not sure how to use DAC ( not PWM ) T3.6
hello
from my understanding , analogwrite() is using PWM pins so it's an analog emulator . i also found guidelines for using low pass filter that will turn the PWM signal to an actuall analog - but it comes with delays and noise that i seek to refrain from .
am i missing an actual analog output pin that receives a value and produces a spectrum of voltages between 0 and 3.3V ?
thanks
Senior Member+
If you had read the reference page on the PJRC website, you'd have seen that analogWrite was extended to the DAC pins, doing a true digital/analog conversion:
https://www.pjrc.com/teensy/teensy31.html (scroll down to "12 Bit Analog Output")
But you are right, on the outdated 8bit AVR processors, analogWrite does only PWM.
the link you put shows exactly what i want , but it is a feature of T3.2 and i am talking about T3.6 . is it the same for the 3.6 version ?
i got a bit confused , you say i'm right but show me that it is an option - how should i proceed ?
Senior Member+
Originally Posted by
gony
The Teensy 3.5 and 3.6 have two DAC pins so you can do stereo effects, but they are on different pins (assume the USB connector is pointing up for the directions):
- On the Teensy LC, the single DAC is on A12 and the position of the DAC is the second pin on the right side of the back 7 pins;
- On the Teensy 3.1 and 3.2, the single DAC is on A14 and the position of the DAC is the second pin on the right side of the back 7 pins;
- On the Teensy 3.5 and 3.6, the two DACs are on A21 and A22 and the position of the pins are pin #16, 17 on the right side.
great !
now i see the pins A21 and A22 , with the DAC0 and DAC1 sign .
so now simply following the instructions on this link https://www.pjrc.com/teensy/teensy31.html ( and changing the pin to A21 / A22 ) will do the trick ?
Senior Member+
Studying the reference cards which come with the Teensy 3.5 and 3.6 should have shown you that these have even 2 of these DACs, and the Teensyduino core files allow you (naturally) to access these with analogWrite(A21) and analogWrite(A22) instead of analogWrite(A14) for the Teensy 3.1 and 3.2.
For more details, you might look at the Teensy 3.6 reference manual.
Senior Member+
gony
great !
Yes it will. Don't ask, try out and be happy!
Tags for this Thread
- You may not post replies
- You may not edit your posts
Forum Rules
