Encoder Library : Error compiling for board Arduino/Genuino Mega or Mega 2560
tlharris
I've just downloaded the Encoder library 1.4.1 and trying to compile "Basic" example on a Mega2560
If I compile with default
Encoder myEnc(5,6);
  • the code loads
  • it works great at low speed
  • loses steps at speed (manual twisting) (Not totally surprising.... 64-ppr Bourns encoders and no interrupts)
If I edit to
Encoder myEnc(2,3);
  • error "Encoder Library : Error compiling for board Arduino/Genuino Mega or Mega 2560"
  • same error using any other Mega interrupt pins (18/19, 20/21)
Source code:
/* Encoder Library - Basic Example
 * http://www.pjrc.com/teensy/td_libs_Encoder.html
 * This example code is in the public domain.
#include <Encoder.h>
// Change these two numbers to the pins connected to your encoder.
//   Best Performance: both pins have interrupt capability
//   Good Performance: only the first pin has interrupt capability
//   Low Performance:  neither pin has interrupt capability
Encoder myEnc(20,21);
//   avoid using pins with LEDs attached
  Serial.println("Basic Encoder Test:");
long oldPosition  = -999;
  long newPosition = myEnc.read();
  if (newPosition != oldPosition) {
    oldPosition = newPosition;
    Serial.println(newPosition);
Any ideas/thoughts/direction appreciated - thanks in advance!
The goal is to use two encoders on handwheels to provide input for motor control.
I should have included error messages:
Arduino: 1.8.7 (Windows Store 1.8.15.0) (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Todd\Documents\ArduinoData\packages -hardware C:\Users\Todd\Documents\Arduino\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Todd\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Todd\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10807 -build-path C:\Users\Todd\AppData\Local\Temp\arduino_build_629879 -warnings=none -build-cache C:\Users\Todd\AppData\Local\Temp\arduino_cache_156498 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\Todd\AppData\Local\Temp\arduino_modified_sketch_234882\Basic.pde
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Todd\Documents\ArduinoData\packages -hardware C:\Users\Todd\Documents\Arduino\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Todd\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Todd\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10807 -build-path C:\Users\Todd\AppData\Local\Temp\arduino_build_629879 -warnings=none -build-cache C:\Users\Todd\AppData\Local\Temp\arduino_cache_156498 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\Todd\AppData\Local\Temp\arduino_modified_sketch_234882\Basic.pde
Using board 'mega' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\mega" "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\sketch\\Basic.pde.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\Todd\\Documents\\Arduino\\libraries\\Encoder-master" "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\sketch\\Basic.pde.cpp" -o nul
Using cached library dependencies for file: C:\Users\Todd\Documents\Arduino\libraries\Encoder-master\Encoder.cpp
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\Todd\\Documents\\Arduino\\libraries\\Encoder-master" "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\sketch\\Basic.pde.cpp" -o "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\Todd\\Documents\\Arduino\\libraries\\Encoder-master" "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\sketch\\Basic.pde.cpp" -o "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\sketch\\Basic.pde.cpp.o"
Compiling libraries...
Compiling library "Encoder-master"
Using previously compiled file: C:\Users\Todd\AppData\Local\Temp\arduino_build_629879\libraries\Encoder-master\Encoder.cpp.o
Compiling core...
Using precompiled core: C:\Users\Todd\AppData\Local\Temp\arduino_cache_156498\core\core_arduino_avr_mega_cpu_atmega2560_83dd9225a3a2a4e5654b35f3e742d65a.a
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,--relax -mmcu=atmega2560 -o "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879/Basic.pde.elf" "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\sketch\\Basic.pde.cpp.o" "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\libraries\\Encoder-master\\Encoder.cpp.o" "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879/..\\arduino_cache_156498\\core\\core_arduino_avr_mega_cpu_atmega2560_83dd9225a3a2a4e5654b35f3e742d65a.a" "-LC:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879" -lm
In function 'global constructors keyed to 65535_0_Basic.pde.cpp.o':
lto1.exe: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
lto-wrapper.exe: fatal error: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc returned 1 exit status
compilation terminated.
c:/program files/windowsapps/arduinollc.arduinoide_1.8.15.0_x86__mdqgnx93n4wtt/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed
Using library Encoder-master at version 1.4.1 in folder: C:\Users\Todd\Documents\Arduino\libraries\Encoder-master
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
Thanks, Kurt.
I'm digging in... would love to get this resolved, but also may have to go another route for now.
My reality is that I just need to get the encoders working so I can keep this project on track.
You might try installing an older version of Arduino? At least that is what it looked like the other person did with the other report where it faulted.
Thanks - yes, that was the first thing I tried. Unfortunately, I don't know what's going on with the older IDE on my Win10 machine, but it won't let me edit a sketch. I'm sure I could dig into that, but it just feels like I'm getting further and further away from solving the issue at hand.
Thanks for checking, Paul.
I don't have any Linux background or machines available, but I appreciate the effort.
Note: I also tried compiling it on Windows 10 and it compiled as well?
