/* Teensyduino Core Library
* http://www.pjrc.com/teensy/
* Copyright (c) 2017 PJRC.COM, LLC.
* Permission is hereby granted, free of charge, to any person obtaining
* a copy of this software and associated documentation files (the
* "Software"), to deal in the Software without restriction, including
* without limitation the rights to use, copy, modify, merge, publish,
* distribute, sublicense, and/or sell copies of the Software, and to
* permit persons to whom the Software is furnished to do so, subject to
* the following conditions:
* 1. The above copyright notice and this permission notice shall be
* included in all copies or substantial portions of the Software.
* 2. If the Software is incorporated into a build system that allows
* selection among a list of target devices, then similar target
* devices manufactured by PJRC.COM must be included in the list of
* target devices and selectable in the same manner.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
* EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
* NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS
* BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN
* ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
* CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
* SOFTWARE.
#include "core_pins.h"
#include "pins_arduino.h"
#include "HardwareSerial.h"
#define TEENSY_3_6_PRO // Enable extended pin numbering scheme for custom boards; see https://forum.pjrc.com/threads/54114-Extended-Pin-Numbering?p=198761&posted=1
#if defined(KINETISK)
#define GPIO_BITBAND_ADDR(reg, bit) (((uint32_t)&(reg) - 0x40000000) * 32 + (bit) * 4 + 0x42000000)
#define GPIO_BITBAND_PTR(reg, bit) ((uint32_t *)GPIO_BITBAND_ADDR((reg), (bit)))
//#define GPIO_SET_BIT(reg, bit) (*GPIO_BITBAND_PTR((reg), (bit)) = 1)
//#define GPIO_CLR_BIT(reg, bit) (*GPIO_BITBAND_PTR((reg), (bit)) = 0)
const struct digital_pin_bitband_and_config_table_struct digital_pin_to_info_PGM[] = {
{GPIO_BITBAND_PTR(CORE_PIN0_PORTREG, CORE_PIN0_BIT), &CORE_PIN0_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN1_PORTREG, CORE_PIN1_BIT), &CORE_PIN1_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN2_PORTREG, CORE_PIN2_BIT), &CORE_PIN2_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN3_PORTREG, CORE_PIN3_BIT), &CORE_PIN3_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN4_PORTREG, CORE_PIN4_BIT), &CORE_PIN4_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN5_PORTREG, CORE_PIN5_BIT), &CORE_PIN5_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN6_PORTREG, CORE_PIN6_BIT), &CORE_PIN6_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN7_PORTREG, CORE_PIN7_BIT), &CORE_PIN7_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN8_PORTREG, CORE_PIN8_BIT), &CORE_PIN8_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN9_PORTREG, CORE_PIN9_BIT), &CORE_PIN9_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN10_PORTREG, CORE_PIN10_BIT), &CORE_PIN10_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN11_PORTREG, CORE_PIN11_BIT), &CORE_PIN11_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN12_PORTREG, CORE_PIN12_BIT), &CORE_PIN12_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN13_PORTREG, CORE_PIN13_BIT), &CORE_PIN13_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN14_PORTREG, CORE_PIN14_BIT), &CORE_PIN14_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN15_PORTREG, CORE_PIN15_BIT), &CORE_PIN15_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN16_PORTREG, CORE_PIN16_BIT), &CORE_PIN16_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN17_PORTREG, CORE_PIN17_BIT), &CORE_PIN17_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN18_PORTREG, CORE_PIN18_BIT), &CORE_PIN18_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN19_PORTREG, CORE_PIN19_BIT), &CORE_PIN19_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN20_PORTREG, CORE_PIN20_BIT), &CORE_PIN20_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN21_PORTREG, CORE_PIN21_BIT), &CORE_PIN21_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN22_PORTREG, CORE_PIN22_BIT), &CORE_PIN22_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN23_PORTREG, CORE_PIN23_BIT), &CORE_PIN23_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN24_PORTREG, CORE_PIN24_BIT), &CORE_PIN24_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN25_PORTREG, CORE_PIN25_BIT), &CORE_PIN25_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN26_PORTREG, CORE_PIN26_BIT), &CORE_PIN26_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN27_PORTREG, CORE_PIN27_BIT), &CORE_PIN27_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN28_PORTREG, CORE_PIN28_BIT), &CORE_PIN28_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN29_PORTREG, CORE_PIN29_BIT), &CORE_PIN29_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN30_PORTREG, CORE_PIN30_BIT), &CORE_PIN30_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN31_PORTREG, CORE_PIN31_BIT), &CORE_PIN31_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN32_PORTREG, CORE_PIN32_BIT), &CORE_PIN32_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN33_PORTREG, CORE_PIN33_BIT), &CORE_PIN33_CONFIG},
#ifdef CORE_PIN34_PORTREG
