Results 1 to 4 of 4
Thread: Read Full Register
    Oct 2018
    2
    Read Full Register
    Hi, I'm new to teensy and this forum and I'm looking for some help regarding my Teensy 3.5 project. When reading the "How-to Tips" the section "Using I/O pins" talks about reading a full register (8bit) which I would like to use for my project (reading external hardware which offers a byte interface). Unfortunately I have not found anything (yet) to read a full register (8, 16, 32 bit) with one command for the teensy 3.5. When scanning the "Teensy 3.5 & 3.6 Schematic" it looks to me that the registers and pins are not used in a consecutive way - but I might be wrong. Right now I have a working solution at bit basis:
    byte read_byte() {
    byte b = 0;
    b |= digitalRead(A0)<<0;
    b |= digitalRead(A1)<<1;
    b |= digitalRead(A2)<<2;
    b |= digitalRead(A3)<<3;
    b |= digitalRead(A4)<<4;
    b |= digitalRead(A5)<<5;
    b |= digitalRead(A6)<<6;
    b |= digitalRead(A7)<<7;
    return b;
    which does not look very efficient to me.
    Thanks!
    Germany NRW
    5,679
    Quote Originally Posted by Wilfried View Post
    You're right. You can't just read a register.
    byte read_byte() {
    byte b = 0;
    return b;
    That's not as bad as you might think. If you use digitalReadFast instead, the compiler can optimize it very good.
    Don't think. Measure the time - you'll see - its better than it looks like
    Edit: You can use different pinnumbers - if I remember correctly, there is a least one full 8bit port. In this case, you can use a register-read. Take a look at the schematics!
    Edit: For example, PortC.
    Germany NRW
    5,679
    Oct 2018
    2
    Hi Frank - Thank you for that quick and very informative reply. This really helps.
    Wilfried
