Dry/wet effect
ianni992
Goodmorning everyone.
I write from Italy, excuse my English.
I have a question:
How can I integrate a "dry/wet" function from a pot on teensy?
I have a simple sketch of delay effect.
thanks
You would have to add a mixer object. On one input, you'd connect the original signal, on the other the delayed signal. Then you would have to add code to read a potentiometer and to scale the readings down to a float variable between 0.0f and 1.0f, lets call it dw_val. Finally, you'd set the two mixer channel volumes synchronously, the delayed signal with dw_val and the original signal with (1 - dw_val), so that the signal remains at same strength in the sum, and that at the extremes you get the pure dry or delayed signals: if dw_val is 0.0, no delay would fully come through the mixer, and the volume for the original signal would be 1.0 - 0.0 = 1.0, thus the sum would be perfectly dry. If dw_val is 1.0, the delayed signal would fully come through the mixer, and the volume for the original signal would be 1.0 - 1.0 = 0.0, thus the sum would be perfectly wet.
BTW:
That's not an excuse... everybody can make the effort to learn foreign languages, even French and Italian people ;)
Tonight I try and I uploaded the code.
It was obvious, but I did not think about it
Thank you so much
You're right, but I currently have little time.
Work, projects, women :D
AudioInputUSB            usb1;           //xy=368,492
AudioInputI2S            i2s1;           //xy=393.5,427.25
AudioMixer4              mixer1;         //xy=585,601.25
AudioMixer4              mixer3;         //xy=607,375
AudioEffectDelay         delay1;         //xy=755.0000114440918,737.5000152587891
AudioMixer4              mixer2;         //xy=1014.75,518.361083984375
AudioOutputI2S           i2s2;           //xy=1197.5,631.25
AudioConnection          patchCord1(usb1, 0, mixer3, 2);
AudioConnection          patchCord2(usb1, 1, mixer3, 3);
AudioConnection          patchCord3(i2s1, 0, mixer3, 0);
AudioConnection          patchCord4(i2s1, 1, mixer3, 1);
AudioConnection          patchCord5(mixer1, delay1);
AudioConnection          patchCord6(mixer3, 0, mixer2, 0);
AudioConnection          patchCord7(mixer3, 0, mixer1, 0);
AudioConnection          patchCord8(delay1, 0, mixer2, 1);
AudioConnection          patchCord9(delay1, 0, mixer1, 3);
AudioConnection          patchCord10(mixer2, 0, i2s2, 0);
AudioConnection          patchCord11(mixer2, 0, i2s2, 1);
AudioControlSGTL5000     sgtl5000_1;     //xy=450.00000762939453,766.2500133514404
  //pinMode(0, INPUT_PULLUP);
  AudioMemory(190);
  sgtl5000_1.enable();
  sgtl5000_1.volume(0.7);
  //sgtl5000_1.inputSelect(AUDIO_INPUT_LINEIN);
  sgtl5000_1.adcHighPassFilterDisable(); // reduction of noise floor in some cases
    mixer1.gain(0, 0.5);
    mixer1.gain(3, 0);
    delay1.delay(0, 100);
    mixer2.gain(0, 1);
    mixer2.gain(1, 0);
  //delay(1000);
  //lettura pot 2 controllo feedback delay
  int knob = analogRead(A1);
  float feedback = (float)knob / 1050.0;
  mixer1.gain(3, feedback);
  //lettura pot 1 per controllo tempo delay
  int knob2 = analogRead(A0);
  int tempo = map(knob2, 0, 1024, 0, 500);
  delay1.delay(0, tempo);
  //lettura pot 3 per controllo dry/wet
  int knob3 = analogRead(A2);
  float dw_val = (float)knob3 / 1050.0;
  mixer2.gain(0, 1.00 - dw_val);
  mixer2.gain(1, dw_val);
  delay(60);
it's work! thanks you:cool:
