FFT analysis of AC motor
Usmanali
New member
Hello! Most of the guys did FFT analysis of audio signal then its display that FFT signal into the spectrum analyzer using teensy3.2 but I want to know what can we do FFT analysis of AC motor using Teensy3.2 Module?
You need to isolate the motor voltage or current that you wish to analyse. This can be done via a suitable transformer, or an isolation current to voltage transducer (hall effect device?), along with protection to ensure that the resulting input to the Teensy does not exceed the A/D input ratings. This is not a specific Teensy problem, as you already noted that a Teensy can perform an FFT of an ac input signal.
