Page 8 of 10 FirstFirst ... 6 7 8 9 10 LastLast
Results 176 to 200 of 235
Thread: Compiling Teensy Sketches with VisualCode (Win10)
  1. #176
    Jan 2015
    France
    117
    I notice a strange behaviour of VSC today, not related to VT. Maybe someone have the solution :
    When I use Shift-Alt-F to intend code, it wipe the code all out. Previously it work OK. Does any one have this behaviour.
    I remind that there was an update recently of VSC C++ plug-in. Maybe is this related to it.
    Thank you,
    Manu
    Hum, hum, it's look like it's related to only one of my file. I have to inquire about this !
  2. #177
    1,167
    Actually, they had some changes in the auto format feature in the current insider version.
    Add the vcFormat option to C_Cpp.formatting (with C_Cpp.vcFormat.* options) to enable VS-style formatting (instead of clang-format formatting). #657
    There also are a couple of new issues logged regarding formatting logged: https://github.com/microsoft/vscode-cpptools/issues
    I'm using the autoformater quite heavily but didn't notice any strange things so far. But, I'm using clang_format files to define the formatting style maybe that makes a difference.
  3. #178
    Jan 2015
    France
    117
    It's odd. If I compile the project it's OK. So I don't think it's a typo error in the main.cpp file.
    But if I intend the main.cpp file all goes wrong and then I can't compile anymore...
    I'll wait a fix from cpptool plugin :-(
  4. #179
    Jan 2015
    France
    117
    In VT, I notice that when you generate "c_cpp_properties.json" you use different formats for files paths.
    One is (for example) :
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3",
    Another is (need to be manually edited to operate":
    "D:/Mes%20documents/Arduino/libraries/TeensyTimerTool/**",
    Where it can be :
    "D:\\Mes documents\\Arduino\\libraries\\TeensyTimerTool\\** ",
  5. #180
    1,167
    Yes, that's true. Originally I started with backslashes as path separator. But since vsCode also accepts a forward slash as separator I switched to "/". Obviously I didn't yet switch all occurrences. But as mentioned vsCode accepts both so this is just cosmetic.
    Regarding your issue with the vsCode auto formatter. Just to make sure: you didn't install any formatting extension which might generate the problem?
    I just checked my installation: I'm running the c/c++ extension v0.30.0-insiders.
    In the settings I changed the setting:
    "C_Cpp: Clang_format_style" to file. With this setting the formatter looks for a file named '.clang-format' in your project base folder (don't miss the starting dot) and uses it for the formatting style. In the .clang-format file you can set your prefered formatting style in deep detail. The available options are documented here: https://clang.llvm.org/docs/ClangFor...leOptions.html
    If you want to try, I zipped and attached my .clang-format to the post. Maybe this tames your broken formatter.
    Attached Files Attached Files
  6. #181
    Jan 2015
    France
    117
    Thank you Luni for the link to cpp issues.
    This one is the one to use to solve the problem :
    https://github.com/microsoft/vscode-...ls/issues/5914
    One have to change "C_Cpp.clang_format_style" to "Emulated Visual Studio" (set to 'file' by default)
  7. #182
    1,167
    Perfect, here it currently it works without problems. Good to know how to fix it if the problem shows up later....
    I reread your question and found that I overlooked your issue with the spaces in c/c++properties.json.
    Does that mean that the original setting written by vsTeensy didn't work and you had to manually change it? Or did you just try to "translate" it to the backslash notation?
  8. #183
    Also using PlatformIO, (which also has infrastructure for unit tests development BTW), why reinventing this, did I miss something there ?
    https://platformio.org/install/ide?install=vscode
  9. #184
    1,167
    PIO is nice of course. I'm quite sure that PIO will be the dominant development system for the Arduino world sooner or later. But it just doesn't fit my needs. And presumably it doesn't fit the needs of those few using it besides me.
    This was developed at a time when building for Teensies with PIO was, lets say, interesting :-)
    Anyway, for me the main difference between PIO and vsTeensy is its footprint. To me, PIO feels like a big oil tanker while vsTeensy is more like a small and easy to steer motor boat. Nothing to install, it generates stand alone projects, depending on gnu make and gcc only. It isn't needed at all once the project is generated and I can easily adopt it to my changing needs.
    Always good if there are options...
  10. #185
    2,769
    Quote Originally Posted by fab672000 View Post
    Yes, IMO, you are missing a fundamental point.
    VisualTeensy generates a Makefile environment, that you can easily modify, adapt to your own make preferences. I do that continuously. Yes, @luni adapts code to user desires, but what remains relevant is a functioning make file, some json file.
    Now, Platformio was introduced in2015 and VisualTeensy in 2018, because a lot of us wanted to use Makefiles. The fact that VisualTeensy is still popular should be encouraging for @luni.
    Finally, a lot of code presented in this forum is grown out of personal interest but shared with others.
  11. #186
    Jan 2015
    France
    117
    It mean that "Mes%20documents" need to become "Mes documents" to operate without warning at compilation.
    If I don't change this, the project can still compil, but claim for an error about teensytimertool location.
    So I have to change the path to either :
    "D:/Mes documents/Arduino/libraries/TeensyTimerTool/**",
    or
    so VSC is happy and compile without warning.
  12. #187
    You should probably try it now, it is updated regularly and very powerful, what specifically does not fit your need?
    PIO This was developed at a time when building for Teensies with PIO was, lets say, interesting :-)
    Now that explains better why you started this, but I think new users should be aware this is fairly ancient material then and look first at PIO.
    You may miss the important points there though, this is a *consolidated*, powerful yet simple to use IDE, that allows you to develop for various platforms and languages all in one place with a very advanced concept of extensions.
    It is actually way simpler to use IMO than VS2019 as an example.
    Anyway, thanks for the feedback.
  13. #188
    Makefiles are evil to me, what do you specifically need to change all the time directly in the Makefile that you could not do elsewhere ?
    I would encourage luni to contribute to bigger tools in the community, and by all means also support that tool if it still has afficionados.
  14. #189
    1,167
    or
    Thanks for spotting that. Since my path doesn't contain spaces I never stumbled over it.
    I just released 0.9.8.2 on GitHub which should fix it. https://github.com/luni64/VisualTeensy/releases/
  15. #190
    Jan 2015
    France
    117
    Will test it soon and report.
    Thank you
  16. #191
    Jan 2015
    France
    117
    Tested OK today,
    Thank you Luni.
    Did you ever play with GIT function in VScode ? I can't make it operate with my Synology NAS GIT server. Does it need SSH or only user/password ?
  17. #192
    Feb 2020
    7
    luni,
    Thanks for Visual Teensy, great stuff for managing the libraries.
    First, I download 9.8.2, but application states its 9.8.1 at the top. Hopefully it's not me.
    But my issue is that Teensy Loader won't download the hex file from VSCode.
