Page 2 of 2 FirstFirst 1 2
Results 26 to 32 of 32
Thread: Recommendation for piezo buffer op-amp
  1. #26
    Jun 2013
    312
    You have an oscilloscope? That helps a lot. I actually programmed oscilloscopes into each input so that I could visualize what was happening.
  2. #27
    Feb 2020
    4
    Quote Originally Posted by yeahtuna View Post
    You have the device, so I can't stop you from opening it up and taking a look.
    Yes I am aware about this option But I kinda like it and don't want to open it and "steal" your design, I purchased it to use, not to hack. I just thought sinse there are some kind people who helped you with chosing write components you could share with the results. I know about firmware magic but don't want to even try to implement positional sensing or hot spot supression, just simple piezo triggering.
    No I don't have it. My intension was to make it as simple as possible, but it looks like it is time do it (oscilloscope).
  3. #28
    Jun 2013
    312
    A good opamp is the mcp6004. Programming in your own oscilloscope will be infinitely more useful than buying a hardware unit. The eDRUMin UI shows the waveform allowing me to really see what the device is seeing. Without that information I would have a hard time seeing problems in my transient detection and alignment.
  4. #29
    Feb 2020
    4
    Ok, thanks. Will use mcp6004 as a start point.
  5. #30
    Feb 2018
    Corvallis, OR
    24
    A friend asked me to look over the Analog Devices LTC6240 for a piezo-base oceanographic shear sensor. That op amp looks very good for piezo sensors because of the very low input bias currents--in the 1picoAmp range.
    https://www.analog.com/media/en/tech...s/624012fe.pdf
  6. #31
    2,518
    Quote Originally Posted by mborgerson View Post
    I plan to use the same Opamp, but have not tested them yet. I`m only concerned about the 18 MHz Gain-Bandwidth product that limits the achievable gain somewhat. But for a Pre-amp it may be OK.
  7. #32
    Feb 2020
    4
    LTC6240 looks nice, but I couldn't find it anywere in our local stores. But I found MCP6022T wich is much like MCP6004 but has better slew rate, wich may be important in piezo sampling.
