urbanspaceman
Hi!
I'm try to running my personal Collidoscope (www.collidoscope.io)
At this address you can find all the material (is an open source project), basically is a teensy that read some sensor and send midi data to a raspberry via Midi over usb.
I have the latest raspberry, the teensy++ but i also made some test with teensy 3.6 and everything works except the Pitch Bend Message.
As you can see in the Collidoscope documentation, the pitchbend value are mapped from 0 to 149.
If i connect the teensy to a midi monitor, i can read the correct values.
today something strange happened, I replaced the teensy 3.6 with the teensy ++ (that was programmed on windows by a friend of mine using the original sketch ...new.ino)
We connected everything and for a short time it (more or less) worked!
Then I tried to load the sketch on teensy ++ from the mac and stopped working.
I am in touch with the student who made the application 2 years ago, he also does not know why the pitchbend doesn't work properly.
I do not know which way to turn, do you have any suggestions?
There are also sources of the raspberry application
Thank you in advance for the support