{GPIO_BITBAND_PTR(CORE_PIN34_PORTREG, CORE_PIN34_BIT), &CORE_PIN34_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN35_PORTREG, CORE_PIN35_BIT), &CORE_PIN35_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN36_PORTREG, CORE_PIN36_BIT), &CORE_PIN36_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN37_PORTREG, CORE_PIN37_BIT), &CORE_PIN37_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN38_PORTREG, CORE_PIN38_BIT), &CORE_PIN38_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN39_PORTREG, CORE_PIN39_BIT), &CORE_PIN39_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN40_PORTREG, CORE_PIN40_BIT), &CORE_PIN40_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN41_PORTREG, CORE_PIN41_BIT), &CORE_PIN41_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN42_PORTREG, CORE_PIN42_BIT), &CORE_PIN42_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN43_PORTREG, CORE_PIN43_BIT), &CORE_PIN43_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN44_PORTREG, CORE_PIN44_BIT), &CORE_PIN44_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN45_PORTREG, CORE_PIN45_BIT), &CORE_PIN45_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN46_PORTREG, CORE_PIN46_BIT), &CORE_PIN46_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN47_PORTREG, CORE_PIN47_BIT), &CORE_PIN47_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN48_PORTREG, CORE_PIN48_BIT), &CORE_PIN48_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN49_PORTREG, CORE_PIN49_BIT), &CORE_PIN49_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN50_PORTREG, CORE_PIN50_BIT), &CORE_PIN50_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN51_PORTREG, CORE_PIN51_BIT), &CORE_PIN51_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN52_PORTREG, CORE_PIN52_BIT), &CORE_PIN52_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN53_PORTREG, CORE_PIN53_BIT), &CORE_PIN53_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN54_PORTREG, CORE_PIN54_BIT), &CORE_PIN54_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN55_PORTREG, CORE_PIN55_BIT), &CORE_PIN55_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN56_PORTREG, CORE_PIN56_BIT), &CORE_PIN56_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN57_PORTREG, CORE_PIN57_BIT), &CORE_PIN57_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN58_PORTREG, CORE_PIN58_BIT), &CORE_PIN58_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN59_PORTREG, CORE_PIN59_BIT), &CORE_PIN59_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN60_PORTREG, CORE_PIN60_BIT), &CORE_PIN60_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN61_PORTREG, CORE_PIN61_BIT), &CORE_PIN61_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN62_PORTREG, CORE_PIN62_BIT), &CORE_PIN62_CONFIG},
{GPIO_BITBAND_PTR(CORE_PIN63_PORTREG, CORE_PIN63_BIT), &CORE_PIN63_CONFIG},
#ifdef TEENSY_3_6_PRO
{GPIO_BITBAND_PTR(CORE_PIN72_PORTREG, CORE_PIN72_BIT), &CORE_PIN72_CONFIG}, // filler entry for future use
{GPIO_BITBAND_PTR(CORE_PIN72_PORTREG, CORE_PIN72_BIT), &CORE_PIN72_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN73_PORTREG, CORE_PIN73_BIT), &CORE_PIN73_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN74_PORTREG, CORE_PIN74_BIT), &CORE_PIN74_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN75_PORTREG, CORE_PIN75_BIT), &CORE_PIN75_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN76_PORTREG, CORE_PIN76_BIT), &CORE_PIN76_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN77_PORTREG, CORE_PIN77_BIT), &CORE_PIN77_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN78_PORTREG, CORE_PIN78_BIT), &CORE_PIN78_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN79_PORTREG, CORE_PIN79_BIT), &CORE_PIN79_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN80_PORTREG, CORE_PIN80_BIT), &CORE_PIN80_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN81_PORTREG, CORE_PIN81_BIT), &CORE_PIN81_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN82_PORTREG, CORE_PIN82_BIT), &CORE_PIN82_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN83_PORTREG, CORE_PIN83_BIT), &CORE_PIN83_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN84_PORTREG, CORE_PIN84_BIT), &CORE_PIN84_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN85_PORTREG, CORE_PIN85_BIT), &CORE_PIN85_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN86_PORTREG, CORE_PIN86_BIT), &CORE_PIN86_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN87_PORTREG, CORE_PIN87_BIT), &CORE_PIN87_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN88_PORTREG, CORE_PIN88_BIT), &CORE_PIN88_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN89_PORTREG, CORE_PIN89_BIT), &CORE_PIN89_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN90_PORTREG, CORE_PIN90_BIT), &CORE_PIN90_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN91_PORTREG, CORE_PIN91_BIT), &CORE_PIN91_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN92_PORTREG, CORE_PIN92_BIT), &CORE_PIN92_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN93_PORTREG, CORE_PIN93_BIT), &CORE_PIN93_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN94_PORTREG, CORE_PIN94_BIT), &CORE_PIN94_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN95_PORTREG, CORE_PIN95_BIT), &CORE_PIN95_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN96_PORTREG, CORE_PIN96_BIT), &CORE_PIN96_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN97_PORTREG, CORE_PIN97_BIT), &CORE_PIN97_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN98_PORTREG, CORE_PIN98_BIT), &CORE_PIN98_CONFIG}, // new
{GPIO_BITBAND_PTR(CORE_PIN99_PORTREG, CORE_PIN99_BIT), &CORE_PIN99_CONFIG}, // new
