal / 10);
  oled.print("%  Oct:");
  oled.print(octave_index);
 /* oled.setCursor(0, 24);
  oled.print("Batt = ");
  oled.print(percentage);
  oled.print("% ");
  oled.print(voltage);
  oled.print("V");
  oled.display();
  delay(10);
void volumeCheck()
  vol = (float)analogRead(volKnob) / 1280.0;
  mixerMain.gain(0, vol);
  mixerMain.gain(1, vol);
void dcValCheck()
  //check knob and set value as delay on dc constant for sine wave decay
  dcVal = map(analogRead(decayKnob), 0, 1023, 1, 1000);
void touchCheck()
  //Each capacitive touch pad will vary based on the size and material it is made of
  //The value necessary to trigger each note will require some trial and error to get the
  //sensitivity just right. Try adjusting these values to get the best response.
  if (touchRead(pinTouch[0]) > 1800)
    //once a pad is touched, a value from the note frquency froma table is looked up via a 2D table
    //with x corresponding to a scale and y corresponding to one of the eight notes on the drum.
    if (octave_index == 1)
      sine1.frequency(note_frequency[scale[0] + 12]);
    else if (octave_index == -1)
      sine1.frequency(note_frequency[scale[0] - 12]);
    else if (octave_index == 2)
      sine1.frequency(note_frequency[scale[0] + 24]);
    else if (octave_index == -2)
      sine1.frequency(note_frequency[scale[0] - 24]);
      sine1.frequency(note_frequency[scale[0]]);
    dc1.amplitude(1.0, 5);
  if (touchRead(pinTouch[0]) <= 1800)
    //one the pad is released, the note fades out with a decay val set by the dcVal knob
    dc1.amplitude(0, dcVal);
  if (touchRead(pinTouch[1]) > 1800)
      sine2.frequency(note_frequency[scale[1] + 12]);
      sine2.frequency(note_frequency[scale[1] - 12]);
      sine2.frequency(note_frequency[scale[1] + 24]);
      sine2.frequency(note_frequency[scale[1] - 24]);
      sine2.frequency(note_frequency[scale[1]]);
    dc2.amplitude(1.0, 5);
  if (touchRead(pinTouch[1]) <= 1800)
    dc2.amplitude(0, dcVal);
  if (touchRead(pinTouch[2]) > 1900)
      sine3.frequency(note_frequency[scale[2] + 12]);
      sine3.frequency(note_frequency[scale[2] - 12]);
      sine3.frequency(note_frequency[scale[2] + 24]);
      sine3.frequency(note_frequency[scale[2] - 24]);
      sine3.frequency(note_frequency[scale[2]]);
    dc3.amplitude(1.0, 5);
  if (touchRead(pinTouch[2]) <= 1900)
    dc3.amplitude(0, dcVal);
  if (touchRead(pinTouch[3]) > 1800)
      sine4.frequency(note_frequency[scale[3] + 12]);
      sine4.frequency(note_frequency[scale[3] - 12]);
      sine4.frequency(note_frequency[scale[3] + 24]);
      sine4.frequency(note_frequency[scale[3] - 24]);
      sine4.frequency(note_frequency[scale[3]]);
    dc4.amplitude(1.0, 5);
  if (touchRead(pinTouch[3]) <= 1800)
    dc4.amplitude(0, dcVal);
  if (touchRead(pinTouch[4]) > 1800)
      sine5.frequency(note_frequency[scale[4] + 12]);
      sine5.frequency(note_frequency[scale[4] - 12]);
      sine5.frequency(note_frequency[scale[4] + 24]);
      sine5.frequency(note_frequency[scale[4] - 24]);
      sine5.frequency(note_frequency[scale[4]]);
    dc5.amplitude(1.0, 5);
  if (touchRead(pinTouch[4]) <= 1800)
    dc5.amplitude(0, dcVal);
  if (touchRead(pinTouch[5]) > 1800)
      sine6.frequency(note_frequency[scale[5] + 12]);
      sine6.frequency(note_frequency[scale[5] - 12]);
      sine6.frequency(note_frequency[scale[5] + 24]);
      sine6.frequency(note_frequency[scale[5] - 24]);
      sine6.frequency(note_frequency[scale[5]]);
    dc6.amplitude(1.0, 5);
