Hi. I've just started experimenting with my new teensy 3.6. While trying to use some of my existing c++ code I found I could not compile anything using c++ libraries. Even the most simple program that includes a c++ library will fail to link.
My current system:
Mac OS 10.14
Arduino 1.8.7
Teensyduino 1.44
Even this code fails to build:
Output:
Its using arm-none-eabi-g++ to compile but then uses arm-none-eabi-gcc to link. If I manually link it and replace arm-none-eabi-gcc with arm-none-eabi-g++ it links ok.
What am I doing wrong? Why won't it use arm-none-eabi-g++ for linking?
Sorry if this is a simple mistake and thanks in advance for your help.
My current system:
Mac OS 10.14
Arduino 1.8.7
Teensyduino 1.44
[B]#include <iostream>[/B]
Output:
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/stivo/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/stivo/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/stivo/Documents/Arduino/libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180,opt=o2std,keys=en-us -ide-version=10807 -build-path /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950 -warnings=none -build-cache /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_cache_150652 -verbose /Users/stivo/Documents/Arduino/sketch_oct06b/sketch_oct06b.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/stivo/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/stivo/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/stivo/Documents/Arduino/libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180,opt=o2std,keys=en-us -ide-version=10807 -build-path /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950 -warnings=none -build-cache /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_cache_150652 -verbose /Users/stivo/Documents/Arduino/sketch_oct06b/sketch_oct06b.ino
Using board 'teensy36' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr
Using core 'teensy3' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr
Detecting libraries used...
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=144 -DARDUINO=10807 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3 /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950/sketch/sketch_oct06b.ino.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=144 -DARDUINO=10807 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3 /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950/sketch/sketch_oct06b.ino.cpp -o /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950/preproc/ctags_target_for_gcc_minus_e.cpp
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/precompile_helper /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3 /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950 /Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=144 -DARDUINO=10807 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3 /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950/pch/Arduino.h -o /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950/pch/Arduino.h.gch
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=144 -DARDUINO=10807 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950/pch -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3 /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950/sketch/sketch_oct06b.ino.cpp -o /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950/sketch/sketch_oct06b.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_cache_150652/core/core_b60bcd800d064b14c3a5ce60e9382b4e.a
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/[B]arm-none-eabi-gcc[/B] -O2 -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1538866587 -T/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/mk66fx1m0.ld -lstdc++ -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950/sketch_oct06b.ino.elf /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950/sketch/sketch_oct06b.ino.cpp.o /var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950/../arduino_cache_150652/core/core_b60bcd800d064b14c3a5ce60e9382b4e.a -L/var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950 -larm_cortexM4lf_math -lm
/var/folders/wn/k2b249w574ndp_5sm22w94y00000gn/T/arduino_build_94950/sketch/sketch_oct06b.ino.cpp.o: In function `__static_initialization_and_destruction_0':
[B]/Applications/Arduino.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/iostream:74: undefined reference to `std::ios_base::Init::Init()'
/Applications/Arduino.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/iostream:74: undefined reference to `std::ios_base::Init::~Init()'[/B]
collect2: error: ld returned 1 exit status
Error compiling for board Teensy 3.6.
