Results 1 to 9 of 9
Thread: Encoder Library : Error compiling for board Arduino/Genuino Mega or Mega 2560
    Sep 2018
    Springfield, MA
    5
    I've just downloaded the Encoder library 1.4.1 and trying to compile "Basic" example on a Mega2560
    If I compile with default
    Encoder myEnc(5,6);
    • the code loads
    • it works great at low speed
    • loses steps at speed (manual twisting) (Not totally surprising.... 64-ppr Bourns encoders and no interrupts)
    If I edit to
    Encoder myEnc(2,3);
    • error "Encoder Library : Error compiling for board Arduino/Genuino Mega or Mega 2560"
    • same error using any other Mega interrupt pins (18/19, 20/21)
    Source code:
    /* Encoder Library - Basic Example
     * http://www.pjrc.com/teensy/td_libs_Encoder.html
     * This example code is in the public domain.
    #include <Encoder.h>
    // Change these two numbers to the pins connected to your encoder.
    //   Best Performance: both pins have interrupt capability
    //   Good Performance: only the first pin has interrupt capability
    //   Low Performance:  neither pin has interrupt capability
    Encoder myEnc(20,21);
    //   avoid using pins with LEDs attached
      Serial.println("Basic Encoder Test:");
    long oldPosition  = -999;
      long newPosition = myEnc.read();
      if (newPosition != oldPosition) {
        oldPosition = newPosition;
        Serial.println(newPosition);
Name:	Screenshot 2018-09-14 08.04.45.png
    Any ideas/thoughts/direction appreciated - thanks in advance!
    The goal is to use two encoders on handwheels to provide input for motor control.
    Sep 2018
    Springfield, MA
    5
    I should have included error messages:
    Arduino: 1.8.7 (Windows Store 1.8.15.0) (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
    C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Todd\Documents\ArduinoData\packages -hardware C:\Users\Todd\Documents\Arduino\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Todd\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Todd\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10807 -build-path C:\Users\Todd\AppData\Local\Temp\arduino_build_629879 -warnings=none -build-cache C:\Users\Todd\AppData\Local\Temp\arduino_cache_156498 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\Todd\AppData\Local\Temp\arduino_modified_sketch_234882\Basic.pde
    C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Todd\Documents\ArduinoData\packages -hardware C:\Users\Todd\Documents\Arduino\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Todd\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Todd\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10807 -build-path C:\Users\Todd\AppData\Local\Temp\arduino_build_629879 -warnings=none -build-cache C:\Users\Todd\AppData\Local\Temp\arduino_cache_156498 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\Todd\AppData\Local\Temp\arduino_modified_sketch_234882\Basic.pde
    Using board 'mega' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
    Using core 'arduino' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
    Detecting libraries used...
    "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\mega" "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\sketch\\Basic.pde.cpp" -o nul
    "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\Todd\\Documents\\Arduino\\libraries\\Encoder-master" "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\sketch\\Basic.pde.cpp" -o nul
    Using cached library dependencies for file: C:\Users\Todd\Documents\Arduino\libraries\Encoder-master\Encoder.cpp
    "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\Todd\\Documents\\Arduino\\libraries\\Encoder-master" "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\sketch\\Basic.pde.cpp" -o "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\Todd\\Documents\\Arduino\\libraries\\Encoder-master" "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\sketch\\Basic.pde.cpp" -o "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\sketch\\Basic.pde.cpp.o"
    Compiling libraries...
    Compiling library "Encoder-master"
    Using previously compiled file: C:\Users\Todd\AppData\Local\Temp\arduino_build_629879\libraries\Encoder-master\Encoder.cpp.o
    Compiling core...
    Using precompiled core: C:\Users\Todd\AppData\Local\Temp\arduino_cache_156498\core\core_arduino_avr_mega_cpu_atmega2560_83dd9225a3a2a4e5654b35f3e742d65a.a
    "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,--relax -mmcu=atmega2560 -o "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879/Basic.pde.elf" "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\sketch\\Basic.pde.cpp.o" "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879\\libraries\\Encoder-master\\Encoder.cpp.o" "C:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879/..\\arduino_cache_156498\\core\\core_arduino_avr_mega_cpu_atmega2560_83dd9225a3a2a4e5654b35f3e742d65a.a" "-LC:\\Users\\Todd\\AppData\\Local\\Temp\\arduino_build_629879" -lm
    In function 'global constructors keyed to 65535_0_Basic.pde.cpp.o':
    lto1.exe: internal compiler error: Segmentation fault
    Please submit a full bug report,
    with preprocessed source if appropriate.
    See <http://gcc.gnu.org/bugs.html> for instructions.
    lto-wrapper.exe: fatal error: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc returned 1 exit status
    compilation terminated.
    c:/program files/windowsapps/arduinollc.arduinoide_1.8.15.0_x86__mdqgnx93n4wtt/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed
    Using library Encoder-master at version 1.4.1 in folder: C:\Users\Todd\Documents\Arduino\libraries\Encoder-master
    exit status 1
    Error compiling for board Arduino/Genuino Mega or Mega 2560.
    3,638
    Looks like a failure in one of the GCC tools installed by Arduino (AVR).
    Wonder if you should maybe also check with Arduino.
    Example maybe same issue as in their Issues database as: https://github.com/arduino/Arduino/issues/7949
    Sep 2018
    Springfield, MA
    5
    Thanks, Kurt.
    I'm digging in... would love to get this resolved, but also may have to go another route for now.
    My reality is that I just need to get the encoders working so I can keep this project on track.
    3,638
    You might try installing an older version of Arduino? At least that is what it looked like the other person did with the other report where it faulted.
