GeneralMidiSynth, help!
stile
Hello Paul
I need help, error appears while compiling project:
AudioSynthWavetable project
See the arduino screen.
Someone?
I guess I could not explain it correctly.
I installed arduino 1.8.5 and teensy duino, I believe I did everything correctly, okay.
When loading any other EXAMPLE * .ino, eg blink, compiles correctly and is called recording in teensy (I'm using teensy 3.2).
I can not understand why the error appears while compiling: GeneralMidiSynth.ino
The libraries are in the folder stech ordered in error ...
If someone has already compiled and worked, please help.
Attached follows the code I'm trying to compile on arduino, so far unsuccessful.
Thanks for the help,
CODE:
#include "bassoon_samples.h"
#include "clarinet_samples.h"
#include "distortiongt_samples.h"
#include "epiano_samples.h"
#include "flute_samples.h"
#include "frenchhorn_samples.h"
#include "glockenspiel_samples.h"
#include "gtfretnoise_samples.h"
#include "harmonica_samples.h"
#include "harp_samples.h"
#include "mutedgtr_samples.h"
#include "nylonstrgtr_samples.h"
#include "oboe_samples.h"
#include "overdrivegt_samples.h"
#include "recorder_samples.h"
#include "standard_DRUMS_samples.h"
#include "steelstrgtr_samples.h"
#include "strings_samples.h"
#include "timpani_samples.h"
#include "trombone_samples.h"
#include "trumpet_samples.h"
#include "tuba_samples.h"
#include "piano_samples.h"
#include "vibraphone_samples.h"
#include <AudioSynthWavetable.h>
#include <Bounce.h>
#include <SerialFlash.h>
//#define DEBUG_ALLOC
const int TOTAL_VOICES = 64;
const int TOTAL_MIXERS = 21;
const int SECONDARY_MIXERS = 4;
AudioSynthWavetable wavetable[TOTAL_VOICES];
AudioMixer4 mixer[TOTAL_MIXERS];
AudioOutputI2S i2s1;
AudioConnection patchCord[] = {
  {wavetable[0], 0, mixer[0], 0}, {wavetable[1], 0, mixer[0], 1}, {wavetable[2], 0, mixer[0],  2}, {wavetable[3], 0, mixer[0],  3}, {mixer[0], 0, mixer[TOTAL_MIXERS - 2], 0},
  {wavetable[4], 0, mixer[1], 0}, {wavetable[5], 0, mixer[1], 1}, {wavetable[6], 0, mixer[1],  2}, {wavetable[7], 0, mixer[1],  3}, {mixer[1], 0, mixer[TOTAL_MIXERS - 2], 1},
  {wavetable[8], 0, mixer[2], 0}, {wavetable[9], 0, mixer[2], 1}, {wavetable[10], 0, mixer[2],  2}, {wavetable[11], 0, mixer[2],  3}, {mixer[2], 0, mixer[TOTAL_MIXERS - 2], 2},
  {wavetable[12], 0, mixer[3], 0}, {wavetable[13], 0, mixer[3], 1}, {wavetable[14], 0, mixer[3],  2}, {wavetable[15], 0, mixer[3],  3}, {mixer[3], 0, mixer[TOTAL_MIXERS - 2], 3},
  {wavetable[16], 0, mixer[4], 0}, {wavetable[17], 0, mixer[4], 1}, {wavetable[18], 0, mixer[4],  2}, {wavetable[19], 0, mixer[4],  3}, {mixer[4], 0, mixer[TOTAL_MIXERS - 3], 0},
  {wavetable[20], 0, mixer[5], 0}, {wavetable[21], 0, mixer[5], 1}, {wavetable[22], 0, mixer[5],  2}, {wavetable[23], 0, mixer[5],  3}, {mixer[5], 0, mixer[TOTAL_MIXERS - 3], 1},
  {wavetable[24], 0, mixer[6], 0}, {wavetable[25], 0, mixer[6], 1}, {wavetable[26], 0, mixer[6],  2}, {wavetable[27], 0, mixer[6],  3}, {mixer[6], 0, mixer[TOTAL_MIXERS - 3], 2},
  {wavetable[28], 0, mixer[7], 0}, {wavetable[29], 0, mixer[7], 1}, {wavetable[30], 0, mixer[7],  2}, {wavetable[31], 0, mixer[7],  3}, {mixer[7], 0, mixer[TOTAL_MIXERS - 3], 3},
