Page 2 of 2 FirstFirst 1 2
Results 26 to 46 of 46
Thread: Problems w/ Tone.h and MusicWithoutDelay.h Compiling
  1. #26
    13,454
    @nathanSuperStar- I connected a Teensy Touch pin that uses Teensy's [LC, 3.2, 3.6] single wire touchRead() as a button. I just started using that because it works well and easier than making a real button to push. I saw you had a SensorToButton.h class - Being a 'c' guy too lazy to make my own class layout - I rewrote that to accommodate the capacitive nature and use of that touchRead() function and it works to encapsulate what I was having to do manually in the earlier test code - it does work with that library wasPressed and wasReleased so I left them and it works in the song_with_MOD sketch.
    Can you tell me if I should leave it pointing you with MIT license as it stands? :: TouchButton_src.zip
    I just looked at IDE's verbose - there are many screens of ' warning: narrowing conversion':
    "T:\\arduino_1.8.6_TYC\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=143 -DARDUINO=10806 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IT:\\TEMP\\arduino_build_489881/pch" "-IT:\\arduino_1.8.6_TYC\\hardware\\teensy\\avr\\cor es\\teensy3" "-It:\\tcode\\libraries\\TouchButton\\src" "-It:\\tcode\\libraries\\MusicWithoutDelay\\src" "T:\\TEMP\\arduino_build_489881\\sketch\\TchSong_w ith_MOD.ino.cpp" -o "T:\\TEMP\\arduino_build_489881\\sketch\\TchSong_w ith_MOD.ino.cpp.o"
    In file included from t:\tcode\libraries\MusicWithoutDelay\src/synth.h:13:0,
    from t:\tcode\libraries\MusicWithoutDelay\src/MusicWithoutDelay.h:32,
    from T:\tCode\TouchRead\TchSong_with_MOD\TchSong_with_M OD.ino:29:
    t:\tcode\libraries\MusicWithoutDelay\src/tables.h:289:1: warning: narrowing conversion of '-3' from 'int' to 'char' inside { } [-Wnarrowing]
    t:\tcode\libraries\MusicWithoutDelay\src/tables.h:289:1: warning: narrowing conversion of '-6' from 'int' to 'char' inside { } [-Wnarrowing]
    t:\tcode\libraries\MusicWithoutDelay\src/tables.h:289:1: warning: narrowing conversion of '-9' from 'int' to 'char' inside { } [-Wnarrowing]
  2. #27
    13,454
    Paul or @nathanSuperStar: Just occurred to me I push the PWM pin 5 directly to the PJRC Prop_LC shield AMP without the CAPs and 1K ohm resistor as pictured.
    Does that matter critically or helpfully? Or does that PWM output provide the kind of signal the AMP is expecting?
  3. #28
    23,738
    TL;DR = should be ok.
    But it's not quite the expected signal. The amplitude is pretty high, so you'll probably get a very loud sound from the speaker. The prop shield does have a low-pass filter, but it was designed with the 44.1 kHz sample rate of the audio library. This code uses 20 kHz, so you would probably want the filter to be a little lower.
    These minor differences are probably ok, assuming you're ok with the output so loud. Quite a lot of the 20 kHz will get to the speaker, which is probably ok for almost any ordinary speaker. Most speakers can't respond that high, and humans can't hear that high even if the speaker is able to reproduce it.
    If you send the output to a stereo system, the strong presence of 20 kHz PWM carrier might be an issue.
  4. #29
    23,738
    Quote Originally Posted by nathanSuperStar View Post
    Yeah, the code on Github is a bit behind, so I had to manually enter the Teensy support because I had new code on my laptop for the volume control.
    Oh, I should have looked more closely. Been fiddling with Arduino bugs the last few days...
  5. #30
    13,454
    Thanks Paul. Volume is okay, not so loud - and with .setVolume() I have been turning it down as it is just repetitious as I play with touchRead() button - which annoys my wife … like with Talkie queue. I'll look to add the filtering.