    Sep 2018
    Springfield, MA
    5
    Thanks - yes, that was the first thing I tried. Unfortunately, I don't know what's going on with the older IDE on my Win10 machine, but it won't let me edit a sketch. I'm sure I could dig into that, but it just feels like I'm getting further and further away from solving the issue at hand.
    18,153
    It compiles with Arduino Mega without any errors using Linux.
    Sep 2018
    Springfield, MA
    5
    Thanks for checking, Paul.
    I don't have any Linux background or machines available, but I appreciate the effort.
    3,638
    Note: I also tried compiling it on Windows 10 and it compiled as well?
    D:\arduino-1.8.7\arduino-builder -dump-prefs -logger=machine -hardware D:\arduino-1.8.7\hardware -hardware C:\Users\kurte\AppData\Local\Arduino15\packages -hardware C:\Users\kurte\Documents\Arduino\hardware -tools D:\arduino-1.8.7\tools-builder -tools D:\arduino-1.8.7\hardware\tools\avr -tools C:\Users\kurte\AppData\Local\Arduino15\packages -built-in-libraries D:\arduino-1.8.7\libraries -libraries C:\Users\kurte\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10807 -build-path C:\Users\kurte\AppData\Local\Temp\arduino_build_6434 -warnings=all -build-cache C:\Users\kurte\AppData\Local\Temp\arduino_cache_704578 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=D:\arduino-1.8.7\hardware\tools\avr -verbose C:\Users\kurte\Documents\Arduino\foo\foo.ino
    D:\arduino-1.8.7\arduino-builder -compile -logger=machine -hardware D:\arduino-1.8.7\hardware -hardware C:\Users\kurte\AppData\Local\Arduino15\packages -hardware C:\Users\kurte\Documents\Arduino\hardware -tools D:\arduino-1.8.7\tools-builder -tools D:\arduino-1.8.7\hardware\tools\avr -tools C:\Users\kurte\AppData\Local\Arduino15\packages -built-in-libraries D:\arduino-1.8.7\libraries -libraries C:\Users\kurte\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10807 -build-path C:\Users\kurte\AppData\Local\Temp\arduino_build_6434 -warnings=all -build-cache C:\Users\kurte\AppData\Local\Temp\arduino_cache_704578 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=D:\arduino-1.8.7\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=D:\arduino-1.8.7\hardware\tools\avr -verbose C:\Users\kurte\Documents\Arduino\foo\foo.ino
    Using board 'mega' from platform in folder: D:\arduino-1.8.7\hardware\arduino\avr
    Using core 'arduino' from platform in folder: D:\arduino-1.8.7\hardware\arduino\avr
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\sketch\\foo.ino.cpp" -o nul
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\sketch\\foo.ino.cpp" -o nul
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master" "-IC:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master\\utility" "C:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master\\Encoder.cpp" -o nul
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\sketch\\foo.ino.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    "D:\\arduino-1.8.7\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\sketch\\foo.ino.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\sketch\\foo.ino.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master" "-IC:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master\\utility" "C:\\Users\\kurte\\Documents\\Arduino\\libraries\\Encoder-master\\Encoder.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\libraries\\Encoder-master\\Encoder.cpp.o"
    Compiling core...
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_pulse.S.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_shift.c.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_analog.c.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\WInterrupts.c.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\wiring.c" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring.c.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\hooks.c" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\hooks.c.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_pulse.c.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_digital.c.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial0.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\new.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\new.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial2.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\IPAddress.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial3.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\WMath.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\Print.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\Print.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\USBCore.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\WString.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\WString.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial1.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\abi.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\abi.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\Tone.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\main.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\main.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\CDC.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\PluggableUSB.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\arduino-1.8.7\\hardware\\arduino\\avr\\variants\\mega" "D:\\arduino-1.8.7\\hardware\\arduino\\avr\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\Stream.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\CDC.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial0.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial1.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial2.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\HardwareSerial3.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\IPAddress.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\PluggableUSB.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\Print.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\Stream.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\Tone.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\USBCore.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\WInterrupts.c.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\WMath.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\WString.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\abi.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\hooks.c.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\main.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\new.cpp.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring.c.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_analog.c.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_digital.c.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_pulse.S.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_pulse.c.o"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\core.a" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\core\\wiring_shift.c.o"
    Archiving built core (caching) in: C:\Users\kurte\AppData\Local\Temp\arduino_cache_704578\core\core_arduino_avr_mega_cpu_atmega2560_61036ca6b1eea0ba9ecba823a33b0093.a
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,--relax -mmcu=atmega2560 -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434/foo.ino.elf" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\sketch\\foo.ino.cpp.o" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434\\libraries\\Encoder-master\\Encoder.cpp.o" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434/core\\core.a" "-LC:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434" -lm
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434/foo.ino.elf" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434/foo.ino.eep"
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434/foo.ino.elf" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434/foo.ino.hex"
    Using library Encoder-master at version 1.4.1 in folder: C:\Users\kurte\Documents\Arduino\libraries\Encoder-master
    "D:\\arduino-1.8.7\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_6434/foo.ino.elf"
    Sketch uses 3594 bytes (1%) of program storage space. Maximum is 253952 bytes.
    Global variables use 252 bytes (3%) of dynamic memory, leaving 7940 bytes for local variables. Maximum is 8192 bytes.
    Note: My windows 10 is up to date. I also think the AVR board code was updated yesterday.
    Again don't know if this maters, but looked like you used the Windows Store version of Arduino. Which I know for example Teensyduino won't install on, so there may be differences.
    I Use the download from: https://www.arduino.cc/en/Main/Software
    I mainly use the zip file version as I keep multiple versions of Arduino installed... You might try this. Also you might try to go to board manager and make sure all your boards are up to date.