  {wavetable[32], 0, mixer[8], 0}, {wavetable[33], 0, mixer[8], 1}, {wavetable[34], 0, mixer[8],  2}, {wavetable[35], 0, mixer[8],  3}, {mixer[8], 0, mixer[TOTAL_MIXERS - 4], 0},
  {wavetable[36], 0, mixer[9], 0}, {wavetable[37], 0, mixer[9], 1}, {wavetable[38], 0, mixer[9],  2}, {wavetable[39], 0, mixer[9],  3}, {mixer[9], 0, mixer[TOTAL_MIXERS - 4], 1},
  {wavetable[40], 0, mixer[10], 0}, {wavetable[41], 0, mixer[10], 1}, {wavetable[42], 0, mixer[10], 2}, {wavetable[43], 0, mixer[10], 3}, {mixer[10], 0, mixer[TOTAL_MIXERS - 4], 2},
  {wavetable[44], 0, mixer[11], 0}, {wavetable[45], 0, mixer[11], 1}, {wavetable[46], 0, mixer[11], 2}, {wavetable[47], 0, mixer[11], 3}, {mixer[11], 0, mixer[TOTAL_MIXERS - 4], 3},
  {wavetable[48], 0, mixer[12], 0}, {wavetable[49], 0, mixer[12], 1}, {wavetable[50], 0, mixer[12], 2}, {wavetable[51], 0, mixer[12], 3}, {mixer[12], 0, mixer[TOTAL_MIXERS - 5], 0},
  {wavetable[52], 0, mixer[13], 0}, {wavetable[53], 0, mixer[13], 1}, {wavetable[54], 0, mixer[13], 2}, {wavetable[55], 0, mixer[13], 3}, {mixer[13], 0, mixer[TOTAL_MIXERS - 5], 1},
  {wavetable[56], 0, mixer[14], 0}, {wavetable[57], 0, mixer[14], 1}, {wavetable[58], 0, mixer[14], 2}, {wavetable[59], 0, mixer[14], 3}, {mixer[14], 0, mixer[TOTAL_MIXERS - 5], 2},
  {wavetable[60], 0, mixer[15], 0}, {wavetable[61], 0, mixer[15], 1}, {wavetable[62], 0, mixer[15], 2}, {wavetable[63], 0, mixer[15], 3}, {mixer[15], 0, mixer[TOTAL_MIXERS - 5], 3},
  {mixer[TOTAL_MIXERS - 2], 0, mixer[TOTAL_MIXERS - 1], 0},
  {mixer[TOTAL_MIXERS - 3], 0, mixer[TOTAL_MIXERS - 1], 1},
  {mixer[TOTAL_MIXERS - 4], 0, mixer[TOTAL_MIXERS - 1], 2},
  {mixer[TOTAL_MIXERS - 5], 0, mixer[TOTAL_MIXERS - 1], 3},
  {mixer[TOTAL_MIXERS - 1], 0, i2s1, 0},
  {mixer[TOTAL_MIXERS - 1], 0, i2s1, 1},
Bounce buttons[] = { {0, 15}, {1, 15}, {2, 15}, };
const int TOTAL_BUTTONS = sizeof(buttons) / sizeof(Bounce);
void guitarHeroMode();
void printVoices();
void setVolume() {
	sgtl5000_1.volume(0.8*(analogRead(PIN_A2) - 1) / 1022.0);
struct voice_t {
	int wavetable_id;
	byte channel;
	byte note;
voice_t voices[TOTAL_VOICES];
IntervalTimer midiMapTimer;
IntervalTimer guitarHeroTimer;
IntervalTimer volumeTimer;
	pinMode(0, INPUT_PULLUP);
	pinMode(1, INPUT_PULLUP);
	pinMode(2, INPUT_PULLUP);
	AudioMemory(120);
	sgtl5000_1.enable();
	sgtl5000_1.volume(0.8);
	for (int i = 0; i < TOTAL_VOICES; ++i) {
		wavetable[i].setInstrument(nylonstrgtr);
		voices[i].wavetable_id = i;
		voices[i].channel = voices[i].note = 0xFF;
	for (int i = 0; i < TOTAL_MIXERS - 1; ++i)
		for (int j = 0; j < 4; ++j)
			mixer[i].gain(j, 0.50);
	for (int i = 0; i < 4; ++i)
		mixer[TOTAL_MIXERS - 1].gain(i, i < SECONDARY_MIXERS ? 2.0 / SECONDARY_MIXERS : 0.0);
	usbMIDI.setHandleNoteOn(OnNoteOn);
	usbMIDI.setHandleNoteOff(OnNoteOff);
	usbMIDI.setHandleProgramChange(OnProgramChange);
	usbMIDI.setHandleControlChange(OnControlChange);
	//volumeTimer.begin(setVolume, 100000);
	//guitarHeroTimer.begin(guitarHeroMode, 1000000 / 120);
	//midiMapTimer.begin(printVoices, 5000);
	delay(2000);
	usbMIDI.read();
	//for (int i = 0; i < TOTAL_BUTTONS; ++i) buttons[i].update();