    "TL;DR" : not seen that in a while … funny … twice in the last week and on short questions too …
  6. #31
    23,738
    Something else to keep in mind is the PWM waveform and especially the pulsing class-D output of the prop shield amplifier can play havoc with capacitive sensing if the wires get too close.
  7. #32
    13,454
    I was wondering if noise might bite me at some point - so far I have two buttons … a pair of resistors poking up from a female header. will keep that in mind as I expand.
  8. #33
    Being a 'c' guy too lazy to make my own class layout - I rewrote that to accommodate the capacitive nature.
    1. Why rewrite the whole class when you can use SensorToButton's Capacitive example? You just need a big resistor, like a 1 Mega ohms between two pins. Doesn't Teensy's touchRead do the same thing? My SensorToButton library will work as long as there is a continous stream of data to read in the loop().
    2. It would be nice if you point the library, with the MIT license, to me
    3. Yeah, I got those warnings too :\ These warnings keep catching up to me somehow. When I compile with Arduino Uno, I get no warnings, but when I use the Teensy, I get narrow warning. But I fixed it now. I'll release it soon.
    It really depends...you may get less volume. I personally don't even have the resistor connected in my circuit because I wanted more volume. Also my library sounds pretty nice on Paul's Teensy
  9. #34
    13,454
    1.> As noted the alternate lib { I was planning to do already if just for practice }: " uses Teensy's [LC, 3.2, 3.6] single wire touchRead() as a button " - I just discovered it and would point to doc's but I don't find any but the PJRC touch.c code.
    With your post - the second 'read(uint16_t reading)' makes sense now to send in an analogRead() or touchRead() value in combination with threshold. I saw the digitalRead() in 'read( void )' and was put off. That explains debounceIt() too.
    The Teensy MCU's hardware ties a 'CAP' to a pin internally - and a simple wire/resistor, or just touching the pin's PCB metal with no external second wire to a surface. It has a library for that style sensing - though not debounced I suppose like the separate button library - I never looked.
    I'm extending and customizing it to internalize/support for calibrating it - last thing I did was to internalize counting 'repeat rate' along the lines of that done in your sample 'song_with_mod' as I was capturing repeats in my first sample - which is why I was thinking of making a library. The Teensys that have those Touch pins have 11 or 12 of them - for ~20 bytes each I could make one class to support them all as an array - there is interrupt support but I haven't gotten as far as figuring that out yet.
    2.> this changes my view of the SensorToButton lib 'Used for sensors' that I didn't get from the readme - will see what I end up with on my changes.
    3.> I'll look for an update for the verbose cleanup
  10. #35
    Dec 2013
    East Stroudsburg PA.
    300
    My main goal was to be able to play simple chiptunes
    Sounds interesting, I need to play with this library soon.
  11. #36
    23,738
    Click File > Preference and use the drop-down list to turn on all warnings. Then you'll see them!
  12. #37
    13,454
    re the comment from @nathanSuperStar
    Just compiled BASIC for UNO and no warnings - when T_LC selected there are a stream of them, so it is the tool chain catching something that passes UNO types in some fashion.
  13. #38
    13,454
    I made a small change under Paul's #ifdef code { Pull Request } that allows code to provide any Teensy PWM pin. Paul's conversion works on the T_LC I hooked up - but is hardcoded to PIN_3 - and still defaults to that pin.
    Since there is a .begin( ###, … ) function for the two AVR pins I just took/stored that as a PIN# for the calls to :: analogWriteFrequency and analogWrite.
    @Nathan - maybe this was found? In tables.h Verbose Warnings the issue is "char" versus "int8_t"
    If these char are made int8_t [like the last in this list] the warnings go away - assuming that is defined for UNO::
    line 31 >> const PROGMEM char SinTable[]=
    line 291 >> const PROGMEM char TriangleTable[]=
    line 551 >> const PROGMEM char SquareTable[]=
    line 810 >> const PROGMEM char SawTable[]=
    line 1069 >> const PROGMEM char RampTable[]=
    line 1328 >> const PROGMEM int8_t NoiseTable[]=
  14. #39
    Yeah, I figured out the narrowing warnings. Also, changing the pin is a nice feature to add.