#elif defined(KINETISL)
{((volatile uint8_t *)&CORE_PIN0_PORTREG + (CORE_PIN0_BIT >> 3)), &CORE_PIN0_CONFIG, (1<<(CORE_PIN0_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN1_PORTREG + (CORE_PIN1_BIT >> 3)), &CORE_PIN1_CONFIG, (1<<(CORE_PIN1_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN2_PORTREG + (CORE_PIN2_BIT >> 3)), &CORE_PIN2_CONFIG, (1<<(CORE_PIN2_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN3_PORTREG + (CORE_PIN3_BIT >> 3)), &CORE_PIN3_CONFIG, (1<<(CORE_PIN3_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN4_PORTREG + (CORE_PIN4_BIT >> 3)), &CORE_PIN4_CONFIG, (1<<(CORE_PIN4_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN5_PORTREG + (CORE_PIN5_BIT >> 3)), &CORE_PIN5_CONFIG, (1<<(CORE_PIN5_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN6_PORTREG + (CORE_PIN6_BIT >> 3)), &CORE_PIN6_CONFIG, (1<<(CORE_PIN6_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN7_PORTREG + (CORE_PIN7_BIT >> 3)), &CORE_PIN7_CONFIG, (1<<(CORE_PIN7_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN8_PORTREG + (CORE_PIN8_BIT >> 3)), &CORE_PIN8_CONFIG, (1<<(CORE_PIN8_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN9_PORTREG + (CORE_PIN9_BIT >> 3)), &CORE_PIN9_CONFIG, (1<<(CORE_PIN9_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN10_PORTREG + (CORE_PIN10_BIT >> 3)), &CORE_PIN10_CONFIG, (1<<(CORE_PIN10_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN11_PORTREG + (CORE_PIN11_BIT >> 3)), &CORE_PIN11_CONFIG, (1<<(CORE_PIN11_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN12_PORTREG + (CORE_PIN12_BIT >> 3)), &CORE_PIN12_CONFIG, (1<<(CORE_PIN12_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN13_PORTREG + (CORE_PIN13_BIT >> 3)), &CORE_PIN13_CONFIG, (1<<(CORE_PIN13_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN14_PORTREG + (CORE_PIN14_BIT >> 3)), &CORE_PIN14_CONFIG, (1<<(CORE_PIN14_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN15_PORTREG + (CORE_PIN15_BIT >> 3)), &CORE_PIN15_CONFIG, (1<<(CORE_PIN15_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN16_PORTREG + (CORE_PIN16_BIT >> 3)), &CORE_PIN16_CONFIG, (1<<(CORE_PIN16_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN17_PORTREG + (CORE_PIN17_BIT >> 3)), &CORE_PIN17_CONFIG, (1<<(CORE_PIN17_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN18_PORTREG + (CORE_PIN18_BIT >> 3)), &CORE_PIN18_CONFIG, (1<<(CORE_PIN18_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN19_PORTREG + (CORE_PIN19_BIT >> 3)), &CORE_PIN19_CONFIG, (1<<(CORE_PIN19_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN20_PORTREG + (CORE_PIN20_BIT >> 3)), &CORE_PIN20_CONFIG, (1<<(CORE_PIN20_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN21_PORTREG + (CORE_PIN21_BIT >> 3)), &CORE_PIN21_CONFIG, (1<<(CORE_PIN21_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN22_PORTREG + (CORE_PIN22_BIT >> 3)), &CORE_PIN22_CONFIG, (1<<(CORE_PIN22_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN23_PORTREG + (CORE_PIN23_BIT >> 3)), &CORE_PIN23_CONFIG, (1<<(CORE_PIN23_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN24_PORTREG + (CORE_PIN24_BIT >> 3)), &CORE_PIN24_CONFIG, (1<<(CORE_PIN24_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN25_PORTREG + (CORE_PIN25_BIT >> 3)), &CORE_PIN25_CONFIG, (1<<(CORE_PIN25_BIT & 7))},
{((volatile uint8_t *)&CORE_PIN26_PORTREG + (CORE_PIN26_BIT >> 3)), &CORE_PIN26_CONFIG, (1<<(CORE_PIN26_BIT & 7))}
static void dummy_isr() {};
typedef void (*voidFuncPtr)(void);
#ifdef NO_PORT_ISR_FASTRUN
static void port_A_isr(void);
static void port_B_isr(void);
static void port_C_isr(void);
static void port_D_isr(void);
static void port_E_isr(void);
#else
static void port_A_isr(void) __attribute__ ((section(".fastrun"), noinline, noclone ));
static void port_B_isr(void) __attribute__ ((section(".fastrun"), noinline, noclone ));
static void port_C_isr(void) __attribute__ ((section(".fastrun"), noinline, noclone ));
static void port_D_isr(void) __attribute__ ((section(".fastrun"), noinline, noclone ));
static void port_E_isr(void) __attribute__ ((section(".fastrun"), noinline, noclone ));
voidFuncPtr isr_table_portA[CORE_MAX_PIN_PORTA+1] = { [0 ... CORE_MAX_PIN_PORTA] = dummy_isr };
voidFuncPtr isr_table_portB[CORE_MAX_PIN_PORTB+1] = { [0 ... CORE_MAX_PIN_PORTB] = dummy_isr };
voidFuncPtr isr_table_portC[CORE_MAX_PIN_PORTC+1] = { [0 ... CORE_MAX_PIN_PORTC] = dummy_isr };
voidFuncPtr isr_table_portD[CORE_MAX_PIN_PORTD+1] = { [0 ... CORE_MAX_PIN_PORTD] = dummy_isr };
voidFuncPtr isr_table_portE[CORE_MAX_PIN_PORTE+1] = { [0 ... CORE_MAX_PIN_PORTE] = dummy_isr };
// The Pin Config Register is used to look up the correct interrupt table
// for the corresponding port.
static inline voidFuncPtr* getIsrTable(volatile uint32_t *config) {
voidFuncPtr* isr_table = NULL;
if(&PORTA_PCR0 <= config && config <= &PORTA_PCR31) isr_table = isr_table_portA;
else if(&PORTB_PCR0 <= config && config <= &PORTB_PCR31) isr_table = isr_table_portB;
else if(&PORTC_PCR0 <= config && config <= &PORTC_PCR31) isr_table = isr_table_portC;
else if(&PORTD_PCR0 <= config && config <= &PORTD_PCR31) isr_table = isr_table_portD;
else if(&PORTE_PCR0 <= config && config <= &PORTE_PCR31) isr_table = isr_table_portE;
return isr_table;
inline uint32_t getPinIndex(volatile uint32_t *config) {
uintptr_t v = (uintptr_t) config;
// There are 32 pin config registers for each port, each port starting at a round address.