    I get this error in VSCode
    User code built and linked to libraries
    [HEX] .vsteensy/build/T41_POE.hex
    [LST] .vsteensy/build/T41_POE.lst
    Sucessfully built project
    Teensy Loader could not find the file T41_POE
    quitmake: *** [makefile:164: upload] Error 1
    The terminal process "C:\windows\System32\WindowsPowerShell\v1.0\powershell.exe -Command C:/Users/pc/GitHub/VisualTeensy_v0_9_8_2/make.exe upload -j -Otarget" terminated with exit code: 1.
    Then in Teensy Loader verbose, I'm seeing the path\name with an extra comma + space added in front of the file name, and perhaps a slash change?
    16:17:45.063 (post_compile 9): Begin, version=1.53, high-res time
    16:17:45.065 (loader): remote connection 3536 opened
    16:17:45.065 (post_compile 9): Sending command: comment: Teensyduino 1.53 - WINDOWS (teensy_post_compile)
    16:17:45.066 (loader): remote cmd from 3536: "comment: Teensyduino 1.53 - WINDOWS (teensy_post_compile)"
    16:17:45.066 (loader): remote cmd from 3536: "status"
    16:17:45.074 (post_compile 9): Status: 0, 0, 0, 5, 2, 0, .vsteensy/build\, T41_POE.hex
    16:17:45.074 (post_compile 9): Sending command: dir:.vsteensy/build\
    16:17:45.074 (loader): remote cmd from 3536: "dir:.vsteensy/build\"
    16:17:45.075 (loader): remote cmd from 3536: "file:T41_POE.hex"
    16:17:45.076 (post_compile 9): Sending command: file:T41_POE.hex
    16:17:45.078 (post_compile 9): Teensy Loader could not find the file T41_POE
    16:17:45.078 (post_compile 9): quit
    16:17:45.079 (loader): remote connection 3536 closed
    If I just go to teensy loader, pick the hex file and upload, it works. The file is in the right folder, with the right name.
    Do you know where the comma+space are coming from?
  18. #193
    1,167
    That's interesting. I don't use the loader much (I prefer TyCommander). So, it might well be that a bug sneaked into the last release. If you post the generated makefile I can have a look.
    No, I simply forgot to update the version
  19. #194
    1,167
    I just gave it a quick try. Works without issue here.
    Can you please also remove the @ from the upload command in the makefile to see what it actually spits out:
Name:	Anmerkung 2020-09-02 070907.jpg
    I get a perfectly normal
    "C:\Arduino\arduino-1.8.12\hardware\tools/teensy_post_compile" -test -file=T41_POE -path=.vsteensy/build -tools="C:\Arduino\arduino-1.8.12\hardware\tools" -board=TEENSY41 -reboot
  20. #195
    Feb 2020
    7
    Here is the makefile, after I removed the @ on line 164
    # Generated by VisualTeensy (https://github.com/luni64/VisualTeensy)
    # Board              Teensy 4.1
    # USB Type           Serial
    # CPU Speed          600 MHz
    # Optimize           Faster
    # Keyboard Layout    US English
    # 9/1/2020 4:09 PM
    SHELL            := cmd.exe
    export SHELL
    TARGET_NAME      := T41_POECan
    BOARD_ID         := TEENSY41
    MCU              := imxrt1062
    LIBS_SHARED_BASE := C:\Users\pc\OneDrive\GitHub\Arduino\libraries
    LIBS_SHARED      :=
    LIBS_LOCAL_BASE  := lib
    LIBS_LOCAL       := Adafruit_BusIO Adafruit_GFX_Library Adafruit_SSD1306 FlexCAN_T4 FNET NativeEthernet QuadEncoder SD SPI Time U8g2 Wire
    CORE_BASE        := C:\PROGRA~2\Arduino\hardware\teensy\avr\cores\teensy4
    GCC_BASE         := C:\PROGRA~2\Arduino\hardware\tools\arm\bin
    UPL_PJRC_B       := C:\PROGRA~2\Arduino\hardware\tools
    # Flags and Defines
    FLAGS_CPU   := -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16
    FLAGS_OPT   := -O2
    FLAGS_COM   := -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD
    FLAGS_LSP   :=
    FLAGS_CPP   := -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing
    FLAGS_C     :=
    FLAGS_S     := -x assembler-with-cpp
    FLAGS_LD    := -Wl,--print-memory-usage,--gc-sections,--relax,--defsym=__rtc_localtime=$(shell powershell [int](Get-Date -UFormat +%s)[0]) -T$(CORE_BASE)/imxrt1062_t41.ld
    LIBS        := -larm_cortexM7lfsp_math -lm -lstdc++
    DEFINES     := -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO_TEENSY41 -DARDUINO=10807
    DEFINES     += -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH
    CPP_FLAGS   := $(FLAGS_CPU) $(FLAGS_OPT) $(FLAGS_COM) $(DEFINES) $(FLAGS_CPP)
    C_FLAGS     := $(FLAGS_CPU) $(FLAGS_OPT) $(FLAGS_COM) $(DEFINES) $(FLAGS_C)
    S_FLAGS     := $(FLAGS_CPU) $(FLAGS_OPT) $(FLAGS_COM) $(DEFINES) $(FLAGS_S)
    LD_FLAGS    := $(FLAGS_CPU) $(FLAGS_OPT) $(FLAGS_LSP) $(FLAGS_LD)
    AR_FLAGS    := rcs
    # Colors
    COL_CORE    := [38;2;187;206;251m
    COL_LIB     := [38;2;206;244;253m
    COL_SRC     := [38;2;100;149;237m
    COL_LINK    := [38;2;255;255;202m
    COL_ERR     := [38;2;255;159;159m
    COL_OK      := [38;2;179;255;179m
    COL_RESET   := [0m
    # Folders and Files
    USR_SRC     := src
    LIB_SRC     := lib
    CORE_SRC    := $(CORE_BASE)
    BIN         := .vsteensy/build
    USR_BIN     := $(BIN)/src
    CORE_BIN    := $(BIN)/core
    LIB_BIN     := $(BIN)/lib
    CORE_LIB    := $(BIN)/core.a
    TARGET_HEX  := $(BIN)/$(TARGET_NAME).hex
    TARGET_ELF  := $(BIN)/$(TARGET_NAME).elf
    TARGET_LST  := $(BIN)/$(TARGET_NAME).lst
    # BINARIES
    CC          := $(GCC_BASE)/arm-none-eabi-gcc
    CXX         := $(GCC_BASE)/arm-none-eabi-g++
    AR          := $(GCC_BASE)/arm-none-eabi-gcc-ar
    OBJCOPY     := $(GCC_BASE)/arm-none-eabi-objcopy
    SIZE        := $(GCC_BASE)/arm-none-eabi-size
    OBJDUMP     := $(GCC_BASE)/arm-none-eabi-objdump
    UPL_PJRC    := "$(UPL_PJRC_B)/teensy_post_compile" -test -file=$(TARGET_NAME) -path=$(BIN) -tools="$(UPL_PJRC_B)" -board=$(BOARD_ID) -reboot
    UPL_TYCMD   := $(UPL_TYCMD_B)/tyCommanderC upload $(TARGET_HEX) --autostart --wait --multi
    UPL_CLICMD  := $(UPL_CLICMD_B)/teensy_loader_cli -mmcu=$(MCU) -v $(TARGET_HEX)
