Results 1 to 3 of 3
Thread: W850io endPacket() failure
    Junior Member weirdgyn's Avatar
    Oct 2018
    Italy
    2
    I'm writing a quite complex sketch where I use Ethernet library to provide UDP bidirectional connections between a Teensy 3.6 + W850io module and a client application running on an Android tablet.
    The 'receving' part (running on Teensy) works fine but when I try to send data back to the client I got a very strange behaviour on endPacket(): everything stops working just after this call..
    This's the function where I send data over UDP connection:
    void sendTelemetry(int i, const char* _identification, int _value)
      char _buffer[5] = { 0, 0, 0, 0, 0 };
      char _buffer_crc[3] = { 0, 0, 0 };
      char _buffer_identification[2] = { 0, 0 };
      String _aux = "";
      byte _crc = 0x00;
      _aux.reserve(16);
      Int2HexStr(_value, _buffer);
      _crc = computeCRC(_buffer);                   // TODO: calcolo crc
      Byte2HexStr(_crc, _buffer_crc);                // sprint(_buffer_crc,"%02X", _crc );
    #ifdef DEBUG_SEND_TELEMETRY
      Serial.print("CRC(0x)=");
      Serial.println(_buffer_crc);
      sprintf(_buffer_identification, "%d", i);
      _aux = "$";
      _aux += _identification;
      _aux += _buffer_identification;
      _aux += _buffer;
      _aux += _buffer_crc;
      _aux += "&";
      if (ethTelemetry.beginPacket(destinationIP, UDP_REMOTE_PORT) == 1)
        ethTelemetry.write(_aux.c_str());
        Serial.print("UDP sending: ");
        if (ethTelemetry.endPacket() != 1)
          Serial.print("endPacket() failed!");
        Serial.print("beginPacket() failed!");
      Serial.print("...sent: ");
      Serial.println(_aux.c_str());
    The code after endPacket() call is never executed. Of course DEBUG_SEND_TELEMETRY is defined.
    I connected the W850io module to the default SPI0 bus i.e. pin 11 (mosi0), 12 (miso0), 13 (sck0), 15 (cs0).
    I have not other SPI units connected on such bus ... should I need to call Ethernet.init(15) to reserve CS pin?
    Best regards,
    Michele Santucci
    19,261
    Quote Originally Posted by weirdgyn View Post
    I can answer this question: Yes, you definitely need Ethernet.init(15) before Ethernet.begin() if using any pin for CS other than pin 10.
    Regarding the rest, I do not know. But I can tell you I only investigate problems with a complete program I can copy into Arduino and run on a real board is posted. If Ethernet.init(15) does not fully solve your problem, maybe you could try creating a small program which shows the problem to share on this forum?
    Together with a program to copy into Arduino and upload to a Teensy 3.6, I will also need a clear way to implement the other side of the communication, to recreate the same problem.
    Oct 2018
    Italy
    2
    Yes I will post a full sketch to show the issue but it will take some time and I'm in a hurry. Hope Ethernet.init(15) fixes this.
