* Very fast RNG. (for test purpose: no guarantee of good statistical properties).
* The generator always use the same deterministic seed.
class FastRNG
public:
/* type of integer returned by the generator */
typedef uint32_t result_type;
/* Default constructor. Always initialize with the same seed. */
FastRNG() : _gen_x(123456789), _gen_y(362436069), _gen_z(521288629) { }
/* min value */
static constexpr result_type min() { return 0; }
/* max value */
static constexpr result_type max() { return 4294967295UL; }
/* return a random number */
inline uint32_t operator()()
uint32_t t;
_gen_x ^= _gen_x << 16; _gen_x ^= _gen_x >> 5; _gen_x ^= _gen_x << 1;
t = _gen_x; _gen_x = _gen_y; _gen_y = _gen_z; _gen_z = t ^ _gen_x ^ _gen_y;
return _gen_z;
/* return a uniform number on [0,1). */
inline float unif() { return ((float)(operator()())) / (4294967296.0); }
private:
uint32_t _gen_x, _gen_y, _gen_z; // state of the generator
/* generate N(0,1) random variable using "ratio of uniform" method
taken from "Numerical recipies in C++"
template<class random_t> inline float normalLaw(random_t & gen)
float u, v, x, y, q;
do {
u = gen.unif(); v = 1.7156*(gen.unif() - 0.5);
x = u - 0.449871; y = abs(v) + 0.386595;
q = (x*x) + y * (0.19600*y - 0.25472*x);
while ((q > 0.27597) && (q > 0.27846 || (v*v) > -4.*logf(u)*(u*u)));
return (v / u);
/* test */
while (!Serial) { yield(); }
const int32_t N = 1000000;
FastRNG gen;
float mean = 0.0, var = 0.0;
elapsedMillis timer = 0;
for (int32_t i = 0; i < N; i++)
const float x = normalLaw(gen);
mean += x;
var += x*x;
const uint32_t t = timer;
Serial.print("mean : "); Serial.println(mean/N, 5);
Serial.print("standart dev: "); Serial.println(sqrt(var/(N-1)), 5);
Serial.print("generation took "); Serial.print(t); Serial.println("ms.");
