As is noted in this forum and other Teensy Audio documents Teensy Audio is a synchronized 16 bit audio buffer interchange system and as such 24 bit sample I2S input devices (mems microphones in this case) are not supported. Reviewing the code I2S Input uses DMA to capture the data stream directly into a Teensy Audio transfer buffer.
I'm need to directly support a pair of I2S compliant microphones (SPH0645LM4H) with both L and R active. This because I cannot seem to locate a 16bit I2S compliant mems microphones. (If anyone knows of one I'd love to know).
Anyway, my question is on modifying the I2S input code to capture 24 bit L/R data into an intermediate capture results buffer then, like many of the math processing modules, decimate the data into a standard 16 bit interchange buffer compliant with the rest of the system.
I would like any opinion on doing this, caveats, watch out for, etc.