    Sorry I didn't update the github code yet. I was adding support for other boards to my library. I have created stereo support on the Arduino Uno and Arduino Mega, and teensy. Also, I've added support to the atmega32u4 chips, such as the pro micro and the teensy 2.0; that's for Paul
    Since you made a feature request, I guess I could change a few things to allow 4 channel Support on the teensy 3.+ and LC.
    I'll have it up on github in about 4-5 hours.
  15. #40
    13,454
    Nice to see that and other features added. I was wondering how the [4] instances of MusicWD shared info when I found the global :: globalInstrument.
    Then wondered why Teensy was stuck on pin3 and saw the opportunity to expand that in that similar way.
  16. #41
    MWD v3.5.0
    I've updated the library now, and I like the acronym "MWD"
    Here it is: MWD v3.5.0
    I've made the readMe easier, so it should be straightforward on what to do(with the addition of the Table of Contents)
    Since there is a .begin( ###, ) function for the two AVR pins I just took/stored that as a PIN# for the calls to :: analogWriteFrequency and analogWrite.
    There's that Multi-stereo option you wanted @Defragster. You can choose whichever pin you want, and can mix the audio on any pin. Pretty much, the possibilities are endless. Also, I figured out how to crank 30 simultaneous notes at the same time
    If you want to see the true power of polyphony, you have to use this sketch
    and have to modify the maxVoice settings in src/synth.cpp.
    Instructions on how to do that are in the read.me
    I must say, I'm really impressed by the Teensy
  17. #42
    Lightbulb Which pins connected to Teensy Audio Shield?
    Just a question...
    Which pins are connected to the Teensy's PT8211 audio kit? And which pins are connected to the Teensy Audio Shield?
    I'm asking, because I want to keep my project clean from stray jumper wires
    And since my Library allows us to change the PWM pin, it seems like it would be possible.
  18. #43
    13,454
    It is near the bottom:
    Technical Details
    PT8211 Datasheet.
    Signal Teensy Pin PT8211 Pin
    BCK 9 1
    DIN 22 3
    WS 23 2
    +3.3V 3.3V 5
    GND GND 4
  19. #44
    13,454
    Indeed - Teensy never ceases to amaze!
    On T_LC with Prop_LC had a sketch using my touchRead based buttons working with 5 buttons [pins 15-19] - using the new V3.5.0 of MWD I have a voice on all 5 buttons!
    When I went to the linked polyphony sketch I get NOISE and trying the SensorToButton btn.read( touchRead ) failed to get button press and importing my working replacement was no better? In fact executing the .read() on either caused a loss of USB "### hz" prints - but the noise persisted. I don't have a POT wired to I removed volume control. But starting at a LOW volume the HUMMMM Noise is the same loudness?
    <edit>: Nice add of the extra voices per channel!
    Note - the Teensy 3.x and LC can PWM 20 Khz at 11 bits - if I'm reading the table right.
  20. #45
    1) the reason why the sound is noisy is because the more note-polyphony, the more bits you are trying to squash together. To fix this, you just have to play at a lower volume(using a potentiometer is probably best for finding this volume). Though, you could use the Serial monitor and decrease the volume.
    2) SensorToButton works for me. Maybe the extra note-polyphony is interfering the Touch sense feature? A regular button works well
    3) Thanks, the extra voices per channel was hard to implement because adding mixed samples to the right output pin can take time on the timer routine. In fact, I thought of using a nested for loop; this only made things worse because the teensy started playing at a higher octave.
    So I decided to use two arrays at the beginning of initialization, and I determined which buzzers are using the same output. So when the buzzers play at runtime, the teensy can play at a much faster rate because the mixed sample's outputs have been predetermined.
    It took a while for me to figure it out, but I'm glad it works without bugs.... For now 😅.
  21. #46
    I've updated the code, so now it should auto-clip the noise at a higher volume.
    Let me know if it works.
    Also, if anyone has a Teensy 2.0, could you please test my library on it? The output is on pin A9 according to the chart
