Good Morning.
I am a university student, and in business practices I am working with the Teensy 3.5 board and the Audio Shield, all in the Arduino IDE 1.8.7 environment.
The problem is the following:
I used to load this program (It's the example 1_02 of Audio> Tutorial) on my board and I heard a beep, as it should be.
However, one day I charge that program again and nothing is heard; instead, the serial monitor displays this message.
The Teensy board and the Audio Shield are connected in this way:
As I said, you do not hear that beep that should be heard. I know the problem is not the Teensy board, because it responds well to other programs, such as the Blink. Therefore, I suspect that the problem is in the Audio Sield.
My question is: is there any way to check my Audio Shield plate? It is to know if something is broken or if a short circuit has occurred. If you could indicate or proportional any program or example that indicates to me if the Audio Shield is broken, I would appreciate it very much.
// Advanced Microcontroller-based Audio Workshop
// http://www.pjrc.com/store/audio_tutorial_kit.html
// https://hackaday.io/project/8292-microcontroller-audio-workshop-had-supercon-2015
// Part 1-2: Test Hardware
// Simple beeping is pre-loaded on the Teensy, so
// it will create sound and print info to the serial
// monitor when plugged into a PC.
// This program is supposed to be pre-loaded before
// the workshop, so Teensy+Audio will beep when
// plugged in.
#include <SerialFlash.h>
#include <Bounce.h>
AudioSynthWaveform waveform1;
AudioOutputI2S i2s1;
AudioConnection patchCord1(waveform1, 0, i2s1, 0);
AudioConnection patchCord2(waveform1, 0, i2s1, 1);
Bounce button0 = Bounce(0, 15);
Bounce button1 = Bounce(1, 15);
Bounce button2 = Bounce(2, 15);
int count=1;
int a1history=0, a2history=0, a3history=0;
AudioMemory(10);
pinMode(0, INPUT_PULLUP);
pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
sgtl5000_1.enable();
sgtl5000_1.volume(0.3);
button0.update();
button1.update();
button2.update();
a1history = analogRead(A1);
a2history = analogRead(A2);
a3history = analogRead(A3);
Serial.print("Beep #");
Serial.println(count);
count = count + 1;
waveform1.frequency(440);
waveform1.amplitude(0.9);
wait(250);
waveform1.amplitude(0);
wait(1750);
void wait(unsigned int milliseconds)
elapsedMillis msec=0;
while (msec <= milliseconds) {
button0.update();
button1.update();
button2.update();
if (button0.fallingEdge()) Serial.println("Button (pin 0) Press");
if (button1.fallingEdge()) Serial.println("Button (pin 1) Press");
if (button2.fallingEdge()) Serial.println("Button (pin 2) Press");
if (button0.risingEdge()) Serial.println("Button (pin 0) Release");
if (button1.risingEdge()) Serial.println("Button (pin 1) Release");
if (button2.risingEdge()) Serial.println("Button (pin 2) Release");
int a1 = analogRead(A1);
int a2 = analogRead(A2);
int a3 = analogRead(A3);
if (a1 > a1history + 50 || a1 < a1history - 50) {
Serial.print("Knob (pin A1) = ");
Serial.println(a1);
a1history = a1;
if (a2 > a2history + 50 || a2 < a2history - 50) {
Serial.print("Knob (pin A2) = ");
Serial.println(a2);
a2history = a2;
if (a3 > a3history + 50 || a3 < a3history - 50) {
Serial.print("Knob (pin A3) = ");
Serial.println(a3);
a3history = a3;
10: 05: 22.560 -> Knob (pin A2) = 111
10: 05: 22.560 -> Knob (pin A3) = 43
10: 05: 22.560 -> Knob (pin A2) = 45
10: 05: 22.560 -> Knob (pin A3) = 98
10: 05: 22.560 -> Knob (pin A2) = 134
10: 05: 22.560 -> Knob (pin A3) = 165
10: 05: 22.560 -> Knob (pin A3) = 105
10: 05: 22.560 -> Knob (pin A2) = 83
10: 05: 22.560 -> Knob (pin A3) = 185
10: 05: 22.560 -> Knob (pin A2) = 163
10: 05: 22.560 -> Knob (pin A3) = 131
10: 05: 22.560 -> Knob (pin A2) = 95
10: 05: 22.560 -> Knob (pin A3) = 73
10: 05: 22.560 -> Knob (pin A2) = 33
10: 05: 22.560 -> Knob (pin A2) = 174
10: 05: 22.560 -> Knob (pin A3) = 75
10: 05: 22.560 -> Knob (pin A3) = 157
10: 05: 22.560 -> Knob (pin A3) = 216
10: 05: 22.560 -> Knob (pin A3) = 132
10: 05: 22.560 -> Knob (pin A2) = 96
10: 05: 22.560 -> Knob (pin A3) = 52
10: 05: 22.560 -> Knob (pin A2) = 191
10: 05: 22.560 -> Knob (pin A3) = 156
10: 05: 22.560 -> Knob (pin A2) = 68
10: 05: 22.560 -> Knob (pin A3) = 70
10: 05: 22.560 -> Knob (pin A2) = 145
10: 05: 22.560 -> Knob (pin A3) = 122
10: 05: 22.560 -> Knob (pin A2) = 211
10: 05: 22.560 -> Knob (pin A3) = 175
10: 05: 22.560 -> Knob (pin A3) = 82
10: 05: 22.560 -> Knob (pin A3) = 150
10: 05: 22.560 -> Knob (pin A2) = 173
10: 05: 22.560 -> Knob (pin A3) = 91
10: 05: 22.560 -> Knob (pin A2) = 101