// They are spaced 4 bytes apart.
return (v % 128) / 4;
volatile static voidFuncPtr intFunc[CORE_NUM_DIGITAL] = { [0 ... CORE_NUM_DIGITAL-1] = dummy_isr };
static void porta_interrupt(void);
static void portcd_interrupt(void);
void attachInterruptVector(enum IRQ_NUMBER_t irq, void (*function)(void))
_VectorsRam[irq + 16] = function;
void attachInterrupt(uint8_t pin, void (*function)(void), int mode)
volatile uint32_t *config;
uint32_t cfg, mask;
if (pin >= CORE_NUM_DIGITAL) return;
switch (mode) {
case CHANGE: mask = 0x0B; break;
case RISING: mask = 0x09; break;
case FALLING: mask = 0x0A; break;
case LOW: mask = 0x08; break;
case HIGH: mask = 0x0C; break;
default: return;
mask = (mask << 16) | 0x01000000;
config = portConfigRegister(pin);
if ((*config & 0x00000700) == 0) {
// for compatibility with programs which depend
// on AVR hardware default to input mode.
pinMode(pin, INPUT);
attachInterruptVector(IRQ_PORTA, port_A_isr);
attachInterruptVector(IRQ_PORTB, port_B_isr);
attachInterruptVector(IRQ_PORTC, port_C_isr);
attachInterruptVector(IRQ_PORTD, port_D_isr);
attachInterruptVector(IRQ_PORTE, port_E_isr);
voidFuncPtr* isr_table = getIsrTable(config);
if(!isr_table) return;
uint32_t pin_index = getPinIndex(config);
__disable_irq();
cfg = *config;
cfg &= ~0x000F0000; // disable any previous interrupt
*config = cfg;
isr_table[pin_index] = function; // set the function pointer
cfg |= mask;
*config = cfg; // enable the new interrupt
__enable_irq();
attachInterruptVector(IRQ_PORTA, porta_interrupt);
attachInterruptVector(IRQ_PORTCD, portcd_interrupt);
__disable_irq();
cfg = *config;
*config = cfg;
intFunc[pin] = function; // set the function pointer
cfg |= mask;
__enable_irq();
void detachInterrupt(uint8_t pin)
__disable_irq();
*config = ((*config & ~0x000F0000) | 0x01000000);
isr_table[pin_index] = dummy_isr;
__enable_irq();
__disable_irq();
intFunc[pin] = dummy_isr;
__enable_irq();
// Using CTZ instead of CLZ is faster, since it allows more efficient bit
// clearing and fast indexing into the pin ISR table.
#define PORT_ISR_FUNCTION_CLZ(port_name) \
static void port_ ## port_name ## _isr(void) { \
uint32_t isfr = PORT ## port_name ##_ISFR; \
PORT ## port_name ##_ISFR = isfr; \
voidFuncPtr* isr_table = isr_table_port ## port_name; \
uint32_t bit_nr; \
while(isfr) { \
bit_nr = __builtin_ctz(isfr); \
isr_table[bit_nr](); \
isfr = isfr & (isfr-1); \
if(!isfr) return; \
// END PORT_ISR_FUNCTION_CLZ
PORT_ISR_FUNCTION_CLZ(A)
PORT_ISR_FUNCTION_CLZ(B)
PORT_ISR_FUNCTION_CLZ(C)
PORT_ISR_FUNCTION_CLZ(D)
PORT_ISR_FUNCTION_CLZ(E)
// Kinetis L (Teensy LC) is based on Cortex M0 and doesn't have hardware
// support for CLZ.
#define DISPATCH_PIN_ISR(pin_nr) { voidFuncPtr pin_isr = intFunc[pin_nr]; \
if(isfr & CORE_PIN ## pin_nr ## _BITMASK) pin_isr(); }
uint32_t isfr = PORTA_ISFR;
PORTA_ISFR = isfr;
DISPATCH_PIN_ISR(3);
DISPATCH_PIN_ISR(4);
uint32_t isfr = PORTC_ISFR;
PORTC_ISFR = isfr;
DISPATCH_PIN_ISR(9);
DISPATCH_PIN_ISR(10);
DISPATCH_PIN_ISR(11);
DISPATCH_PIN_ISR(12);
DISPATCH_PIN_ISR(13);
DISPATCH_PIN_ISR(15);
DISPATCH_PIN_ISR(22);
DISPATCH_PIN_ISR(23);
isfr = PORTD_ISFR;
PORTD_ISFR = isfr;
DISPATCH_PIN_ISR(2);
DISPATCH_PIN_ISR(5);
DISPATCH_PIN_ISR(6);
DISPATCH_PIN_ISR(7);
DISPATCH_PIN_ISR(8);
DISPATCH_PIN_ISR(14);
DISPATCH_PIN_ISR(20);
DISPATCH_PIN_ISR(21);
#undef DISPATCH_PIN_ISR
#if defined(__MK20DX128__) || defined(__MK20DX256__) || defined(__MK64FX512__) || defined(__MK66FX1M0__)
unsigned long rtc_get(void)
return RTC_TSR;
void rtc_set(unsigned long t)
RTC_SR = 0;
RTC_TPR = 0;
RTC_TSR = t;
RTC_SR = RTC_SR_TCE;
// adjust is the amount of crystal error to compensate, 1 = 0.1192 ppm
// For example, adjust = -100 is slows the clock by 11.92 ppm
void rtc_compensate(int adjust)
uint32_t comp, interval, tcr;
// This simple approach tries to maximize the interval.