    UPL_JLINK   := $(UPL_JLINK_B)/jlink -commanderscript .vsteensy/flash.jlink
    # Source and Include Files
    # Recursively create list of source and object files in USR_SRC and CORE_SRC
    # and corresponding subdirectories.
    # The function rwildcard is taken from http://stackoverflow.com/a/12959694)
    rwildcard =$(wildcard $1$2) $(foreach d,$(wildcard $1*),$(call rwildcard,$d/,$2))
    #User Sources -----------------------------------------------------------------
    USR_C_FILES    := $(call rwildcard,$(USR_SRC)/,*.c)
    USR_CPP_FILES  := $(call rwildcard,$(USR_SRC)/,*.cpp)
    USR_S_FILES    := $(call rwildcard,$(USR_SRC)/,*.S)
    USR_OBJ        := $(USR_S_FILES:$(USR_SRC)/%.S=$(USR_BIN)/%.o) $(USR_C_FILES:$(USR_SRC)/%.c=$(USR_BIN)/%.o) $(USR_CPP_FILES:$(USR_SRC)/%.cpp=$(USR_BIN)/%.o)
    # Core library sources --------------------------------------------------------
    CORE_CPP_FILES := $(call rwildcard,$(CORE_SRC)/,*.cpp)
    CORE_C_FILES   := $(call rwildcard,$(CORE_SRC)/,*.c)
    CORE_S_FILES   := $(call rwildcard,$(CORE_SRC)/,*.S)
    CORE_OBJ       := $(CORE_S_FILES:$(CORE_SRC)/%.S=$(CORE_BIN)/%.o) $(CORE_C_FILES:$(CORE_SRC)/%.c=$(CORE_BIN)/%.o) $(CORE_CPP_FILES:$(CORE_SRC)/%.cpp=$(CORE_BIN)/%.o)
    # User library sources  (see) https://github.com/arduino/arduino/wiki/arduino-ide-1.5:-library-specification
    LIB_DIRS_SHARED  := $(foreach d, $(LIBS_SHARED), $(LIBS_SHARED_BASE)/$d/ $(LIBS_SHARED_BASE)/$d/utility/)  # base and /utility
    LIB_DIRS_SHARED  += $(foreach d, $(LIBS_SHARED), $(LIBS_SHARED_BASE)/$d/src/ $(dir $(call rwildcard,$(LIBS_SHARED_BASE)/$d/src/,*/.)))                           # src and all subdirs of base
    LIB_DIRS_LOCAL   := $(foreach d, $(LIBS_LOCAL), $(LIBS_LOCAL_BASE)/$d/ $(LIBS_LOCAL_BASE)/$d/utility/ )    # base and /utility
    LIB_DIRS_LOCAL   += $(foreach d, $(LIBS_LOCAL), $(LIBS_LOCAL_BASE)/$d/src/ $(dir $(call rwildcard,$(LIBS_LOCAL_BASE)/$d/src/,*/.)))                             # src and all subdirs of base
    LIB_CPP_SHARED  := $(foreach d, $(LIB_DIRS_SHARED),$(call wildcard,$d*.cpp))
    LIB_C_SHARED    := $(foreach d, $(LIB_DIRS_SHARED),$(call wildcard,$d*.c))
    LIB_S_SHARED    := $(foreach d, $(LIB_DIRS_SHARED),$(call wildcard,$d*.S))
    LIB_CPP_LOCAL   := $(foreach d, $(LIB_DIRS_LOCAL),$(call wildcard,$d/*.cpp))
    LIB_C_LOCAL     := $(foreach d, $(LIB_DIRS_LOCAL),$(call wildcard,$d/*.c))
    LIB_S_LOCAL     := $(foreach d, $(LIB_DIRS_LOCAL),$(call wildcard,$d/*.S))
    LIB_OBJ         := $(LIB_CPP_SHARED:$(LIBS_SHARED_BASE)/%.cpp=$(LIB_BIN)/%.o)  $(LIB_CPP_LOCAL:$(LIBS_LOCAL_BASE)/%.cpp=$(LIB_BIN)/%.o)
    LIB_OBJ         += $(LIB_C_SHARED:$(LIBS_SHARED_BASE)/%.c=$(LIB_BIN)/%.o)  $(LIB_C_LOCAL:$(LIBS_LOCAL_BASE)/%.c=$(LIB_BIN)/%.o)
    LIB_OBJ         += $(LIB_S_SHARED:$(LIBS_SHARED_BASE)/%.S=$(LIB_BIN)/%.o)  $(LIB_S_LOCAL:$(LIBS_LOCAL_BASE)/%.S=$(LIB_BIN)/%.o)
    # Includes -------------------------------------------------------------
    INCLUDE        := -I./$(USR_SRC) -I$(CORE_SRC)
    INCLUDE        += $(foreach d, $(LIB_DIRS_SHARED), -I$d)
    INCLUDE        += $(foreach d, $(LIB_DIRS_LOCAL), -I$d)
    # Generate directories --------------------------------------------------------
    DIRECTORIES :=  $(sort $(dir $(CORE_OBJ) $(USR_OBJ) $(LIB_OBJ)))
    generateDirs := $(foreach d, $(DIRECTORIES), $(shell if not exist "$d" mkdir "$d"))
    #$(info dirs: $(DIRECTORIES))
    $(info$(COL_RESET))
    # Rules:
    .PHONY: directories all rebuild upload uploadTy uploadCLI clean cleanUser cleanCore
    all:  $(TARGET_LST) $(TARGET_HEX)
    rebuild: cleanUser all
    clean:   cleanUser cleanCore cleanLib
    	@echo $(COL_OK)cleaning done$(COL_RESET)
    upload: all
    	$(UPL_PJRC)
    uploadTy: all
    	@$(UPL_TYCMD)
    uploadCLI: all
    	@$(UPL_CLICMD)
    uploadJLink: all
    	@$(UPL_JLINK)
    # Core library ----------------------------------------------------------------
    $(CORE_BIN)/%.o: $(CORE_SRC)/%.S
    	@echo $(COL_CORE)CORE [ASM] $(notdir $<) $(COL_ERR)
    	@"$(CC)" $(S_FLAGS) $(INCLUDE) -o $@ -c $<
    $(CORE_BIN)/%.o: $(CORE_SRC)/%.c
    	@echo $(COL_CORE)CORE [CC]  $(notdir $<) $(COL_ERR)
    	@"$(CC)" $(C_FLAGS) $(INCLUDE) -o $@ -c $<
    $(CORE_BIN)/%.o: $(CORE_SRC)/%.cpp
    	@echo $(COL_CORE)CORE [CPP] $(notdir $<) $(COL_ERR)
    	@"$(CXX)" $(CPP_FLAGS) $(INCLUDE) -o $@ -c $<
    $(CORE_LIB) : $(CORE_OBJ)
    	@echo $(COL_LINK)CORE [AR]  $@ $(COL_ERR)
    	@$(AR) $(AR_FLAGS) $@ $^
    	@echo $(COL_OK)Teensy core built successfully &&echo.