  if (touchRead(pinTouch[5]) <= 1800)
    dc6.amplitude(0, dcVal);
  if (touchRead(pinTouch[6]) > 1800)
      sine7.frequency(note_frequency[scale[6] + 12]);
      sine7.frequency(note_frequency[scale[6] - 12]);
      sine7.frequency(note_frequency[scale[6] + 24]);
      sine7.frequency(note_frequency[scale[6] - 24]);
      sine7.frequency(note_frequency[scale[6]]);
    dc7.amplitude(1.0, 5);
  if (touchRead(pinTouch[6]) <= 1800)
    dc7.amplitude(0, dcVal);
  if (touchRead(pinTouch[7]) > 1700)
      sine8.frequency(note_frequency[scale[7] + 12]);
      sine8.frequency(note_frequency[scale[7] - 12]);
      sine8.frequency(note_frequency[scale[7] + 24]);
      sine8.frequency(note_frequency[scale[7] - 24]);
      sine8.frequency(note_frequency[scale[7]]);
    dc8.amplitude(1.0, 5);
  if (touchRead(pinTouch[7]) <= 1700)
    dc8.amplitude(0, dcVal);
void buttonCheck()
  button0.update();
  button1.update();
  button2.update();
  foot0.update();
  foot1.update();
  //if button 0 is pressed, increment the scale being used
  if (button0.fallingEdge())
    note_index++;
    padNumber++;
    //check for overflow
    if (note_index > 68)
      note_index = 57;
    if (padNumber > 7)
      padNumber = 0;
    octave_index = 0;
    changeScale();
  //if button 1 is pressed, decrement the scale being used
  if (button1.fallingEdge())
    scale_index++;
    padNumber--;
    if (scale_index > numOfScales)
      scale_index = 0;
    if (padNumber < 0)
      padNumber = 7;
    octave_index = 0;
    changeScale();
  //if foot pedal 0 is pressed, increment the octave
  if (foot0.risingEdge())
    octave_index++;
    if (octave_index > 2)
      octave_index = 2;
  if (foot1.risingEdge())
    octave_index--;
    if (octave_index < -2)
      octave_index = -2;
  //if button 1 is pressed, cycle through wave types
  if (button2.risingEdge())
    wave_index++;
    if (wave_index > numOfWaves)
      wave_index = 0;
    switch (wave_index) {
      case 0:
        Serial.println("WAVEFORM_SINE");
        sine1.begin(WAVEFORM_SINE);
        sine2.begin(WAVEFORM_SINE);
        sine3.begin(WAVEFORM_SINE);
        sine4.begin(WAVEFORM_SINE);
        sine5.begin(WAVEFORM_SINE);
        sine6.begin(WAVEFORM_SINE);
        sine7.begin(WAVEFORM_SINE);
        sine8.begin(WAVEFORM_SINE);
      case 1:
        Serial.println("WAVEFORM_SAWTOOTH");
        sine1.begin(WAVEFORM_SAWTOOTH);
        sine2.begin(WAVEFORM_SAWTOOTH);
        sine3.begin(WAVEFORM_SAWTOOTH);
        sine4.begin(WAVEFORM_SAWTOOTH);
        sine5.begin(WAVEFORM_SAWTOOTH);
        sine6.begin(WAVEFORM_SAWTOOTH);
        sine7.begin(WAVEFORM_SAWTOOTH);
        sine8.begin(WAVEFORM_SAWTOOTH);
      case 2:
        Serial.println("WAVEFORM_SQUARE");
      case 3:
        Serial.println("WAVEFORM_TRIANGLE");
        sine1.begin(WAVEFORM_TRIANGLE);
        sine2.begin(WAVEFORM_TRIANGLE);
        sine3.begin(WAVEFORM_TRIANGLE);
        sine4.begin(WAVEFORM_TRIANGLE);
        sine5.begin(WAVEFORM_TRIANGLE);
        sine6.begin(WAVEFORM_TRIANGLE);
        sine7.begin(WAVEFORM_TRIANGLE);
        sine8.begin(WAVEFORM_TRIANGLE);
      case 4:
        Serial.println("WAVEFORM_SAMPLE_HOLD");
        sine1.begin(WAVEFORM_SAMPLE_HOLD);
        sine2.begin(WAVEFORM_SAMPLE_HOLD);
        sine3.begin(WAVEFORM_SAMPLE_HOLD);
        sine4.begin(WAVEFORM_SAMPLE_HOLD);
        sine5.begin(WAVEFORM_SAMPLE_HOLD);
        sine6.begin(WAVEFORM_SAMPLE_HOLD);
        sine7.begin(WAVEFORM_SAMPLE_HOLD);
        sine8.begin(WAVEFORM_SAMPLE_HOLD);
