Results 1 to 16 of 16
Thread: Basic question about analog read voltage
    Sep 2018
    14
    I want simple code for reading analog input A0 voltage for Teensy 3.2 .
    I don't understand ADC library examples exactly.
    Can some one help me about single voltage read?
    3,704
    All you need to do is something like:
    int i = analogRead(A0);
    More details up on: https://www.arduino.cc/reference/en/...io/analogread/
    This will set the variable i to the result of the analog read.
    By default the read will give you 10 bits of information. That is 0-1023, where 0v will be 0 and 3.3v will be 1023 (more or less). Anything above 3.3v will also read 1023.
    And it is pretty linear. So 1.65v will read around 512
    The Teensy can read in more bits of information, and you can change this by calling analogReadResolution example: analogReadResulution(12);
    Will set 12 bit resolution. So values will then be between 0-4095
    Sep 2018
    14
    I know this already I forgot to say. In Teensy ADC examples there no any simple code. Im should I use arduino's ADC code as you said or use Teensy's lib.?
    Feb 2014
    Colmar, France
    2,071
    The Teensy lib might be used for more complex scenarios, that means when the "default" Arduino functions like analogRead() and analogReadResolution() are not enough to achieve what you want. Shortly resumed: It depends on your project.
    Before you start coding, you should setup your algorithm, be it in mind or on paper, and define the specifications, first: How many signals will I have to read, at which intervals, regular depending on the signal bandwidth or asynchronous, and at which resolution? Do I (depending on the environment) need filtering functions like averaging? How do I want to process the readings afterwards, can it be done in real time on the fly, or do I have to buffer a series of readings before processing these in a batch?
    If you have answered these questions, that means if you know exactly what you need, the second step is to look for the appropriate tools: Can that be done with the Arduino functions, then do it with the Arduino functions. Can't it be done with the Arduino functions, check if the ADC lib can do it. Can't it be done with the ADC lib, write your own ADC engine.
    That's what we call systematic problem analysis and project engineering.
    Sep 2018
    14
    Thank you I totaly agree what you said. I already know these things. But I can't find this answer, how Teensy 3.2 ADC works with "default" Arduino functions? What is default resolution? What is this default sampling rate? I don't need a complex or fast ADC. I will do averaging and filtering by myself after I get ADC input data.
    Feb 2014
    Colmar, France
    2,071
    The maximum (useful) ADC resolution is 12 bit. You can theoretically select 16bit with analogReadResolution(16) but that makes no sense, the last 4 bits will only contain noise. By default, after powering up, the resolution is set to 10bits (for Arduino compatibility). Before you start making reads, you should use analogReadResolution(b) in your setup() to set the resolution to your desired b bits. There is no default sampling rate, analogRead() does just a single one shot read which will take a few microseconds to complete, depending on the signal source impedance, F_CPU and the selected resolution. You'll have to try out at which frequency you can do a simple analogRead() in your code, but I'd guess that it will be above 15kHz. In optimized scenarios, using DMA buffering, people have obtained sampling rates >= 300kHz.
    Sep 2018
    14
    Thank you I don't need fast ADC. 25 samples per second is even nice to me. My signal source is buffer output so it have near by zero impedance. So I will set the resolution 12bits. And I will get the voltage value with this eq. (ADC/2^12)*3300 mV.
    Feb 2014
    Colmar, France
    2,071
    You see, it’s neither rocket science nor music theory...
    18,696
    Quote Originally Posted by feveran View Post
    Pretty much the same as regular Arduino.
    The input range is 3.3V instead of 5V range. But on Arduino's boards which run with 3.3V power, the range is also 3.3V, so again, same as regular Arduino which runs from 3.3V power.
    10 bits, same as Arduino's default.
    That depends on how often to call analogRead(), the same as regular Arduino.
    But Teensy's analogRead() does take less time than analogRead() on most Arduino boards, so you could call it more frequently than with other boards. Still, the exact sample rate is up to you. The normal Arduino analogRead() doesn't implement a specific sample rate on regular Arduino boards, and Teensy's analogRead() is meant to work the same way as Arduino's.
    Hopefully you're seeing a "same as regular Arduino" theme here?
    Sep 2018
    14
    same as regular Arduino thanks
    With regard to selecting 12-bit versus 16-bit, it does matter. The chart below is a bode plot of an 801-point finite impulse response bandpass filter I have running in real time on a Teensy 3.6. The filter program acquires the data using the ADC and outputs the result to the DAC. (The ADC and the DAC use DMA buffering.) The data acquisition rate of both the ADC and the DAC is set at 333 kHz. The frequency is swept from from 27.5 kHz to 90.5 kHz. The only difference between the two data sets is the ADC resolution. As you can see, there is a clear difference in both sensitivity and noise performance.
Name:	12-bit vs 16-bit.jpg
    Feb 2014
    Colmar, France
    2,071
    That‘s interesting and at the same time contradictory to the official data sheet and documentation. I wonder from where this difference does come.
    Sep 2018
    14
    I didn't get the test setup exactly yet.
    See Section 39.2.1 of the K66 Sub-Family Reference Manual under Output Modes. One of those modes is single-ended 16-bit. Here is a schematic of my test setup.
    Regards,
    W
Name:	Test Setup.jpg
    Feb 2014
    Colmar, France
    2,071
    I knew that there was a 16bit mode. But seen that the data sheet K66P144M180SF5V2.pdf says on page 47 that the ENOB in single ended 16bit mode is "only" 12.2 to 13.9 bits with 32x averaging, and still worse 11.4 to 13.1 bits with 4 x averaging, and finally they even don't dare giving a value without averaging, I didn't think that there would be a noticeable difference compared to 12bit mode. Driving the ADC with only a 10mVpp signal doesn't make things better, since the "good" upper 6 bits would never be used if you don't configure the PGA for x64...
    When I first got this filter working I was really surprised that I wasn't getting better performance. You can see from my filter design in the setup diagram that I should expect greater than -80 dB attenuation in the bandstop regions (in a perfect world). Then I read the performance spec... Although I'm convinced that I'm not getting 16-bit accuracy using 16-bit resolution, I'm clearly getting better performance than I would if I were only using 12 bits. Using 12-bits does buy you more acquisition bandwidth but since I am already using about 60% of the computational bandwidth running the filter at 333 kHz, I really can't go much faster so I figured may as well take advantage of the higher bit resolution. Besides, using the ADC in 12-bit mode does not mean your ENOB is 12-bits. I don't normally run the ADC with only 10 mVpp but did it in this case to illustrate the difference in sensitivity. In the 10 mVpp case my filter detected the signal at 16-bits but didn't at 12-bits. Below is the best performance I have been able to obtain with the Teensy 3.6.
    W
Name:	Filter Performance.jpg
