Results 1 to 5 of 5
Thread: Dry/wet effect
    Dec 2017
    5
    Dry/wet effect
    Goodmorning everyone.
    I write from Italy, excuse my English.
    I have a question:
    How can I integrate a "dry/wet" function from a pot on teensy?
    I have a simple sketch of delay effect.
    thanks
    Feb 2014
    Colmar, France
    2,591
    You would have to add a mixer object. On one input, you'd connect the original signal, on the other the delayed signal. Then you would have to add code to read a potentiometer and to scale the readings down to a float variable between 0.0f and 1.0f, lets call it dw_val. Finally, you'd set the two mixer channel volumes synchronously, the delayed signal with dw_val and the original signal with (1 - dw_val), so that the signal remains at same strength in the sum, and that at the extremes you get the pure dry or delayed signals: if dw_val is 0.0, no delay would fully come through the mixer, and the volume for the original signal would be 1.0 - 0.0 = 1.0, thus the sum would be perfectly dry. If dw_val is 1.0, the delayed signal would fully come through the mixer, and the volume for the original signal would be 1.0 - 1.0 = 0.0, thus the sum would be perfectly wet.
    BTW:
    That's not an excuse... everybody can make the effort to learn foreign languages, even French and Italian people
    Dec 2017
    5
    Tonight I try and I uploaded the code.
    It was obvious, but I did not think about it
    Thank you so much
    You're right, but I currently have little time.
    Work, projects, women
    Dec 2017
    5
    #include <SerialFlash.h>
    AudioInputUSB            usb1;           //xy=368,492
    AudioInputI2S            i2s1;           //xy=393.5,427.25
    AudioMixer4              mixer1;         //xy=585,601.25
    AudioMixer4              mixer3;         //xy=607,375
    AudioEffectDelay         delay1;         //xy=755.0000114440918,737.5000152587891
    AudioMixer4              mixer2;         //xy=1014.75,518.361083984375
    AudioOutputI2S           i2s2;           //xy=1197.5,631.25
    AudioConnection          patchCord1(usb1, 0, mixer3, 2);
    AudioConnection          patchCord2(usb1, 1, mixer3, 3);
    AudioConnection          patchCord3(i2s1, 0, mixer3, 0);
    AudioConnection          patchCord4(i2s1, 1, mixer3, 1);
    AudioConnection          patchCord5(mixer1, delay1);
    AudioConnection          patchCord6(mixer3, 0, mixer2, 0);
    AudioConnection          patchCord7(mixer3, 0, mixer1, 0);
    AudioConnection          patchCord8(delay1, 0, mixer2, 1);
    AudioConnection          patchCord9(delay1, 0, mixer1, 3);
    AudioConnection          patchCord10(mixer2, 0, i2s2, 0);
    AudioConnection          patchCord11(mixer2, 0, i2s2, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=450.00000762939453,766.2500133514404
      //pinMode(0, INPUT_PULLUP);
      AudioMemory(190);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.7);
      //sgtl5000_1.inputSelect(AUDIO_INPUT_LINEIN);
      sgtl5000_1.adcHighPassFilterDisable(); // reduction of noise floor in some cases
        mixer1.gain(0, 0.5);
        mixer1.gain(3, 0);
        delay1.delay(0, 100);
        mixer2.gain(0, 1);
        mixer2.gain(1, 0);
      //delay(1000);
      //lettura pot 2 controllo feedback delay
      int knob = analogRead(A1);
      float feedback = (float)knob / 1050.0;
      mixer1.gain(3, feedback);
      //lettura pot 1 per controllo tempo delay
      int knob2 = analogRead(A0);
      int tempo = map(knob2, 0, 1024, 0, 500);
      delay1.delay(0, tempo);
      //lettura pot 3 per controllo dry/wet
      int knob3 = analogRead(A2);
      float dw_val = (float)knob3 / 1050.0;
      mixer2.gain(0, 1.00 - dw_val);
      mixer2.gain(1, dw_val);
      delay(60);
    it's work! thanks you
    Feb 2014
    Colmar, France
    2,591
    You are welcome! I’m glad that I could help.