    # Shared Libraries ------------------------------------------------------------
    $(LIB_BIN)/%.o: $(LIBS_SHARED_BASE)/%.S
    	@echo $(COL_LIB)LIB  [ASM] $(notdir $<) $(COL_ERR)
    $(LIB_BIN)/%.o: $(LIBS_SHARED_BASE)/%.cpp
    	@echo $(COL_LIB)LIB  [CPP] $(notdir $<) $(COL_ERR)
    	@echo $(COL_LIB)LIB  [CC]  $(notdir $<) $(COL_ERR)
    # Local Libraries -------------------------------------------------------------
    $(LIB_BIN)/%.o: $(LIBS_LOCAL_BASE)/%.S
    $(LIB_BIN)/%.o: $(LIBS_LOCAL_BASE)/%.cpp
    # Handle user sources ---------------------------------------------------------
    $(USR_BIN)/%.o: $(USR_SRC)/%.S
    	@echo $(COL_SRC)USER [ASM] $< $(COL_ERR)
    $(USR_BIN)/%.o: $(USR_SRC)/%.c
    	@echo $(COL_SRC)USER [CC]  $(notdir $<) $(COL_ERR)
    	@"$(CC)" $(C_FLAGS) $(INCLUDE) -o "$@" -c $<
    $(USR_BIN)/%.o: $(USR_SRC)/%.cpp
    	@echo $(COL_SRC)USER [CPP] $(notdir $<) $(COL_ERR)
    	@"$(CXX)" $(CPP_FLAGS) $(INCLUDE) -o "$@" -c $<
    # Linking ---------------------------------------------------------------------
    $(TARGET_ELF): $(CORE_LIB) $(LIB_OBJ) $(USR_OBJ)
    	@echo $(COL_LINK)
    	@echo [LD]  $@ $(COL_ERR)
    	@$(CC) $(LD_FLAGS) -o "$@" $(USR_OBJ) $(LIB_OBJ) $(CORE_LIB) $(LIBS)
    	@echo $(COL_OK)User code built and linked to libraries &&echo.
    %.lst: %.elf
    	@echo $(COL_LINK)
    	@echo [LST] $@ $(COL_ERR)
    	@$(OBJDUMP) -d -S --demangle --no-show-raw-insn --syms "$<"  > "$@"
    	@echo $(COL_OK)Sucessfully built project$(COL_RESET) &&echo.
    %.hex: %.elf
    	@echo $(COL_LINK)[HEX] $@
    #	@$(SIZE) "$<"
    	@$(OBJCOPY) -O ihex -R.eeprom "$<" "$@"
    # Cleaning --------------------------------------------------------------------
    cleanUser:
    	@echo $(COL_LINK)Cleaning user binaries...$(COL_RESET)
    	@if exist $(USR_BIN) rd /s/q "$(USR_BIN)"
    	@if exist "$(TARGET_LST)" del $(subst /,\,$(TARGET_LST))
    cleanCore:
    	@echo $(COL_LINK)Cleaning core binaries...$(COL_RESET)
    	@if exist $(CORE_BIN) rd /s/q "$(CORE_BIN)"
    	@if exist $(CORE_LIB) del  $(subst /,\,$(CORE_LIB))
    cleanLib:
    	@echo $(COL_LINK)Cleaning user library binaries...$(COL_RESET)
    	@if exist $(LIB_BIN) rd /s/q "$(LIB_BIN)"
    # compiler generated dependency info ------------------------------------------
    -include $(CORE_OBJ:.o=.d)
    -include $(USR_OBJ:.o=.d)
    -include $(LIB_OBJ:.o=.d)
    clean & build, I get this
    [LD]  .vsteensy/build/T41_POECan.elf
    Memory region         Used Size  Region Size  %age Used
                ITCM:         96 KB       512 KB     18.75%
                DTCM:       67328 B       512 KB     12.84%
                 RAM:       12416 B       512 KB      2.37%
               FLASH:      121800 B      7936 KB      1.50%
                ERAM:          0 GB        16 MB      0.00%
    [HEX] .vsteensy/build/T41_POECan.hex
    [LST] .vsteensy/build/T41_POECan.lst
    "C:\PROGRA~2\Arduino\hardware\tools/teensy_post_compile" -test -file=T41_POECan -path=.vsteensy/build -tools="C:\PROGRA~2\Arduino\hardware\tools" -board=TEENSY41 -reboot
    Teensy Loader could not find the file T41_POECan
    The terminal process "C:\windows\System32\WindowsPowerShell\v1.0\powershell.exe -Command C:/Users/pc/OneDrive/GitHub/VisualTeensy_v0_9_8_2/make.exe upload -j -Otarget" terminated with exit code: 1.
    09:39:42.128 (post_compile 20): Begin, version=1.53, high-res time
    09:39:42.129 (loader): remote connection 2900 opened
    09:39:42.134 (loader): remote cmd from 2900: "comment: Teensyduino 1.53 - WINDOWS (teensy_post_compile)"
    09:39:42.134 (post_compile 20): Sending command: comment: Teensyduino 1.53 - WINDOWS (teensy_post_compile)
    09:39:42.139 (loader): remote cmd from 2900: "status"
    09:39:42.149 (loader): remote cmd from 2900: "dir:.vsteensy/build\"
    09:39:42.150 (post_compile 20): Status: 0, 1, 0, 15, 5, 0, .vsteensy/build\, T41_POECan.hex
    09:39:42.150 (post_compile 20): Sending command: dir:.vsteensy/build\
    09:39:42.157 (loader): remote cmd from 2900: "file:T41_POECan.hex"
    09:39:42.157 (post_compile 20): Sending command: file:T41_POECan.hex
    09:39:42.164 (post_compile 20): Teensy Loader could not find the file T41_POECan
    09:39:42.164 (post_compile 20): quit
    09:39:42.211 (loader): remote connection 2900 closed
    Thanks for looking into this.
  21. #196
    2,769
    Not sure if 'C:\PROGRA~2' is always good.
    Try to use the full directory name, maybe place Arduino system in a root directory without a space.
  22. #197
    1,167
    Thanks, I can reproduce this with your settings. Strange thing, I'll have a look now.
    Unfortunately 'make' gets absolutely confused if it works on a path with spaces. On the other hand the default installation path of Arduino is in a path with spaces. So, VisualTeensy converts the path to the old 8+3 nomenclature. Since this conversion is done by a Windows call I assume that it is always correct. And I didn't have issues so far...
  23. #198
    Feb 2020
    7
    So I rebooted the laptop, now it's happy with Teensy Loader.
    Interesting, the filename still has the comma+space in verbose
    11:49:20.796 (post_compile 1): Begin, version=1.53, high-res time, perhaps not an issue.
