Results 1 to 4 of 4
Thread: Push to release and lock SD card
    Sep 2018
    3
    Would it be possible to request a T3.6 with a push-release SD card mount? Currently they are pull to release without locks. In some applications, the card comes loose. I am currently taping it to the board with ducktape so it will stay in place. I don't know if that would be a matter of just putting a different component or if it would require a board layout change.
    Thanks!
    Sep 2018
    3
    Paul, any answers to this? Would really appreciate it for a project.
    19,255
    The answer is no.
    Or technically, yes you can request anything, but this change isn't going to happen. The main problem is the size. The space available is at most 13 mm wide. Those sockets with the spring mechanism are about 14 to 16 mm wide, so they simply can not fit.
    Sep 2018
    3
    Thanks! Duck tape it is then