// Perhaps minimizing TCR would be better, so the
// compensation is distributed more evenly across
// many seconds, rather than saving it all up and then
// altering one second up to +/- 0.38%
if (adjust >= 0) {
comp = adjust;
interval = 256;
while (1) {
tcr = comp * interval;
if (tcr < 128*256) break;
if (--interval == 1) break;
tcr = tcr >> 8;
comp = -adjust;
interval = 256;
while (1) {
if (tcr < 129*256) break;
tcr = tcr >> 8;
tcr = 256 - tcr;
RTC_TCR = ((interval - 1) << 8) | tcr;
#else
unsigned long rtc_get(void) { return 0; }
void rtc_set(unsigned long t) { }
void rtc_compensate(int adjust) { }
#if 0
// TODO: build system should define this
// so RTC is automatically initialized to approx correct time
// at least when the program begins running right after upload
#ifndef TIME_T
#define TIME_T 1350160272
void init_rtc(void)
serial_print("init_rtc\n");
//SIM_SCGC6 |= SIM_SCGC6_RTC;
// enable the RTC crystal oscillator, for approx 12pf crystal
if (!(RTC_CR & RTC_CR_OSCE)) {
serial_print("start RTC oscillator\n");
RTC_SR = 0;
RTC_CR = RTC_CR_SC16P | RTC_CR_SC4P | RTC_CR_OSCE;
// should wait for crystal to stabilize.....
serial_print("SR=");
serial_phex32(RTC_SR);
serial_print("\n");
serial_print("CR=");
serial_phex32(RTC_CR);
serial_print("\n");
serial_print("TSR=");
serial_phex32(RTC_TSR);
serial_print("\n");
serial_print("TCR=");
serial_phex32(RTC_TCR);
serial_print("\n");
if (RTC_SR & RTC_SR_TIF) {
// enable the RTC
RTC_SR = 0;
RTC_TPR = 0;
RTC_TSR = TIME_T;
extern void usb_init(void);
// create a default PWM at the same 488.28 Hz as Arduino Uno
#define F_TIMER F_BUS
#if F_CPU > 16000000
#define F_TIMER (F_PLL/2)
#else
#define F_TIMER (F_PLL)
#endif//Low Power
#if F_TIMER == 120000000
#define DEFAULT_FTM_MOD (61440 - 1)
#define DEFAULT_FTM_PRESCALE 2
#elif F_TIMER == 108000000
#define DEFAULT_FTM_MOD (55296 - 1)
#elif F_TIMER == 96000000
#define DEFAULT_FTM_MOD (49152 - 1)
#elif F_TIMER == 90000000
#define DEFAULT_FTM_MOD (46080 - 1)
#elif F_TIMER == 80000000
#define DEFAULT_FTM_MOD (40960 - 1)
#elif F_TIMER == 72000000
#define DEFAULT_FTM_MOD (36864 - 1)
#elif F_TIMER == 64000000
#define DEFAULT_FTM_MOD (65536 - 1)
#define DEFAULT_FTM_PRESCALE 1
#elif F_TIMER == 60000000
#elif F_TIMER == 56000000
#define DEFAULT_FTM_MOD (57344 - 1)
#elif F_TIMER == 54000000
#elif F_TIMER == 48000000
#elif F_TIMER == 40000000
#elif F_TIMER == 36000000
#elif F_TIMER == 24000000
#define DEFAULT_FTM_PRESCALE 0
#elif F_TIMER == 16000000
#define DEFAULT_FTM_MOD (32768 - 1)
#define DEFAULT_FTM_MOD (16384 - 1)
#define DEFAULT_FTM_MOD (8192 - 1)
#elif F_TIMER == 2000000
#define DEFAULT_FTM_MOD (4096 - 1)
//void init_pins(void)
__attribute__((noinline))
void _init_Teensyduino_internal_(void)
NVIC_ENABLE_IRQ(IRQ_PORTA);
NVIC_ENABLE_IRQ(IRQ_PORTB);
NVIC_ENABLE_IRQ(IRQ_PORTC);
NVIC_ENABLE_IRQ(IRQ_PORTD);
NVIC_ENABLE_IRQ(IRQ_PORTE);
#elif defined(__MKL26Z64__)
NVIC_ENABLE_IRQ(IRQ_PORTCD);
//SIM_SCGC6 |= SIM_SCGC6_FTM0; // TODO: use bitband for atomic read-mod-write
//SIM_SCGC6 |= SIM_SCGC6_FTM1;
FTM0_CNT = 0;
FTM0_MOD = DEFAULT_FTM_MOD;
FTM0_C0SC = 0x28; // MSnB:MSnA = 10, ELSnB:ELSnA = 10
FTM0_C1SC = 0x28;
FTM0_C2SC = 0x28;
FTM0_C3SC = 0x28;
FTM0_C4SC = 0x28;
FTM0_C5SC = 0x28;
FTM0_C6SC = 0x28;
FTM0_C7SC = 0x28;
#if defined(__MK64FX512__) || defined(__MK66FX1M0__)
FTM3_C0SC = 0x28;
FTM3_C1SC = 0x28;
FTM3_C2SC = 0x28;
FTM3_C3SC = 0x28;
FTM3_C4SC = 0x28;
FTM3_C5SC = 0x28;
FTM3_C6SC = 0x28;
FTM3_C7SC = 0x28;
FTM0_SC = FTM_SC_CLKS(1) | FTM_SC_PS(DEFAULT_FTM_PRESCALE);
FTM1_CNT = 0;
FTM1_MOD = DEFAULT_FTM_MOD;
FTM1_C0SC = 0x28;
FTM1_C1SC = 0x28;
FTM1_SC = FTM_SC_CLKS(1) | FTM_SC_PS(DEFAULT_FTM_PRESCALE);