    11:49:23.072 (loader): Teensy Loader 1.53, begin program
    11:49:23.217 (loader): File "T41_POECan.hex". 121800 bytes, 1% used
    11:49:23.242 (loader): Listening for remote control on port 3149
    11:49:23.242 (loader): initialized, showing main window
    11:49:23.343 (loader): remote connection 1240 opened
    11:49:23.345 (post_compile 1): Sending command: comment: Teensyduino 1.53 - WINDOWS (teensy_post_compile)
    11:49:23.345 (loader): remote cmd from 1240: "comment: Teensyduino 1.53 - WINDOWS (teensy_post_compile)"
    11:49:23.345 (loader): remote cmd from 1240: "status"
    11:49:23.353 (loader): HID/win32:  vid:06CB pid:CD50 ver:0704
    11:49:23.353 (loader): HID/win32:  vid:04F3 pid:29F5 ver:6102
    11:49:23.354 (loader): HID/win32:  vid:8087 pid:0A1E ver:0200
    11:49:23.355 (loader): HID/win32:  vid:256F pid:C652 ver:0102
    11:49:23.356 (loader): HID/win32:  vid:04F3 pid:29F5 ver:6102
    11:49:23.357 (loader): HID/win32:  vid:04F3 pid:29F5 ver:6102
    11:49:23.358 (loader): HID/win32:  vid:256F pid:C652 ver:0102
    11:49:23.359 (loader): HID/win32:  vid:256F pid:C652 ver:0102
    11:49:23.360 (loader): HID/win32:  vid:03F0 pid:0567 ver:0002
    11:49:23.361 (loader): HID/win32:  vid:06CB pid:CD50 ver:0704
    11:49:23.361 (loader): HID/win32:  vid:04F3 pid:29F5 ver:6102
    11:49:23.362 (loader): HID/win32:  vid:256F pid:C652 ver:0102
    11:49:23.363 (loader): HID/win32:  vid:03F0 pid:0567 ver:0002
    11:49:23.364 (loader): HID/win32:  vid:03F0 pid:0567 ver:0002
    11:49:23.365 (loader): HID/win32:  vid:046D pid:C318 ver:5503
    11:49:23.366 (loader): HID/win32:  vid:03F0 pid:0269 ver:0017
    11:49:23.367 (loader): HID/win32:  vid:046D pid:C318 ver:5503
    11:49:23.367 (loader): HID/win32:  vid:03F0 pid:0269 ver:0017
    11:49:23.368 (loader): HID/win32:  vid:045E pid:0000 ver:0000
    11:49:23.369 (loader): HID/win32:  vid:03F0 pid:0269 ver:0017
    11:49:23.369 (loader): HID/win32:  vid:045E pid:0000 ver:0000
    11:49:23.370 (loader): HID/win32:  vid:03F0 pid:0269 ver:0017
    11:49:23.373 (loader): HID/win32:  vid:03F0 pid:0667 ver:0100
    11:49:23.374 (loader): HID/win32:  vid:256F pid:C652 ver:0102
    11:49:23.375 (loader): HID/win32:  vid:BEEF pid:046D ver:0101
    11:49:23.377 (loader): HID/win32:  vid:256F pid:C652 ver:0102
    11:49:23.379 (loader): HID/win32:  vid:04F3 pid:29F5 ver:6102
    11:49:23.380 (post_compile 1): Status: 1, 0, 0, 0, 0, 0, C:\Users\pc\OneDrive\GitHub\T41_POECan\.vsteensy\build\, T41_POECan.hex
    11:49:23.380 (post_compile 1): Sending command: dir:.vsteensy/build\
    11:49:23.380 (loader): remote cmd from 1240: "dir:.vsteensy/build\"
    11:49:23.381 (loader): remote cmd from 1240: "file:T41_POECan.hex"
    11:49:23.381 (post_compile 1): Sending command: file:T41_POECan.hex
    11:49:23.422 (loader): File "T41_POECan.hex". 121800 bytes, 1% used
    11:49:23.455 (loader): remote cmd from 1240: "status"
    11:49:23.463 (post_compile 1): Status: 1, 0, 0, 0, 0, 0, .vsteensy/build\, T41_POECan.hex
    11:49:23.463 (post_compile 1): Sending command: auto:on
    11:49:23.464 (loader): remote cmd from 1240: "auto:on"
    11:49:23.466 (post_compile 1): Disconnect
    11:49:23.481 (post_compile 2): Running teensy_reboot: "C:\PROGRA~2\Arduino\hardware\tools\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY41"
    11:49:23.495 (loader): remote connection 1240 closed
    11:49:23.507 (loader): remote connection 1268 opened
    11:49:23.652 (reboot 3): Begin, version=1.53, high-res time
    11:49:23.652 (reboot 3): LoadLibrary cfgmgr32 ok
    11:49:23.652 (reboot 3): LoadLibrary ntdll ok
    11:49:23.654 (reboot 3): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#7677540#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    11:49:23.654 (reboot 3): found_usb_device, loc=usb:20000/0/0/1/2/1    Port_#0001.Hub_#0008
    11:49:23.654 (reboot 3): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0280
    11:49:23.654 (reboot 3): found_usb_device, devinst=0000000b
    11:49:23.654 (reboot 3): add: loc=usb:20000/0/0/1/2/1, class=Ports, vid=16C0, pid=0483, ver=0280, serial=7677540, dev=\\?\usb#vid_16c0&pid_0483#7677540#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    11:49:23.654 (reboot 3):   comport_from_devinst_list attempt
    11:49:23.654 (reboot 3):   found Ports in classguid_list at index=0
    11:49:23.654 (reboot 3):   port COM3 found from devnode
    11:49:23.654 (reboot 3): found_usb_device complete
    11:49:23.663 (loader): remote connection 1304 opened
    11:49:23.663 (loader): remote cmd from 1304: "show:arduino_attempt_reboot"
    11:49:23.663 (loader): got request to show arduino rebooting message
    11:49:23.663 (reboot 3): found Teensy Loader, version 1.53
    11:49:23.663 (reboot 3): Sending command: show:arduino_attempt_reboot
    11:49:23.667 (loader): remote cmd from 1304: "comment: Teensyduino 1.53 - WINDOWS (teensy_reboot)"
    11:49:23.667 (loader): remote cmd from 1304: "status"
    11:49:23.667 (reboot 3): Sending command: comment: Teensyduino 1.53 - WINDOWS (teensy_reboot)
    11:49:23.673 (reboot 3): Status: 1, 1, 0, 0, 0, 0, .vsteensy/build\, T41_POECan.hex
    11:49:23.673 (reboot 3): do_reset (serial) COM3
    11:49:23.680 (loader): remote cmd from 1304: "status"
    11:49:23.689 (reboot 3): Status: 1, 1, 0, 0, 0, 0, .vsteensy/build\, T41_POECan.hex
    11:49:23.689 (reboot 3): status read, retry 0
    11:49:23.803 (loader): remote cmd from 1304: "status"
    11:49:23.812 (reboot 3): Status: 1, 1, 0, 0, 0, 0, .vsteensy/build\, T41_POECan.hex
    11:49:23.812 (reboot 3): status read, retry 1
    11:49:23.927 (loader): remote cmd from 1304: "status"