	//if (buttons[0].fallingEdge()) AudioSynthWavetable::print_performance();
	//if (buttons[1].risingEdge()) {
	//  midiMapTimer.end();
	//  Serial.print('\n');
	//if (buttons[1].fallingEdge()) midiMapTimer.begin(printVoices, 5000);
	//if (buttons[2].risingEdge()) guitarHeroTimer.end();
	//if (buttons[2].fallingEdge())
	//  guitarHeroTimer.begin(guitarHeroMode, 1000000/60);
int allocateVoice(byte channel, byte note);
int findVoice(byte channel, byte note);
void freeVoices();
int used_voices = 0;
int stopped_voices = 0;
int evict_voice = 0;
int notes_played = 0;
void OnPress(int key)
	Serial.print("key '");
	Serial.print((char)key);
	Serial.print("'  ");
	Serial.println(key);
	//Serial.print("key ");
	//Serial.print((char)keyboard1.getKey());
	//Serial.print("  ");
	//Serial.print((char)keyboard2.getKey());
	//Serial.println();
const instrument_data* const midi_map[] = {
	&piano, &piano, &piano, &piano, &piano, &piano, &piano, &piano, // 000: pianos
	&vibraphone, &vibraphone, &vibraphone, &vibraphone, &vibraphone, &vibraphone, &vibraphone, &vibraphone, // 008: chrom percus
	&harmonica, &harmonica, &harmonica, &harmonica, &harmonica, &harmonica, &harmonica, &harmonica, // 016: organs
	&nylonstrgtr, &steelstrgtr, &nylonstrgtr, &nylonstrgtr, &mutedgtr, &overdrivegt, &distortiongt, &nylonstrgtr, // 024: guitars
	&piano, &piano, &piano, &piano, &piano, &piano, &piano, &piano, // 032: bass
	&strings, &strings, &strings, &strings, &strings, &strings, &harp, &timpani, // 040: strings
	&strings, &strings, &strings, &strings, &strings, &strings, &strings, &strings, // 048: ensemble
	&trumpet, &trombone, &tuba, &frenchhorn, &frenchhorn, &frenchhorn, &frenchhorn, &frenchhorn, // 056: brass
	&oboe, &oboe, &oboe, &oboe, &oboe, &oboe, &bassoon, &clarinet, // 064: reed
	&flute, &flute, &recorder, &flute, &flute, &flute, &flute, &flute, // 072: pipe
	&piano, &piano, &piano, &piano, &piano, &piano, &piano, &piano, // 080: synth lead
	&piano, &piano, &piano, &piano, &piano, &piano, &piano, &piano, // 088: synth pad
	&piano, &piano, &piano, &piano, &piano, &piano, &piano, &piano, // 096: synth effect
	&piano, &piano, &piano, &piano, &piano, &piano, &piano, &piano, // 104: ethnic
	&timpani, &timpani, &timpani, &timpani, &timpani, &timpani, &timpani, &timpani, // 112: percussive
	&gtfretnoise, &gtfretnoise, &gtfretnoise, &gtfretnoise, &gtfretnoise, &gtfretnoise, &gtfretnoise, &gtfretnoise, // 120: sound effects
const instrument_data* channel_map[17] = {
	&piano, &piano, &piano, &piano, &piano, &piano, &piano, &piano, &piano, &piano, &standard_DRUMS, &piano, &piano, &piano, &piano, &piano, &piano,
int channel_vol[] = {
	90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90,
void OnControlChange(byte channel, byte control, byte value)
	switch (control) {
	case 7: //volume
		channel_vol[channel] = value;
	default:
	Serial.print("Control Change, ch=");
	Serial.print(channel);
	Serial.print(", control=");
	Serial.print(control);
	Serial.print(", value=");
	Serial.print(value);
void OnProgramChange(byte channel, byte program) {
	channel_map[channel] = channel != 10 ? midi_map[program] : &standard_DRUMS;