#if defined(__MK20DX256__) || defined(__MK64FX512__) || defined(__MK66FX1M0__) || defined(__MKL26Z64__)
FTM2_CNT = 0;
FTM2_MOD = DEFAULT_FTM_MOD;
FTM2_C0SC = 0x28;
FTM2_C1SC = 0x28;
FTM2_SC = FTM_SC_CLKS(1) | FTM_SC_PS(DEFAULT_FTM_PRESCALE);
FTM3_CNT = 0;
FTM3_MOD = DEFAULT_FTM_MOD;
FTM3_C0SC = 0x28;
FTM3_C1SC = 0x28;
FTM3_SC = FTM_SC_CLKS(1) | FTM_SC_PS(DEFAULT_FTM_PRESCALE);
#if defined(__MK66FX1M0__)
SIM_SCGC2 |= SIM_SCGC2_TPM1;
SIM_SOPT2 |= SIM_SOPT2_TPMSRC(2);
TPM1_CNT = 0;
TPM1_MOD = 32767;
TPM1_C0SC = 0x28;
TPM1_C1SC = 0x28;
TPM1_SC = FTM_SC_CLKS(1) | FTM_SC_PS(0);
analog_init();
// for background about this startup delay, please see these conversations
// https://forum.pjrc.com/threads/36606-startup-time-(400ms)?p=113980&viewfull=1#post113980
// https://forum.pjrc.com/threads/31290-Teensey-3-2-Teensey-Loader-1-24-Issues?p=87273&viewfull=1#post87273
#if TEENSYDUINO >= 142
delay(25);
usb_init();
delay(275);
#else
delay(50);
usb_init();
delay(350);
#define FTM0_CH0_PIN 22
#define FTM0_CH1_PIN 23
#define FTM0_CH2_PIN 9
#define FTM0_CH3_PIN 10
#define FTM0_CH4_PIN 6
#define FTM0_CH5_PIN 20
#define FTM0_CH6_PIN 21
#define FTM0_CH7_PIN 5
#define FTM1_CH0_PIN 3
#define FTM1_CH1_PIN 4
#elif defined(__MK20DX256__)
#define FTM2_CH0_PIN 32
#define FTM2_CH1_PIN 25
#define FTM1_CH0_PIN 16
#define FTM1_CH1_PIN 17
#define FTM2_CH1_PIN 4
#elif defined(__MK64FX512__)
#define FTM2_CH0_PIN 29
#define FTM2_CH1_PIN 30
#define FTM3_CH0_PIN 2
#define FTM3_CH1_PIN 14
#define FTM3_CH2_PIN 7
#define FTM3_CH3_PIN 8
#define FTM3_CH4_PIN 35
#define FTM3_CH5_PIN 36
#define FTM3_CH6_PIN 37
#define FTM3_CH7_PIN 38
#elif defined(__MK66FX1M0__)
#define TPM1_CH0_PIN 16
#define TPM1_CH1_PIN 17
#define FTM_PINCFG(pin) FTM_PINCFG2(pin)
#define FTM_PINCFG2(pin) CORE_PIN ## pin ## _CONFIG
static uint8_t analog_write_res = 8;
// SOPT4 is SIM select clocks?
// FTM is clocked by the bus clock, either 24 or 48 MHz
// input capture can be FTM1_CH0, CMP0 or CMP1 or USB start of frame
// 24 MHz with reload 49152 to match Arduino's speed = 488.28125 Hz
void analogWrite(uint8_t pin, int val)
uint32_t cval, max;
if (pin == A14) {
uint8_t res = analog_write_res;
if (res < 12) {
val <<= 12 - res;
} else if (res > 12) {
val >>= res - 12;
analogWriteDAC0(val);
return;
if (pin == A12) {
if (res < 12) {
val <<= 12 - res;
val >>= res - 12;
return;
#elif defined(__MK64FX512__) || defined(__MK66FX1M0__)
if (pin == A21 || pin == A22) {
if (res < 12) {
val <<= 12 - res;
val >>= res - 12;
if (pin == A21) analogWriteDAC0(val);
else analogWriteDAC1(val);
return;
max = 1 << analog_write_res;
if (val <= 0) {
digitalWrite(pin, LOW);
pinMode(pin, OUTPUT); // TODO: implement OUTPUT_LOW
return;
} else if (val >= max) {
digitalWrite(pin, HIGH);
pinMode(pin, OUTPUT); // TODO: implement OUTPUT_HIGH
return;
//serial_print("analogWrite\n");
//serial_print("val = ");
//serial_phex32(val);
//serial_print("\n");
//serial_print("analog_write_res = ");
//serial_phex(analog_write_res);
if (pin == FTM1_CH0_PIN || pin == FTM1_CH1_PIN) {
cval = ((uint32_t)val * (uint32_t)(FTM1_MOD + 1)) >> analog_write_res;
#if defined(FTM2_CH0_PIN)
} else if (pin == FTM2_CH0_PIN || pin == FTM2_CH1_PIN) {
cval = ((uint32_t)val * (uint32_t)(FTM2_MOD + 1)) >> analog_write_res;
#if defined(FTM3_CH0_PIN)
} else if (pin == FTM3_CH0_PIN || pin == FTM3_CH1_PIN || pin == FTM3_CH2_PIN
|| pin == FTM3_CH3_PIN || pin == FTM3_CH4_PIN || pin == FTM3_CH5_PIN
|| pin == FTM3_CH6_PIN || pin == FTM3_CH7_PIN) {
cval = ((uint32_t)val * (uint32_t)(FTM3_MOD + 1)) >> analog_write_res;
#if defined(TPM1_CH0_PIN)
} else if (pin == TPM1_CH0_PIN || pin == TPM1_CH1_PIN) {
cval = ((uint32_t)val * (uint32_t)(TPM1_MOD + 1)) >> analog_write_res;
cval = ((uint32_t)val * (uint32_t)(FTM0_MOD + 1)) >> analog_write_res;
