Has anyone been able to get nrf8001 ble boards to work with any teensy board??? I recntly switched to a teensy from arduino and the ble no longer connects.
im using the echodemo code from adafruit
This is an example for our nRF8001 Bluetooth Low Energy Breakout
Pick one up today in the adafruit shop!
------> [url]http://www.adafruit.com/products/1697[/url]
products from Adafruit!
Written by Kevin Townsend/KTOWN for Adafruit Industries.
MIT license, check LICENSE for more information
All text above, and the splash screen below must be included in any redistribution
// This version uses the internal data queing so you can treat it like Serial (kinda)!
#include "Adafruit_BLE_UART.h"
#define ADAFRUITBLE_REQ 10
#define ADAFRUITBLE_RDY 2 // This should be an interrupt pin, on Uno thats #2 or #3
#define ADAFRUITBLE_RST 9
Adafruit_BLE_UART BTLEserial = Adafruit_BLE_UART(ADAFRUITBLE_REQ, ADAFRUITBLE_RDY, ADAFRUITBLE_RST);
Configure the Arduino and start advertising with the radio
void setup(void)
while(!Serial); // Leonardo/Micro should wait for serial init
Serial.println(F("Adafruit Bluefruit Low Energy nRF8001 Print echo demo"));
// BTLEserial.setDeviceName("NEWNAME"); /* 7 characters max! */
BTLEserial.begin();
Constantly checks for new events on the nRF8001
aci_evt_opcode_t laststatus = ACI_EVT_DISCONNECTED;
// Tell the nRF8001 to do whatever it should be working on.
BTLEserial.pollACI();
// Ask what is our current status
aci_evt_opcode_t status = BTLEserial.getState();
// If the status changed....
if (status != laststatus) {
// print it out!
if (status == ACI_EVT_DEVICE_STARTED) {
Serial.println(F("* Advertising started"));
if (status == ACI_EVT_CONNECTED) {
Serial.println(F("* Connected!"));
if (status == ACI_EVT_DISCONNECTED) {
Serial.println(F("* Disconnected or advertising timed out"));
// OK set the last status change to this one
laststatus = status;
// Lets see if there's any data for us!
if (BTLEserial.available()) {
Serial.print("* "); Serial.print(BTLEserial.available()); Serial.println(F(" bytes available from BTLE"));
// OK while we still have something to read, get a character and print it out
while (BTLEserial.available()) {
char c = BTLEserial.read();
Serial.print(c);
// Next up, see if we have any data to get from the Serial console
if (Serial.available()) {
// Read a line from Serial
Serial.setTimeout(100); // 100 millisecond timeout
String s = Serial.readString();
// We need to convert the line to bytes, no more than 20 at this time
uint8_t sendbuffer[20];
s.getBytes(sendbuffer, 20);
char sendbuffersize = min(20, s.length());
Serial.print(F("\n* Sending -> \"")); Serial.print((char *)sendbuffer); Serial.println("\"");
// write the data
BTLEserial.write(sendbuffer, sendbuffersize);