void OnNoteOn(byte channel, byte note, byte velocity) {
	notes_played++;
#ifdef DEBUG_ALLOC
	//Serial.printf("**** NoteOn: channel==%hhu,note==%hhu ****\n", channel, note);
	printVoices();
#endif //DEBUG_ALLOC
	freeVoices();
	int wavetable_id = allocateVoice(channel, note);
	wavetable[wavetable_id].setInstrument(*channel_map[channel]);
	wavetable[wavetable_id].playNote(note, (velocity*channel_vol[channel] + 0x80) >> 7);
#ifdef DEBUG_ALLOC
	printVoices();
void OnNoteOff(byte channel, byte note, byte velocity) {
#ifdef DEBUG_ALLOC
	//Serial.printf("\n**** NoteOff: channel==%hhu,note==%hhu ****", channel, note);
	printVoices();
	int wavetable_id = findVoice(channel, note);
	if (wavetable_id != TOTAL_VOICES)
		wavetable[wavetable_id].stop();
#ifdef DEBUG_ALLOC
	printVoices();
int allocateVoice(byte channel, byte note) {
	int i;
	int nonfree_voices = stopped_voices + used_voices;
	if (nonfree_voices < TOTAL_VOICES) {
		for (i = nonfree_voices; i < TOTAL_VOICES && voices[i].channel != channel; ++i);
		if (i < TOTAL_VOICES) {
			voice_t temp = voices[i];
			voices[i] = voices[nonfree_voices];
			voices[nonfree_voices] = temp;
		i = nonfree_voices;
		used_voices++;
	else {
		if (stopped_voices) {
			i = evict_voice % stopped_voices;
			stopped_voices--;
			voices[i] = voices[stopped_voices];
			voices[stopped_voices] = temp;
			used_voices++;
			i = stopped_voices;
			i = evict_voice;
	voices[i].channel = channel;
	voices[i].note = note;
	evict_voice++;
	evict_voice %= TOTAL_VOICES;
	return voices[i].wavetable_id;
int findVoice(byte channel, byte note) {
	int i;
	//find match
	for (i = stopped_voices; i < nonfree_voices && !(voices[i].channel == channel && voices[i].note == note); ++i);
	//return TOTAL_VOICES if no match
	if (i == (nonfree_voices)) return TOTAL_VOICES;
	--used_voices;
	return voices[stopped_voices++].wavetable_id;
void freeVoices() {
	for (int i = 0; i < stopped_voices; i++)
		if (wavetable[voices[i].wavetable_id].isPlaying() == false) {
			--stopped_voices;
			voices[stopped_voices] = voices[nonfree_voices];
void guitarHeroMode() { // now unicorn friendly
	const int RESET = 4;
	const int MIDI_NOTES = 128;
	static char line[MIDI_NOTES + 1] = { 0 };
	static int accumulated = 0;
	if (!accumulated) {
		for (int i = 0; i < MIDI_NOTES; ++i) line[i] = '-';
		++accumulated;
	for (int i = stopped_voices; i < used_voices + stopped_voices; ++i) line[voices[i].note] = '*';
	if (accumulated == RESET) {
		Serial.println(line);
		accumulated = 0;
	else {
		++accumulated;
const char* note_map[] = {
  "C","C#","D","D#","E","F","F#","G","G#","A","A#","B"
void printVoices() {
	static int last_notes_played = notes_played;
	if (last_notes_played == notes_played)
		return;
	int usage = AudioProcessorUsage();
	Serial.printf("\nCPU:%03i voices:%02i CPU/Voice:%02i evict:%02i", usage, used_voices, usage / used_voices, evict_voice);
	for (int i = 0; i < used_voices; ++i)
		Serial.printf(" %02hhu %-2s", voices[i].channel, note_map[voices[i].note % 12]);
Better to include the error output as text for readability … but squinting at the screenshot it looks like this requested file:: #include <AudioSynthWavetable.h>
It presented as not found.