          case 2:
          Serial.println("WAVEFORM_SAWTOOTH_REVERSE");
          sine1.begin(WAVEFORM_SAWTOOTH_REVERSE);
          sine2.begin(WAVEFORM_SAWTOOTH_REVERSE);
          sine3.begin(WAVEFORM_SAWTOOTH_REVERSE);
          sine4.begin(WAVEFORM_SAWTOOTH_REVERSE);
          sine5.begin(WAVEFORM_SAWTOOTH_REVERSE);
          sine6.begin(WAVEFORM_SAWTOOTH_REVERSE);
          sine7.begin(WAVEFORM_SAWTOOTH_REVERSE);
          sine8.begin(WAVEFORM_SAWTOOTH_REVERSE);
          case 5:
          Serial.println("WAVEFORM_ARBITRARY");
          sine1.begin(WAVEFORM_ARBITRARY);
          sine2.begin(WAVEFORM_ARBITRARY);
          sine3.begin(WAVEFORM_ARBITRARY);
          sine4.begin(WAVEFORM_ARBITRARY);
          sine5.begin(WAVEFORM_ARBITRARY);
          sine6.begin(WAVEFORM_ARBITRARY);
          sine7.begin(WAVEFORM_ARBITRARY);
          sine8.begin(WAVEFORM_ARBITRARY);
          case 6:
          Serial.println("WAVEFORM_PULSE");
          sine1.begin(WAVEFORM_PULSE);
          sine2.begin(WAVEFORM_PULSE);
          sine3.begin(WAVEFORM_PULSE);
          sine4.begin(WAVEFORM_PULSE);
          sine5.begin(WAVEFORM_PULSE);
          sine6.begin(WAVEFORM_PULSE);
          sine7.begin(WAVEFORM_PULSE);
          sine8.begin(WAVEFORM_PULSE);
    } //end case
void changeScale()
  //Change numOfScales variable at top if adding new scale!!
  int root = note_index;
  if (scale_index == 0) //Major Scale  2,2,3,2,3,2,2  (WholeStep, WS, WS+HalfStep, WS, WS+HS, WS, WS) Asha changed to w,w,h,w,w,w,h
    scale[0] = root;
    scale[1] = root + 2;
    scale[2] = root + 4;
    scale[3] = root + 5;
    scale[4] = root + 7;
    scale[5] = root + 9;
    scale[6] = root + 11;
    scale[7] = root + 12;
  if (scale_index == 1) //Minor Scale  3,2,2,3,2,3,2
    scale[0] = root;
    scale[1] = root + 3;
    scale[2] = root + 5;
    scale[3] = root + 7;
    scale[4] = root + 10;
    scale[5] = root + 12;
    scale[6] = root + 15;
    scale[7] = root + 17;
  if (scale_index == 2) //Akebono Scale  2,1,4,1,4,2,1
    scale[0] = root;
    scale[2] = root + 3;
    scale[4] = root + 8;
    scale[6] = root + 14;
    scale[7] = root + 15;
  if (scale_index == 3) //Pygmy Scale  2,1,4,3,2,2,1
    scale[0] = root;
  if (scale_index == 4) //Equinox Scale  4,1,2,2,2,1,4
    scale[0] = root;
    scale[1] = root + 4;
    scale[4] = root + 9;
    scale[5] = root + 11;
    scale[6] = root + 12;
    scale[7] = root + 16;
  if (scale_index == 5) //Sapphire    3,2,4,1,2,3,2
    scale[0] = root;
    scale[3] = root + 9;
  if (scale_index == 6) //Gypsy    1,3,1,2,1,2,2
    scale[0] = root;
    scale[1] = root + 1;
    scale[5] = root + 8;
    scale[6] = root + 10;
  if (scale_index == 7) //Silver Spring  4,1,2,2,3,4,1
    scale[0] = root;
    scale[6] = root + 16;
  if (scale_index == 8) //Integral  2,1,4,1,2,2,2
    scale[0] = root;
    scale[5] = root + 10;
    scale[7] = root + 14;
  if (scale_index == 9) //Dorian  2,1,2,2,2,3,2
    scale[0] = root;
  if (scale_index == 10) //Golden Arcadia  4,3,4,1,2,4,1
    scale[0] = root;
    scale[2] = root + 7;
    scale[3] = root + 11;
    scale[4] = root + 12;
    scale[5] = root + 14;
    scale[6] = root + 18;
    scale[7] = root + 19;
  if (scale_index == 11) // pentatonic major ws, ws, hs+ws, ws , hs+ws
    scale[0] = root;
  if (scale_index == 12) // pentatonic minor ws+hs, w, w, ws+hs, w
    scale[0] = root;
  if (scale_index == 13) // blues ws+hs, w, h, h, ws+hs, w
    scale[0] = root;
    scale[3] = root + 6;
