Results 1 to 6 of 6
Thread: ADC library conflicts with Audio library dac output
    I am trying to use a teensy 3.6 to read an analog input and put signals to the dac pins using the soundwave synthesis library and AudioOutputAnalogStereo dacs
    Running each one of these alone works fine, however the moment I setup "ADC *adc = new ADC();" the dac output using AudioOutputAnalogStereo stops working.
    Any idea on what the conflict between the two is and how to resolve it?
    1,837
    as the forum rule states, please provide a runnable sketch that demonstrates the problem. You can't use analogRead() with Audio lib's AudioInputAnalog,
    see https://www.pjrc.com/teensy/gui/?info=AudioInputAnalog
    Not trying to do analogRead with AudioInputAnalog. Trying to do analogRead with the ADC and output to the dac with Audio lib
    Very simple, this works:
    AudioSynthWaveformSine   sine;
    AudioOutputAnalogStereo  dacs;
    AudioConnection          patchCord1(sine, 0, dacs, 0);
    AudioConnection          patchCord2(sine, 0, dacs, 1);
    //#include <ADC.h>
    //ADC *adc = new ADC();
      AudioMemory(10);
      dacs.analogReference(INTERNAL);
      sine.frequency(120);
      sine.amplitude(0.6);
    Uncomment the two ADC related lines (two comments in the text) no more ADC output (other outputs work fine).
    Last tested with teensyduino 1.42
    1,837
    Since DACs are also analog pins (A21, A22), the ADC library initializations might conflict with Audio lib DAC ... more study required.
    can you use the Teensy analogRead()? That might avoid a conflict. a simple analogRead(A0) in your sketch does not
    seem to kill the DAC in my testing
    That is what I resorted to at the moment, the only thing is that it does not allow me to control any settings not the dac (number of bits, conversion speed and averaging).
    1,837
    analogReadAveraging(1);
    analogReadResolution(8);
    changing conversion speed would require manipulating the ADC registers ....