If not needed that should be removed - if needed it should be found and made available.
The downloaded file should be extracted into the "sketchbook"\libraries folder?
And closing and restarting the IDE is the best way to know it will be found.
With VERBOSE info on the compile - copy and paste that resultant text into a forum post comment for best review. That will show paths and information to contrast a better answer.
In addition to installing Arduino & Teensyduino, you need to perform special steps to install that library you downloaded. Arduino will not find it unless you copy the files to the proper location.
Look at these instructions.
https://www.arduino.cc/en/Guide/Libraries
Scroll down to "Importing a .zip Library" or "Manual installation".
All the tips, I am analyzing carefully.
I noticed that I had not installed the libraries ...
I have already installed the libraries and the build has progressed, but errors still appear ...
I'll gather more information and come back with the results,
Thank you
Hello friends.
I installed the library: Wavetable-Synthesis-master.zip.
Now the compilation happens, but errors still appear at the end of the build, see:
VIDEO: https://www.youtube.com/watch?v=sYhwVUanWsw&feature=youtu.be
ERROR MESSAGES:
Arduino: 1.8.5 (Windows 7), TD: 1.43-beta1, Placa:"Teensy 3.6, Serial, 180 MHz, Faster, US English"
GeneralMidiSynth:112: error: 'usbMIDI' was not declared in this scope
To make a USB MIDI device, use the Tools > USB Type menu
GeneralMidiSynth: In function 'void loop()':
GeneralMidiSynth:124: error: 'usbMIDI' was not declared in this scope
usbMIDI.read();
Foram encontradas múltiplas bibliotecas para "AudioSynthWavetable.h"
Usado: C:\Users\Marcos\Documents\Arduino\libraries\Wavetable-Synthesis-master
Não usado: C:\Users\Marcos\Documents\Arduino\libraries\GeneralMidiSynth
Foram encontradas múltiplas bibliotecas para "Audio.h"
Usado: C:\Users\Marcos\Desktop\ARDUINO\arduino-1.8.5\hardware\teensy\avr\libraries\Audio
Não usado: C:\Users\Marcos\Documents\Arduino\libraries\Audio-master
Foram encontradas múltiplas bibliotecas para "SD.h"
Usado: C:\Users\Marcos\Desktop\ARDUINO\arduino-1.8.5\hardware\teensy\avr\libraries\SD
Não usado: C:\Users\Marcos\Desktop\ARDUINO\arduino-1.8.5\libraries\SD
Usando biblioteca Wavetable-Synthesis-master na pasta: C:\Users\Marcos\Documents\Arduino\libraries\Wavetable-Synthesis-master (legacy)
Usando biblioteca Bounce na pasta: C:\Users\Marcos\Desktop\ARDUINO\arduino-1.8.5\hardware\teensy\avr\libraries\Bounce (legacy)
Usando a biblioteca Audio na versão 1.3 na pasta: C:\Users\Marcos\Desktop\ARDUINO\arduino-1.8.5\hardware\teensy\avr\libraries\Audio
Usando a biblioteca SPI na versão 1.0 na pasta: C:\Users\Marcos\Desktop\ARDUINO\arduino-1.8.5\hardware\teensy\avr\libraries\SPI
Usando a biblioteca SD na versão 1.2.2 na pasta: C:\Users\Marcos\Desktop\ARDUINO\arduino-1.8.5\hardware\teensy\avr\libraries\SD
Usando a biblioteca SerialFlash na versão 0.5 na pasta: C:\Users\Marcos\Desktop\ARDUINO\arduino-1.8.5\hardware\teensy\avr\libraries\SerialFlash
Usando a biblioteca Wire na versão 1.0 na pasta: C:\Users\Marcos\Desktop\ARDUINO\arduino-1.8.5\hardware\teensy\avr\libraries\Wire