//serial_print("cval = ");
//serial_phex32(cval);
switch (pin) {
#ifdef FTM0_CH0_PIN
case FTM0_CH0_PIN: // PTC1, FTM0_CH0
FTM0_C0V = cval;
FTM_PINCFG(FTM0_CH0_PIN) = PORT_PCR_MUX(4) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM0_CH1_PIN
case FTM0_CH1_PIN: // PTC2, FTM0_CH1
FTM0_C1V = cval;
FTM_PINCFG(FTM0_CH1_PIN) = PORT_PCR_MUX(4) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM0_CH2_PIN
case FTM0_CH2_PIN: // PTC3, FTM0_CH2
FTM0_C2V = cval;
FTM_PINCFG(FTM0_CH2_PIN) = PORT_PCR_MUX(4) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM0_CH3_PIN
case FTM0_CH3_PIN: // PTC4, FTM0_CH3
FTM0_C3V = cval;
FTM_PINCFG(FTM0_CH3_PIN) = PORT_PCR_MUX(4) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM0_CH4_PIN
case FTM0_CH4_PIN: // PTD4, FTM0_CH4
FTM0_C4V = cval;
FTM_PINCFG(FTM0_CH4_PIN) = PORT_PCR_MUX(4) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM0_CH5_PIN
case FTM0_CH5_PIN: // PTD5, FTM0_CH5
FTM0_C5V = cval;
FTM_PINCFG(FTM0_CH5_PIN) = PORT_PCR_MUX(4) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM0_CH6_PIN
case FTM0_CH6_PIN: // PTD6, FTM0_CH6
FTM0_C6V = cval;
FTM_PINCFG(FTM0_CH6_PIN) = PORT_PCR_MUX(4) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM0_CH7_PIN
case FTM0_CH7_PIN: // PTD7, FTM0_CH7
FTM0_C7V = cval;
FTM_PINCFG(FTM0_CH7_PIN) = PORT_PCR_MUX(4) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM1_CH0_PIN
case FTM1_CH0_PIN: // PTA12, FTM1_CH0
FTM1_C0V = cval;
FTM_PINCFG(FTM1_CH0_PIN) = PORT_PCR_MUX(3) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM1_CH1_PIN
case FTM1_CH1_PIN: // PTA13, FTM1_CH1
FTM1_C1V = cval;
FTM_PINCFG(FTM1_CH1_PIN) = PORT_PCR_MUX(3) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM2_CH0_PIN
case FTM2_CH0_PIN: // PTB18, FTM2_CH0
FTM2_C0V = cval;
FTM_PINCFG(FTM2_CH0_PIN) = PORT_PCR_MUX(3) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM2_CH1_PIN
case FTM2_CH1_PIN: // PTB19, FTM1_CH1
FTM2_C1V = cval;
FTM_PINCFG(FTM2_CH1_PIN) = PORT_PCR_MUX(3) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM3_CH0_PIN
case FTM3_CH0_PIN:
FTM3_C0V = cval;
FTM_PINCFG(FTM3_CH0_PIN) = PORT_PCR_MUX(4) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM3_CH1_PIN
case FTM3_CH1_PIN:
FTM3_C1V = cval;
FTM_PINCFG(FTM3_CH1_PIN) = PORT_PCR_MUX(4) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM3_CH2_PIN
case FTM3_CH2_PIN:
FTM3_C2V = cval;
FTM_PINCFG(FTM3_CH2_PIN) = PORT_PCR_MUX(4) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM3_CH3_PIN
case FTM3_CH3_PIN:
FTM3_C3V = cval;
FTM_PINCFG(FTM3_CH3_PIN) = PORT_PCR_MUX(4) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM3_CH4_PIN
case FTM3_CH4_PIN:
FTM3_C4V = cval;
FTM_PINCFG(FTM3_CH4_PIN) = PORT_PCR_MUX(3) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM3_CH5_PIN
case FTM3_CH5_PIN:
FTM3_C5V = cval;
FTM_PINCFG(FTM3_CH5_PIN) = PORT_PCR_MUX(3) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM3_CH6_PIN
case FTM3_CH6_PIN:
FTM3_C6V = cval;
FTM_PINCFG(FTM3_CH6_PIN) = PORT_PCR_MUX(3) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef FTM3_CH7_PIN
case FTM3_CH7_PIN:
FTM3_C7V = cval;
FTM_PINCFG(FTM3_CH7_PIN) = PORT_PCR_MUX(3) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef TPM1_CH0_PIN
case TPM1_CH0_PIN:
TPM1_C0V = cval;
FTM_PINCFG(TPM1_CH0_PIN) = PORT_PCR_MUX(6) | PORT_PCR_DSE | PORT_PCR_SRE;
#ifdef TPM1_CH1_PIN
case TPM1_CH1_PIN:
TPM1_C1V = cval;
FTM_PINCFG(TPM1_CH1_PIN) = PORT_PCR_MUX(6) | PORT_PCR_DSE | PORT_PCR_SRE;
default:
digitalWrite(pin, (val > 127) ? HIGH : LOW);
uint32_t analogWriteRes(uint32_t bits)
uint32_t prior_res;
if (bits < 1) {
bits = 1;
} else if (bits > 16) {
bits = 16;
prior_res = analog_write_res;
analog_write_res = bits;
return prior_res;
void analogWriteFrequency(uint8_t pin, float frequency)
