Biquad-filter low corner frequency test-sketch
AdaZus
For those which are interested in Biquad filter…
Here is a testsketch with low corner frequency:
[url]https://www.pjrc.com/teensy/gui/index.html?info=AudioFilterBiquad[/url]
Biquad filters test with low corner frequency @ Teensy 3.6.
Try out following sketch.
AudioInputI2S            i2s1;           //xy=105,240
AudioAmplifier           amp1;           //xy=264,226
AudioFilterBiquad        biquad1;        //xy=441,226
AudioAnalyzePeak         peak1;          //xy=621,226
AudioConnection          patchCord1(i2s1, 0, amp1, 0);
AudioConnection          patchCord2(amp1, biquad1);
AudioConnection          patchCord3(biquad1, peak1);
AudioControlSGTL5000     sgtl5000_1;     //xy=362,332
elapsedMillis msecs;
//Tones and frequencies
float C = 65.40;
float CIS = 69.29;
float D = 73.41;
float GIS = 103.82;
float A = 110;
float AIS = 116.54;
  AudioMemory(30);
  sgtl5000_1.enable();
  // MicIn
  sgtl5000_1.micGain(50); // sgtl5000_1.micGain(30); original
  amp1.gain(0); //MicIn (i2s1) gain (again)
  //MicIn
    // Filter
    //File > Examples > Audio > Effects > Filter
    // Butterworth filter, 12 db/octave
    // biquad1.setLowpass(0, 700, 0.707);
    // Linkwitz-Riley filter, 48 dB/octave
     biquad1.setBandpass(0, CIS, 15);
     biquad1.setBandpass(1, CIS, 15);
     biquad1.setBandpass(2, CIS, 15);
     biquad1.setBandpass(3, CIS, 15);
     // Filter
      amp1.gain(0.9); // to ajusd MicIn(i2s1)-gain: Filters must have their input signals attenuated, so the signal does not exceed 1.0 (or 2 if measured peak to peak).
       // Amplitude to serial monitor
       if (msecs > 100) {
       if (peak1.available() ) { //&& peak2.available() commented out...only Mono needed.
       msecs = 0;
       float leftNumber = peak1.readPeakToPeak();
       //float rightNumber = Peak.read();
       Serial.println(leftNumber); //left channel
       //Serial.println();
The amplitude-difference (peak to peak) between the filtered tone and one halftone under and over is as follows:
103.82Hz: 0.13V
Filtered tone= 110Hz: 1.95V Amplitude
116.54Hz: 0.13V
Difference 1.82V
65.4Hz: 0.12V
Filtered tone= 69,29Hz: 1.89V Amplitude
73.41Hz: 0.12V
Difference 1.77V
Despite of written in notes @ https://www.pjrc.com/teensy/gui/index.html?info=AudioFilterBiquad
‘Biquad filters with low corner frequency (under about 400 Hz) can run into trouble with limited numerical precision, causing the filter to perform poorly` with Teensy 3.6 works well.
Maybe because the new powerful microcontroller??
These test results are really great! :)
Hi AdaZus,
yes, you can perform very high Q bandpass and notch filters with biquads and they filter very well.
Your example is a bit on the extreme side, a bandpass filter around C# (69Hz) with an extremely high Q of 15.
For my purposes and from my experiences with the fixed point biquad filters, I hear considerable distortion and ringing of those biquad filters when using cutoff frequencies below 400Hz. Maybe you will also find these problems with your example if you perform an FFT of your audio and look at the higher audio frequencies, not only one halftone/tone below and above your bandpass.
If you are satisfied with the audio results for your purpose (filtering only C# from your audio)[BTW, did you really listen to your audio result or did you only measure the output voltage?], thats perfect and you can use them.
All the best,
Frank DD4WH
Hi Frank,
Many thanks for your fast reply. :)
No I haven’t heard at the sound. I have only checked the amplitude-difference to understand if the filter works. Even I haven’t checked higher frequencies because I`m interested only in very low frequencies (below ca. 350Hz).
Nevertheless I have updated the test-sketch now to verify if I`m hearing also distortions or similar:
New is:
Sound to headphones, to hear what’s going on and
Notefreq, to see which fundamental is detected..
//01 Notefreq1 after biquad1
AudioAmplifier           amp1;           //xy=262,224
AudioFilterBiquad        biquad1; //xy=444,223
AudioOutputI2S           i2s2;           //xy=695,161
AudioAnalyzePeak         peak1;          //xy=698,231
AudioAnalyzeNoteFrequency notefreq1;      //xy=706,305
AudioConnection          patchCord3(biquad1, 0, i2s2, 0);
AudioConnection          patchCord4(biquad1, 0, i2s2, 1);
AudioConnection          patchCord5(biquad1, peak1);
AudioConnection          patchCord6(biquad1, notefreq1);
//02 Notefreq1 after amp1
AudioConnection          patchCord3(amp1, notefreq1);
AudioConnection          patchCord4(biquad1, 0, i2s2, 0);
AudioConnection          patchCord5(biquad1, 0, i2s2, 1);
AudioConnection          patchCord6(biquad1, peak1);
//03 Two filter: Biquad2 and Biquad1. Notefreq1 after Biquad2
AudioFilterBiquad        biquad2; //xy=399,224
AudioFilterBiquad        biquad1; //xy=527,171
AudioConnection          patchCord2(amp1, biquad2);
AudioConnection          patchCord3(biquad2, biquad1);
AudioConnection          patchCord4(biquad2, notefreq1);
AudioConnection          patchCord5(biquad1, 0, i2s2, 0);
AudioConnection          patchCord6(biquad1, 0, i2s2, 1);
AudioConnection          patchCord7(biquad1, peak1);
float C = 65.40;
float CIS = 69.29;
float D = 73.41;
float GIS = 103.82;
float A = 110;
float AIS = 116.54;
  AudioMemory(30);
  //Hearphone Out
  sgtl5000_1.volume(0.6);
  //Hearphone Out
  // MicIn
  //MicIn
  notefreq1.begin(.15);
    // Filter
    //biquad1.setLowpass(0, 400, 0.707);
     biquad2.setHighpass(0, 60, 1);
     biquad2.setHighpass(1, 60, 0.707);
     biquad2.setHighpass(2, 60, 1);
     biquad2.setHighpass(3, 60, 0.707);
     // Filter
     biquad1.setBandpass(0, CIS, 10);
     biquad1.setBandpass(1, CIS, 5);
     biquad1.setBandpass(2, CIS, 10);
     biquad1.setBandpass(3, CIS, 5);
     // Filter
       if (msecs > 100) {
          // read back fundamental frequency
          if (notefreq1.available()  ) {
          int cpuusage = AudioProcessorUsageMax();
          float note1 = notefreq1.read();
          float prob1 = notefreq1.probability();
          Serial.printf("CPUusage1: %i | Note1: %3.2f | Probability1: %.2f\n", cpuusage, note1, prob1);
          if (peak1.available() ) {//only Mono needed.
          msecs = 0;
Result:
I couldn`t hear any distortions or ringing.
But what I have heard is the amplification of cut off frequency.
Example:
Filtered note = CIS
Headphones connected to headphone-out (Teensy AudioBoard).
Play CIS (69.29Hz) with my stereo.
The tone is recorded via microphone (MicIn) and I can hear it very well in headphones.
After stopping playing, I´m hearing the same tone but very silent in the background.
When I´m knocking on the table (or make some interruptive noise), this ‘filtered tone loop’ stops (not every time) and I´m hearing silence.
To solve it I have changed the filter parameters as follows:
// Filter
This settings (actually) works well for my project.
BR
