Results 1 to 3 of 3
Thread: DAC Filtering on Teensy 3.2
    Hi all,
    I am very new to Teensy and have set up a simple code to run a single 900 Hz tone to the DAC and into an oscilloscope to figure out the resistor I need to put on my low pass filter to get a nice crisp and clean sine wave. Unfortunately, the signal I seem to be getting doesn't even look like a sine wave.Click image for larger version.
ID:	14855 Am I supposed to setup the DAC before I use it or does the DAC work when it is called from pin A14. My code is below and any help would be much appreciated! Sorry if this is a simple, stupid question.
    The closest I was able to get to a sine wave(pretty noisy):
    Circuit:
      pinMode(12, OUTPUT);
      digitalWrite(12, HIGH);
      //pinMode(3, OUTPUT);
      tone(A14, 900, 500000000000);
      delayMicroseconds(3010000);
    Thanks in advance!
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    107
    Hi LunarEclipse57,
    The function tone() outputs a square wave, not a sine wave, see this page: https://www.pjrc.com/teensy/td_pulse.html [scroll down to the bottom of the page].
    For a sine wave output you need to use PJRC's "Audio System Design Tool", here: https://www.pjrc.com/teensy/gui/.
    Design your circuit and Export the code:
    In void setup(), set the frequency & amplitude and define AudioMemory buffers.
    AudioSynthWaveformSine   sine1;          //xy=316,337
    AudioOutputAnalog        dac1;           //xy=484,336
    AudioConnection          patchCord1(sine1, dac1);
      sine1.amplitude(1);
      sine1.frequency(900);
      AudioMemory(12);
    Compile and upload to your Teensy.
    On the oscilloscope:
    Regards,
    Paul
    Thank you, it was silly of me to just assume that the tone librabry outputs a sine wave.
