I have a question about the built in RTC feature of the Teensy 3.2.
Is it supposed to maintain the time when not powered up?
I soldered in a 32.768 crystal, and attached a 2025 battery to vbat and gnd.
I'm using the same initial setup for the RTC that is floating around in here.
I have a remote and an IR receiver that I use to set the time with.
On each button press, I increment the clock by 10 seconds (+-).
Watching the serial output, I have a simple serial out in the loop() to see the time change.
Here is where I'm not sure what I'm supposed to expect.
When I set the time with the remote, it changes the output time to the serial.
When I unplug the USB to the teensy (the only power I was using).. wait about 10 seconds or so.. and plug it back in.
The time picks up exactly where it left off. Not the 10 seconds additional that I waited.
What should have happened? should it have kept proper time? Or just restored the "powered down" time?
See bellow for a snippet of the serial output. I ran the sketch, unplugged the usb, waited 10 seconds, and plugged it back in.
If it's supposed to keep time when unplugged.. where should I look for the problem?
Is it the crystal? bad solder job (dang that thing is tiny to solder).
P.S. As expected, if I remove the 2025 battery, and do the same as above, the "clock" get reset to the compile time. So.. I know at least that the batter must be doing something right.
*edit* I put my voltage tester to see if the pins of the crystal are correctly linked to the pins on the teensy, and they both seem to map out correctly. Shows a good connection on them both to the pins on the CPU itself.
Cheers
if (timeStatus() != timeSet)
Serial.println("ERR: Unable to sync with RTC");
Serial.println("RTC Has set the system time");
time_t tNow = now();
tNow += TIME_INCREASE_SECONDS * (_buttonRepeatCount > TIME_MULTIPLIER_REPEAT_THRESHOLD ? TIME_INCREASE_MULTIPLIER : 1);
Teensy3Clock.set(tNow);
setTime(tNow);
Serial.print(hour()); Serial.print(':'); Serial.print(minute()); Serial.print(':'); Serial.print(second());
16:13:43
16:13:44
16:13:44
16:13:45
16:13:45
--- exit ---
Exception in thread rx:
Traceback (most recent call last):
File "/usr/lib/python2.7/threading.py", line 801, in __bootstrap_inner
self.run()
File "/usr/lib/python2.7/threading.py", line 754, in run
self.__target(*self.__args, **self.__kwargs)
File "/home/spowell/.local/lib/python2.7/site-packages/serial/tools/miniterm.py", line 445, in reader
data = self.serial.read(self.serial.in_waiting or 1)
File "/home/spowell/.local/lib/python2.7/site-packages/serial/serialposix.py", line 501, in read
'device reports readiness to read but returned no data '
SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
$ pio device monitor
--- Miniterm on /dev/ttyACM0 250000,8,N,1 ---
--- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
Setup RTC Has set the system time
16:13:45
16:13:45
16:13:46
16:13:46
16:13:47
Cheers