    11:49:23.936 (loader): Device came online, code_size = 8126464
    11:49:23.936 (loader): Board is: Teensy 4.1 (IMXRT1062), version 1.05
    11:49:23.998 (loader): File "T41_POECan.hex". 121800 bytes, 1% used
    11:49:24.001 (loader): set background IMG_ONLINE
    11:49:24.059 (loader): File "T41_POECan.hex". 121800 bytes, 1% used
    11:49:24.089 (loader): elf appears to be for Teensy 4.1 (IMXRT1062) (8126464 bytes)
    11:49:24.089 (loader): elf binary data matches hex file
    11:49:24.090 (loader): elf file is for Teensy 4.1 (IMXRT1062)
    11:49:24.090 (loader): begin operation
    11:49:24.131 (reboot 3): Status: 1, 1, 1, 1, 0, 1, .vsteensy/build\, T41_POECan.hex
    11:49:24.179 (loader): flash, block=0, bs=1024, auto=1
    11:49:24.179 (loader):  gauge old value = 0
    11:49:24.180 (loader): flash, block=1, bs=1024, auto=1
    11:49:24.327 (loader):  gauge old value = 1
    11:49:24.328 (loader): remote cmd from 1304: "status"
    11:49:24.328 (reboot 3): Status: 1, 1, 1, 1, 0, 1, .vsteensy/build\, T41_POECan.hex
    11:49:24.329 (loader): flash, block=2, bs=1024, auto=1
    11:49:24.514 (loader):  gauge old value = 2
    11:49:24.514 (loader): remote cmd from 1304: "status"
    11:49:24.515 (reboot 3): Status: 1, 1, 1, 1, 0, 1, .vsteensy/build\, T41_POECan.hex
    11:49:24.515 (loader): flash, block=3, bs=1024, auto=1
    11:49:24.515 (loader):  gauge old value = 3
    11:49:24.515 (loader): flash, block=4, bs=1024, auto=1
    11:49:24.515 (loader):  gauge old value = 4
    11:49:24.521 (loader): flash, block=5, bs=1024, auto=1
    11:49:24.521 (loader):  gauge old value = 5
    11:49:24.523 (loader): flash, block=6, bs=1024, auto=1
    11:49:24.523 (loader):  gauge old value = 6
    11:49:24.526 (loader): flash, block=7, bs=1024, auto=1
    11:49:24.526 (loader):  gauge old value = 7
    11:49:24.530 (loader): flash, block=8, bs=1024, auto=1
    11:49:24.530 (loader):  gauge old value = 8
    11:49:24.532 (loader): flash, block=9, bs=1024, auto=1
    11:49:24.532 (loader):  gauge old value = 9
    11:49:24.535 (loader): flash, block=10, bs=1024, auto=1
    11:49:24.535 (loader):  gauge old value = 10
    11:49:24.537 (loader): flash, block=11, bs=1024, auto=1
    11:49:24.537 (loader):  gauge old value = 11
    11:49:24.539 (loader): flash, block=12, bs=1024, auto=1
    11:49:24.539 (loader):  gauge old value = 12
    11:49:24.541 (loader): flash, block=13, bs=1024, auto=1
    11:49:24.541 (loader):  gauge old value = 13
    11:49:24.544 (loader): flash, block=14, bs=1024, auto=1
    11:49:24.545 (loader):  gauge old value = 14
    11:49:24.547 (loader): flash, block=15, bs=1024, auto=1
    11:49:24.547 (loader):  gauge old value = 15
    11:49:24.549 (loader): flash, block=16, bs=1024, auto=1
    11:49:24.549 (loader):  gauge old value = 16
    11:49:24.552 (loader): flash, block=17, bs=1024, auto=1
    11:49:24.553 (loader):  gauge old value = 17
    11:49:24.555 (loader): flash, block=18, bs=1024, auto=1
    11:49:24.556 (loader):  gauge old value = 18
    11:49:24.557 (loader): flash, block=19, bs=1024, auto=1
    11:49:24.558 (loader):  gauge old value = 19
    11:49:24.560 (loader): flash, block=20, bs=1024, auto=1
    11:49:24.560 (loader):  gauge old value = 20
    11:49:24.563 (loader): flash, block=21, bs=1024, auto=1
    11:49:24.563 (loader):  gauge old value = 21
    11:49:24.565 (loader): flash, block=22, bs=1024, auto=1
    11:49:24.565 (loader):  gauge old value = 22
    11:49:24.566 (loader): flash, block=23, bs=1024, auto=1
    11:49:24.567 (loader):  gauge old value = 23
    11:49:24.569 (loader): flash, block=24, bs=1024, auto=1
    11:49:24.569 (loader):  gauge old value = 24
    11:49:24.571 (loader): flash, block=25, bs=1024, auto=1
    11:49:24.571 (loader):  gauge old value = 25
    11:49:24.573 (loader): flash, block=26, bs=1024, auto=1
    11:49:24.574 (loader):  gauge old value = 26
    11:49:24.577 (loader): remote cmd from 1304: "status"
    11:49:24.577 (reboot 3): Status: 1, 1, 1, 1, 0, 1, .vsteensy/build\, T41_POECan.hex
    11:49:24.578 (loader): flash, block=27, bs=1024, auto=1
    11:49:24.578 (loader):  gauge old value = 27
    11:49:24.580 (loader): flash, block=28, bs=1024, auto=1
    11:49:24.581 (loader):  gauge old value = 28
    11:49:24.582 (loader): flash, block=29, bs=1024, auto=1
    11:49:24.583 (loader):  gauge old value = 29
    11:49:24.584 (loader): flash, block=30, bs=1024, auto=1
    11:49:24.585 (loader):  gauge old value = 30
    11:49:24.587 (loader): flash, block=31, bs=1024, auto=1
    11:49:24.587 (loader):  gauge old value = 31
    11:49:24.590 (loader): flash, block=32, bs=1024, auto=1
    11:49:24.590 (loader):  gauge old value = 32
    11:49:24.593 (loader): flash, block=33, bs=1024, auto=1
    11:49:24.593 (loader):  gauge old value = 33
    11:49:24.595 (loader): flash, block=34, bs=1024, auto=1
    11:49:24.596 (loader):  gauge old value = 34
    11:49:24.597 (loader): flash, block=35, bs=1024, auto=1
    11:49:24.598 (loader):  gauge old value = 35
    11:49:24.600 (loader): flash, block=36, bs=1024, auto=1
    11:49:24.600 (loader):  gauge old value = 36
    11:49:24.603 (loader): flash, block=37, bs=1024, auto=1
    11:49:24.603 (loader):  gauge old value = 37
    11:49:24.605 (loader): flash, block=38, bs=1024, auto=1
    11:49:24.605 (loader):  gauge old value = 38
    11:49:24.610 (loader): flash, block=39, bs=1024, auto=1
    11:49:24.610 (loader):  gauge old value = 39
    11:49:24.612 (loader): flash, block=40, bs=1024, auto=1
    11:49:24.613 (loader):  gauge old value = 40
    11:49:24.615 (loader): flash, block=41, bs=1024, auto=1
    11:49:24.616 (loader):  gauge old value = 41