D:\arduino-1.8.7\arduino-builder -dump-prefs -logger=machine -hardware D:\arduino-1.8.7\hardware -hardware C:\Users\kurte\AppData\Local\Arduino15\packages -hardware C:\Users\kurte\Documents\Arduino\hardware -tools D:\arduino-1.8.7\tools-builder -tools D:\arduino-1.8.7\hardware\tools\avr -tools C:\Users\kurte\AppData\Local\Arduino15\packages -built-in-libraries D:\arduino-1.8.7\libraries -libraries C:\Users\kurte\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10807 -build-path C:\Users\kurte\AppData\Local\Temp\arduino_build_6434 -warnings=all -build-cache C:\Users\kurte\AppData\Local\Temp\arduino_cache_704578 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=D:\arduino-1.8.7\hardware\tools\avr -verbose C:\Users\kurte\Documents\Arduino\foo\foo.ino
D:\arduino-1.8.7\arduino-builder -compile -logger=machine -hardware D:\arduino-1.8.7\hardware -hardware C:\Users\kurte\AppData\Local\Arduino15\packages -hardware C:\Users\kurte\Documents\Arduino\hardware -tools D:\arduino-1.8.7\tools-builder -tools D:\arduino-1.8.7\hardware\tools\avr -tools C:\Users\kurte\AppData\Local\Arduino15\packages -built-in-libraries D:\arduino-1.8.7\libraries -libraries C:\Users\kurte\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10807 -build-path C:\Users\kurte\AppData\Local\Temp\arduino_build_6434 -warnings=all -build-cache C:\Users\kurte\AppData\Local\Temp\arduino_cache_704578 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=D:\arduino-1.8.7\hardware\tools\avr -verbose C:\Users\kurte\Documents\Arduino\foo\foo.ino
Using board 'mega' from platform in folder: D:\arduino-1.8.7\hardware\arduino\avr
Using core 'arduino' from platform in folder: D:\arduino-1.8.7\hardware\arduino\avr
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\sketch\\foo.ino.cpp" -o nul
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\sketch\\foo.ino.cpp" -o nul
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master" "-IC:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master\\utility" "C:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master\\Encoder.cpp" -o nul
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\sketch\\foo.ino.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"D:\\arduino-1.8.7\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\sketch\\foo.ino.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\sketch\\foo.ino.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master" "-IC:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master\\utility" "C:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master\\Encoder.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\libraries\\Encoder-master\\Encoder.cpp.o"
Compiling core...
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_pulse.S.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_shift.c.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_analog.c.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\WInterrupts.c.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\wiring.c" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring.c.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\hooks.c" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\hooks.c.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_pulse.c.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_digital.c.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial0.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\new.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\new.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial2.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\IPAddress.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial3.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\WMath.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\Print.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\Print.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\USBCore.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\WString.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\WString.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial1.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\abi.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\abi.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\Tone.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\main.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\main.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\CDC.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\PluggableUSB.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\Stream.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\CDC.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial0.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial1.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial2.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial3.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\IPAddress.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\PluggableUSB.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\Print.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\Stream.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\Tone.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\USBCore.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\WInterrupts.c.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\WMath.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\WString.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\abi.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\hooks.c.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\main.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\new.cpp.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring.c.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_analog.c.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_digital.c.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_pulse.S.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_pulse.c.o"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_shift.c.o"
Archiving built core (caching) in: C:\Users\kurte\AppData\Local\Temp\arduino_cache_704578\core\core_arduino_avr_mega_cpu_atmega2560_61036ca6b1eea0ba9ecba823a33b0093.a
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,--relax -mmcu=atmega2560 -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434/foo.ino.elf" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\sketch\\foo.ino.cpp.o" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\libraries\\Encoder-master\\Encoder.cpp.o" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434/core\\core.a" "-LC:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434" -lm
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434/foo.ino.elf" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434/foo.ino.eep"
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434/foo.ino.elf" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434/foo.ino.hex"
Using library Encoder-master at version 1.4.1 in folder: C:\Users\kurte\Documents\Arduino\libraries\Encoder-master
"D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434/foo.ino.elf"
Sketch uses 3594 bytes (1%) of program storage space. Maximum is 253952 bytes.
Global variables use 252 bytes (3%) of dynamic memory, leaving 7940 bytes for local variables. Maximum is 8192 bytes.
Note: My windows 10 is up to date. I also think the AVR board code was updated yesterday.
Again don't know if this maters, but looked like you used the Windows Store version of Arduino. Which I know for example Teensyduino won't install on, so there may be differences.
I Use the download from: https://www.arduino.cc/en/Main/Software
I mainly use the zip file version as I keep multiple versions of Arduino installed... You might try this. Also you might try to go to board manager and make sure all your boards are up to date.
I've had this same error, same implementation as original post, and also using the windows 10 store install (but my error has been intermittent). Today I realized that if I try to compile an edited sketch without first saving I get this error. When saving first, the error goes away. Today this work, lets see what happens tomorrow :). Hope this helps someone.
I'd bet Per knows the answer. Too bad he's not on this forum. If you post on Arduino's forum he'll almost certainly see your question.
If you post over there, maybe put a link to this thread in your question, so people trying to help you over there can see what's already been discussed here.
