Modified-BMI160 (Accel/Gyro) ---BMM150 (Mag) -Teensy/AVR Libraries
mjs513
Senior Member+
I created a repository on GITHUB (https://github.com/mjs513/Modified-BMI160---BMM150-Arduino-Libraries/tree/master) that is a combination of three of existing libraries for the referenced Bosch sensors.
  1. BMI160-Arduino - This is a direct copy of the Hanyazou's BMI160-Arduino repository: https://github.com/hanyazou/BMI160-Arduino. No changes were made to this library.
  2. Grove_3_Axis_Compass_V2.0_BMM150 - is a slighly modifed version of the SeedStudio respository (https://github.com/Seeed-Studio/Grove_3_Axis_Compass_V2.0_BMM150) which is modeled after the Bosch BMI150 API. I added two additional functions to simplify modifications to the ODR and setup the DRDY interrupt if you choose to use the DRDY:
    [a]set_mag_rate(uint8_t rate) - where the uint8 rate is defined by the enum for the BMI ODR in the .h file
    set_DRDY_bit(uint8_t enable_bit) - it can be either 1 or 0, 1 to use a interrup or 0 not too. Or just not call it and the interrupt won't be set.
    [*]BMI160_Arduino_Combo - is an updated library for using the BMM150 in passthrough mode with a BMI160. The original library can be found here: BMI160_Arduino_Combo. The library has been reworked to reflect the changes in the BMI160 library so it can now operate in I2c or SPI modes. NOTE: i have only tested this with I2C.
I have also included 3 sketches that illustrate the use of each library. I have only completely tested them with a Teensy 3.5. They should work with Teensy from what I could see.
Enjoy.