    11:49:24.618 (loader): flash, block=42, bs=1024, auto=1
    11:49:24.618 (loader):  gauge old value = 42
    11:49:24.621 (loader): flash, block=43, bs=1024, auto=1
    11:49:24.621 (loader):  gauge old value = 43
    11:49:24.624 (loader): flash, block=44, bs=1024, auto=1
    11:49:24.625 (loader):  gauge old value = 44
    11:49:24.628 (loader): flash, block=45, bs=1024, auto=1
    11:49:24.628 (loader):  gauge old value = 45
    11:49:24.631 (loader): flash, block=46, bs=1024, auto=1
    11:49:24.631 (loader):  gauge old value = 46
    11:49:24.634 (loader): flash, block=47, bs=1024, auto=1
    11:49:24.634 (loader):  gauge old value = 47
    11:49:24.636 (loader): flash, block=48, bs=1024, auto=1
    11:49:24.636 (loader):  gauge old value = 48
    11:49:24.639 (loader): remote cmd from 1304: "status"
    11:49:24.639 (reboot 3): Status: 1, 1, 1, 1, 0, 1, .vsteensy/build\, T41_POECan.hex
    11:49:24.641 (loader): flash, block=49, bs=1024, auto=1
    11:49:24.641 (loader):  gauge old value = 49
    11:49:24.645 (loader): flash, block=50, bs=1024, auto=1
    11:49:24.645 (loader):  gauge old value = 50
    11:49:24.648 (loader): flash, block=51, bs=1024, auto=1
    11:49:24.648 (loader):  gauge old value = 51
    11:49:24.652 (loader): flash, block=52, bs=1024, auto=1
    11:49:24.652 (loader):  gauge old value = 52
    11:49:24.654 (loader): flash, block=53, bs=1024, auto=1
    11:49:24.654 (loader):  gauge old value = 53
    11:49:24.656 (loader): flash, block=54, bs=1024, auto=1
    11:49:24.656 (loader):  gauge old value = 54
    11:49:24.658 (loader): flash, block=55, bs=1024, auto=1
    11:49:24.658 (loader):  gauge old value = 55
    11:49:24.662 (loader): flash, block=56, bs=1024, auto=1
    11:49:24.662 (loader):  gauge old value = 56
    11:49:24.665 (loader): flash, block=57, bs=1024, auto=1
    11:49:24.665 (loader):  gauge old value = 57
    11:49:24.668 (loader): flash, block=58, bs=1024, auto=1
    11:49:24.668 (loader):  gauge old value = 58
    11:49:24.670 (loader): flash, block=59, bs=1024, auto=1
    11:49:24.671 (loader):  gauge old value = 59
    11:49:24.673 (loader): flash, block=60, bs=1024, auto=1
    11:49:24.673 (loader):  gauge old value = 60
    11:49:24.676 (loader): flash, block=61, bs=1024, auto=1
    11:49:24.676 (loader):  gauge old value = 61
    11:49:24.679 (loader): flash, block=62, bs=1024, auto=1
    11:49:24.679 (loader):  gauge old value = 62
    11:49:24.682 (loader): flash, block=63, bs=1024, auto=1
    11:49:24.682 (loader):  gauge old value = 63
    11:49:24.684 (loader): flash, block=64, bs=1024, auto=1
    11:49:24.684 (loader):  gauge old value = 64
    11:49:24.686 (loader): flash, block=65, bs=1024, auto=1
    11:49:24.686 (loader):  gauge old value = 65
    11:49:24.688 (loader): flash, block=66, bs=1024, auto=1
    11:49:24.688 (loader):  gauge old value = 66
    11:49:24.689 (loader): flash, block=67, bs=1024, auto=1
    11:49:24.690 (loader):  gauge old value = 67
    11:49:24.691 (loader): flash, block=68, bs=1024, auto=1
    11:49:24.691 (loader):  gauge old value = 68
    11:49:24.694 (loader): flash, block=69, bs=1024, auto=1
    11:49:24.694 (loader):  gauge old value = 69
    11:49:24.696 (loader): flash, block=70, bs=1024, auto=1
    11:49:24.696 (loader):  gauge old value = 70
    11:49:24.698 (loader): flash, block=71, bs=1024, auto=1
    11:49:24.698 (loader):  gauge old value = 71
    11:49:24.701 (loader): remote cmd from 1304: "status"
    11:49:24.702 (loader): flash, block=72, bs=1024, auto=1
    11:49:24.702 (loader):  gauge old value = 72
    11:49:24.702 (reboot 3): Status: 1, 1, 1, 1, 0, 1, .vsteensy/build\, T41_POECan.hex
    11:49:24.704 (loader): flash, block=73, bs=1024, auto=1
    11:49:24.704 (loader):  gauge old value = 73
    11:49:24.706 (loader): flash, block=74, bs=1024, auto=1
    11:49:24.707 (loader):  gauge old value = 74
    11:49:24.708 (loader): flash, block=75, bs=1024, auto=1
    11:49:24.708 (loader):  gauge old value = 75
    11:49:24.711 (loader): flash, block=76, bs=1024, auto=1
    11:49:24.711 (loader):  gauge old value = 76
    11:49:24.714 (loader): flash, block=77, bs=1024, auto=1
    11:49:24.714 (loader):  gauge old value = 77
    11:49:24.717 (loader): flash, block=78, bs=1024, auto=1
    11:49:24.717 (loader):  gauge old value = 78
    11:49:24.720 (loader): flash, block=79, bs=1024, auto=1
    11:49:24.720 (loader):  gauge old value = 79
    11:49:24.722 (loader): flash, block=80, bs=1024, auto=1
    11:49:24.722 (loader):  gauge old value = 80
    11:49:24.724 (loader): flash, block=81, bs=1024, auto=1
    11:49:24.724 (loader):  gauge old value = 81
    11:49:24.725 (loader): flash, block=82, bs=1024, auto=1
    11:49:24.726 (loader):  gauge old value = 82
    11:49:24.727 (loader): flash, block=83, bs=1024, auto=1
    11:49:24.728 (loader):  gauge old value = 83
    11:49:24.730 (loader): flash, block=84, bs=1024, auto=1
    11:49:24.730 (loader):  gauge old value = 84
    11:49:24.732 (loader): flash, block=85, bs=1024, auto=1
    11:49:24.733 (loader):  gauge old value = 85
    11:49:24.735 (loader): flash, block=86, bs=1024, auto=1
    11:49:24.735 (loader):  gauge old value = 86
    11:49:24.737 (loader): flash, block=87, bs=1024, auto=1
    11:49:24.737 (loader):  gauge old value = 87
    11:49:24.739 (loader): flash, block=88, bs=1024, auto=1
    11:49:24.740 (loader):  gauge old value = 88
    11:49:24.741 (loader): flash, block=89, bs=1024, auto=1
    11:49:24.742 (loader):  gauge old value = 89
    11:49:24.743 (loader): flash, block=90, bs=1024, auto=1
    11:49:24.743 (loader):  gauge old value = 90
    11:49:24.746 (loader): flash, block=91, bs=1024, auto=1
