Results 1 to 3 of 3
Thread: FTM timer problems
    FTM timer problems
    Hello
    I tested ftm1 in order to understand how it works. I didnít know how to connect the pin to the timer channel so I simply copied the define macro from ďpins_teensy.cĒ (but I donít understand what those define lines do).
    This is my simple sketch which is supposed to put ftm1 in edge aligned mode and to produce a pulse with a frequency of about 85828 kHz. I thought that putting C0V at half it will produce a 50% duty cycle:
    uint8_t pulsePin1 = 3;
    #define FTM1_CH0_PIN 3
    #define FTM_PINCFG(pin) FTM_PINCFG2(pin)
    #define FTM_PINCFG2(pin) CORE_PIN ## pin ## _CONFIG
      pinMode(pulsePin1, OUTPUT);
      FTM_PINCFG(FTM1_CH0_PIN) = PORT_PCR_MUX(3) | PORT_PCR_DSE | PORT_PCR_SRE;
      FTM1_COMBINE=0;
      FTM1_SC=B1001000;
      FTM1_C0SC=B101000;
      FTM1_MOD = 500;
      FTM1_C0V = 250;
    I measured the output with an oscilloscope and the problem is that the output frequency is about 95.8kHz. Also the duty cycle is about 22%.
    I need some help to understand why the frequency and duty cycle donít match.
    19,255
    Try using 558 for FTM1_MOD.
    Or use this:
      analogWriteFrequency(3, 85828);
      analogWrite(3, 128);
    Thank you Paul!
    Yes, with FTM1_MOD=558 the frequency is correct. I figured why the frequency didn’t match. I made a stupid mistake – I used 43Mhz instead of 48Mhz, for F_BUS.
    Also the duty cycle wasn’t 50% due to some other components (transistor, resistors). When I put the probe on the output pin everything match perfectly.
    I tried analogwrite and it works very nice, but I have some problems using it.
