Results 1 to 3 of 3
Thread: How can I change the volume from DAC0 pin while playing a file?
    Sep 2018
    2
    Is it possible to change the volume of a WAV file while playing. I use teensy 3.5, the DAC0 pin as the output and amplified speakers connected to DAC0 pin. Also I use an HC-SR04 distance sensor to measure the distance and I want to change the volume while the file is playing according to the distance. My code below doesn't affect the sound volume.
    #include <NewPing.h>
    #include <SerialFlash.h>
    AudioPlaySdWav           playWav1;
    AudioOutputAnalog        audioOutput;
    AudioConnection          patchCord1(playWav1, 0, audioOutput, 0);
    AudioConnection          patchCord2(playWav1, 1, audioOutput, 1);
    AudioControlSGTL5000     sgtl5000_1;
    // Use these with the Teensy 3.5 & 3.6 SD card
    #define SDCARD_CS_PIN    BUILTIN_SDCARD
    #define SDCARD_MOSI_PIN  11  // not actually used
    #define SDCARD_SCK_PIN   13  // not actually used
    #define TRIGGER_PIN  12
    #define ECHO_PIN     11
    #define MAX_DISTANCE 300
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
    float vol;
    int distance;
      // Audio connections require memory to work.  For more
      AudioMemory(8);
     // Comment these out if not using the audio adaptor board.
     // This may wait forever if the SDA & SCL pins lack
     // pullup resistors
     //sgtl5000_1.enable();
     // sgtl5000_1.volume(0.5);
      SPI.setMOSI(SDCARD_MOSI_PIN);
      SPI.setSCK(SDCARD_SCK_PIN);
        // stop here, but print a message repetitively
        while (1) {
    void playFile(const char *filename)
      Serial.print("Playing file: ");
      Serial.println(filename);
      // Start playing the file.  This sketch continues to
      // run while the file plays.
      playWav1.play(filename);
      // A brief delay for the library read WAV info
      delay(5);
      // Simply wait for the file to finish playing.
      while (playWav1.isPlaying()) {
        // uncomment these lines if you audio shield
        // has the optional volume pot soldered
        //float vol = analogRead(15);
        //vol = vol / 1024;
       delay(50); // Wait 50ms between pings
       distance = sonar.ping_cm();
       vol = map(distance,MAX_DISTANCE, 1, 0.1, 0.8);
       Serial.println(vol);
       sgtl5000_1.volume(vol);
      playFile("SOUND.WAV");  // filenames are always uppercase 8.3 format
    19,006
    You need to add an amp or mixer object between the SD player and DAC output. Like this:
    Then your code can control the gain of the amp.
    Sep 2018
    2
    I add a mixer and works flawlessly! Thanks!
