Hello all,
I've just received my teensy3.6, I tried to run a basic Hello world and I got troubles with the Serial.println command on the IDE Arduino
The monitor starts printing "Hello World" but stop after 3 or 4 seconds ...
I found a similar topic on this forum but no real solution is given so I tried to post my own topic on this issue.
What I have already done:
- Update Arduino IDE version to 1.8.7
- Update Teensyduino with the new release 1.44
- Change USB wire
- Restart everything (teensy, computer etc...)
- Google
- I'm running IDE arduino on "Linux Mint 17.2 rafaela"
Please, I would love it if you could help.
Best regards
Joris
- Change USB wire
Best regards
Joris
Blink
Turns on an LED on for one second, then off for one second, repeatedly. Serial monitor of arduino
// Pin 13 has an LED connected on most Arduino boards.
// Pin 11 has the LED on Teensy 2.0
// Pin 6 has the LED on Teensy++ 2.0
// Pin 13 has the LED on Teensy 3.0
// give it a name:
int led = 13;
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
Serial.println("Hello world");
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
delay(100); // wait for a second
