I have an absolute magnetic encoder (MB029+MBA029) that i want to buy (specific this model due to its small size and high resolution).
I want to read its position with a Teensy 3.2, and if its possible with no extra parts.
The encoder comes with 3 optional communication interfaces: (Datasheet P.17)
As i understand only the "Asynchronous serial RS422(UART)" can be used with Tensy with no other parts like communication converots.
In the datasheet there is an explanation about this pins and how to request the encoder position.
But i still have truble with how to wire both of them:
The encoder has 8 pins: (Datasheet P.16)
And there is an explanation which command do i send to get the info(pos/speed/temp/..) that i need (Datasheet P.18 bottom).
I dont understand where do i connect the RX+/- TX +/-
and which serial i send / read the indormation from the sensor.
Download the Datasheet
Best regards.
- Asynchronous serial RS422(UART)
- SSI
- BiSS-C
- Vdd - 5V
- GND
- Temp sens 1 & 2
- RX +
- RX -
- TX data out +
- TX data out -
Best regards.