    11:49:24.746 (loader):  gauge old value = 91
    11:49:24.748 (loader): flash, block=92, bs=1024, auto=1
    11:49:24.748 (loader):  gauge old value = 92
    11:49:24.751 (loader): flash, block=93, bs=1024, auto=1
    11:49:24.751 (loader):  gauge old value = 93
    11:49:24.753 (loader): flash, block=94, bs=1024, auto=1
    11:49:24.753 (loader):  gauge old value = 94
    11:49:24.755 (loader): flash, block=95, bs=1024, auto=1
    11:49:24.755 (loader):  gauge old value = 95
    11:49:24.756 (loader): flash, block=96, bs=1024, auto=1
    11:49:24.757 (loader):  gauge old value = 96
    11:49:24.758 (loader): flash, block=97, bs=1024, auto=1
    11:49:24.758 (loader):  gauge old value = 97
    11:49:24.760 (loader): flash, block=98, bs=1024, auto=1
    11:49:24.762 (loader):  gauge old value = 98
    11:49:24.763 (reboot 3): status read, retry 2
    11:49:24.763 (reboot 3): Success
    11:49:24.763 (reboot 3): Disconnect
    11:49:24.764 (loader): flash, block=99, bs=1024, auto=1
    11:49:24.764 (loader):  gauge old value = 99
    11:49:24.767 (loader): flash, block=100, bs=1024, auto=1
    11:49:24.767 (loader):  gauge old value = 100
    11:49:24.769 (loader): flash, block=101, bs=1024, auto=1
    11:49:24.769 (loader):  gauge old value = 101
    11:49:24.772 (loader): flash, block=102, bs=1024, auto=1
    11:49:24.772 (loader):  gauge old value = 102
    11:49:24.774 (loader): flash, block=103, bs=1024, auto=1
    11:49:24.774 (loader):  gauge old value = 103
    11:49:24.776 (loader): flash, block=104, bs=1024, auto=1
    11:49:24.776 (loader):  gauge old value = 104
    11:49:24.782 (loader): remote connection 1304 closed
    11:49:24.782 (loader): flash, block=105, bs=1024, auto=1
    11:49:24.783 (loader):  gauge old value = 105
    11:49:24.786 (loader): flash, block=106, bs=1024, auto=1
    11:49:24.786 (loader):  gauge old value = 106
    11:49:24.792 (loader): flash, block=107, bs=1024, auto=1
    11:49:24.792 (loader):  gauge old value = 107
    11:49:24.795 (loader): flash, block=108, bs=1024, auto=1
    11:49:24.795 (loader):  gauge old value = 108
    11:49:24.798 (loader): remote connection 1268 closed
    11:49:24.799 (loader): flash, block=109, bs=1024, auto=1
    11:49:24.799 (loader):  gauge old value = 109
    11:49:24.803 (loader): flash, block=110, bs=1024, auto=1
    11:49:24.803 (loader):  gauge old value = 110
    11:49:24.805 (loader): flash, block=111, bs=1024, auto=1
    11:49:24.805 (loader):  gauge old value = 111
    11:49:24.807 (loader): flash, block=112, bs=1024, auto=1
    11:49:24.807 (loader):  gauge old value = 112
    11:49:24.810 (loader): flash, block=113, bs=1024, auto=1
    11:49:24.810 (loader):  gauge old value = 113
    11:49:24.813 (loader): flash, block=114, bs=1024, auto=1
    11:49:24.813 (loader):  gauge old value = 114
    11:49:24.816 (loader): flash, block=115, bs=1024, auto=1
    11:49:24.816 (loader):  gauge old value = 115
    11:49:24.818 (loader): flash, block=116, bs=1024, auto=1
    11:49:24.818 (loader):  gauge old value = 116
    11:49:24.820 (loader): flash, block=117, bs=1024, auto=1
    11:49:24.821 (loader):  gauge old value = 117
    11:49:24.823 (loader): flash, block=118, bs=1024, auto=1
    11:49:24.824 (loader):  gauge old value = 118
    11:49:24.845 (loader): sending reboot
    11:49:24.846 (loader): begin wait_until_offline
    11:49:24.901 (loader): offline, waited 1
    11:49:24.901 (loader): end operation, total time = 0.811 seconds
    11:49:24.903 (loader): set background IMG_REBOOT_OK
    11:49:24.909 (loader): redraw timer set, image 14 to show for 1200 ms
    11:49:24.977 (loader): HID/win32:  vid:06CB pid:CD50 ver:0704
    11:49:24.977 (loader): HID/win32:  vid:04F3 pid:29F5 ver:6102
    11:49:24.977 (loader): HID/win32:  vid:8087 pid:0A1E ver:0200
    11:49:24.977 (loader): HID/win32:  vid:256F pid:C652 ver:0102
    11:49:24.978 (loader): HID/win32:  vid:256F pid:C652 ver:0102
    11:49:24.978 (loader): HID/win32:  vid:03F0 pid:0567 ver:0002
    11:49:24.978 (loader): HID/win32:  vid:06CB pid:CD50 ver:0704
    11:49:24.978 (loader): HID/win32:  vid:04F3 pid:29F5 ver:6102
    11:49:24.978 (loader): HID/win32:  vid:046D pid:C318 ver:5503
    11:49:24.978 (loader): HID/win32:  vid:03F0 pid:0269 ver:0017
    11:49:24.978 (loader): HID/win32:  vid:045E pid:0000 ver:0000
    11:49:24.979 (loader): HID/win32:  vid:03F0 pid:0667 ver:0100
    11:49:24.979 (loader): HID/win32:  vid:256F pid:C652 ver:0102
    11:49:24.979 (loader): HID/win32:  vid:BEEF pid:046D ver:0101
    11:49:24.980 (loader): HID/win32:  vid:256F pid:C652 ver:0102
    11:49:24.980 (loader): HID/win32:  vid:04F3 pid:29F5 ver:6102
    11:49:26.113 (loader): redraw, image 9
    11:49:42.654 (loader): Verbose Info event
    And yes, this didn't go so well:
    CORE_BASE        := C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4
    So I left it as it was generated by VisualTeensy.
    Sorry for the fire alarm.
  24. #199
    1,167
    That is absolutely strange, I was able to reproduce your issue, then I switched back to an Arduino installation without spaces in the path and it worked. Switching back to the installation with the space in the path and now it works perfectly. Probably the same effect as your rebooting. I don't understand this. OK, since it works now for both of us lets declare this as weird... Anyway, as WMXZ already wrote, if possible don't use a path with spaces. Have fun with VisualTeensy.
  25. #200
    1,167
    Regarding the comma + space, this seems to be just a comma separated list of folder and filename. If you start the loader from Arduino you see the same.