uint32_t prescale, mod, ftmClock, ftmClockSource;
float minfreq;
//serial_print("analogWriteFrequency: pin = ");
//serial_phex(pin);
//serial_print(", freq = ");
//serial_phex32((uint32_t)frequency);
#ifdef TPM1_CH0_PIN
ftmClockSource = 1;
ftmClock = 16000000;
} else
#if defined(__MKL26Z64__)
// Teensy LC does not support slow clock source (ftmClockSource = 2)
ftmClockSource = 1; // Use default F_TIMER clock source
ftmClock = F_TIMER; // Set variable for the actual timer clock frequency
#else
if (frequency < (float)(F_TIMER >> 7) / 65536.0f) {
// frequency is too low for working with F_TIMER:
ftmClockSource = 2; // Use alternative 31250Hz clock source
ftmClock = 31250; // Set variable for the actual timer clock frequency
for (prescale = 0; prescale < 7; prescale++) {
minfreq = (float)(ftmClock >> prescale) / 65536.0f; //Use ftmClock instead of F_TIMER
if (frequency >= minfreq) break;
//serial_print("F_TIMER/ftm_Clock = ");
//serial_phex32(ftmClock >> prescale);
//serial_print("prescale = ");
//serial_phex(prescale);
mod = (float)(ftmClock >> prescale) / frequency - 0.5f; //Use ftmClock instead of F_TIMER
if (mod > 65535) mod = 65535;
//serial_print("mod = ");
//serial_phex32(mod);
FTM1_SC = 0;
FTM1_CNT = 0;
FTM1_MOD = mod;
FTM1_SC = FTM_SC_CLKS(ftmClockSource) | FTM_SC_PS(prescale); //Use ftmClockSource instead of 1
} else if (pin == FTM0_CH0_PIN || pin == FTM0_CH1_PIN
|| pin == FTM0_CH2_PIN || pin == FTM0_CH3_PIN
|| pin == FTM0_CH4_PIN || pin == FTM0_CH5_PIN
#ifdef FTM0_CH6_PIN
|| pin == FTM0_CH6_PIN || pin == FTM0_CH7_PIN
FTM0_SC = 0;
FTM0_CNT = 0;
FTM0_MOD = mod;
FTM0_SC = FTM_SC_CLKS(ftmClockSource) | FTM_SC_PS(prescale); //Use ftmClockSource instead of 1
#ifdef FTM2_CH0_PIN
FTM2_SC = 0;
FTM2_CNT = 0;
FTM2_MOD = mod;
FTM2_SC = FTM_SC_CLKS(ftmClockSource) | FTM_SC_PS(prescale); //Use ftmClockSource instead of 1
#ifdef FTM3_CH0_PIN
|| pin == FTM3_CH2_PIN || pin == FTM3_CH3_PIN
FTM3_SC = 0;
FTM3_CNT = 0;
FTM3_MOD = mod;
FTM3_SC = FTM_SC_CLKS(ftmClockSource) | FTM_SC_PS(prescale); //Use the new ftmClockSource instead of 1
#ifdef TPM1_CH0_PIN
TPM1_SC = 0;
TPM1_CNT = 0;
TPM1_MOD = mod;
TPM1_SC = FTM_SC_CLKS(ftmClockSource) | FTM_SC_PS(prescale);
// TODO: startup code needs to initialize all pins to GPIO mode, input by default
void digitalWrite(uint8_t pin, uint8_t val)
#ifdef KINETISK
if (*portModeRegister(pin)) {
if (val) {
*portSetRegister(pin) = 1;
*portClearRegister(pin) = 1;
#else
if (*portModeRegister(pin) & digitalPinToBitMask(pin)) {
if (val) {
*portSetRegister(pin) = digitalPinToBitMask(pin);
*portClearRegister(pin) = digitalPinToBitMask(pin);
volatile uint32_t *config = portConfigRegister(pin);
if (val) {
// TODO use bitband for atomic read-mod-write
*config |= (PORT_PCR_PE | PORT_PCR_PS);
//*config = PORT_PCR_MUX(1) | PORT_PCR_PE | PORT_PCR_PS;
*config &= ~(PORT_PCR_PE);
//*config = PORT_PCR_MUX(1);
uint8_t digitalRead(uint8_t pin)
if (pin >= CORE_NUM_DIGITAL) return 0;
#ifdef KINETISK
return *portInputRegister(pin);
#else
return (*portInputRegister(pin) & digitalPinToBitMask(pin)) ? 1 : 0;
void pinMode(uint8_t pin, uint8_t mode)
if (mode == OUTPUT || mode == OUTPUT_OPENDRAIN) {
#ifdef KINETISK
*portModeRegister(pin) = 1;
#else
*portModeRegister(pin) |= digitalPinToBitMask(pin); // TODO: atomic
*config = PORT_PCR_SRE | PORT_PCR_DSE | PORT_PCR_MUX(1);
if (mode == OUTPUT_OPENDRAIN) {
*config |= PORT_PCR_ODE;
*config &= ~PORT_PCR_ODE;
#ifdef KINETISK
*portModeRegister(pin) = 0;
#else
*portModeRegister(pin) &= ~digitalPinToBitMask(pin);
if (mode == INPUT) {
} else if (mode == INPUT_PULLUP) {
} else if (mode == INPUT_PULLDOWN) {
*config = PORT_PCR_MUX(1) | PORT_PCR_PE;
} else { // INPUT_DISABLE
*config = 0;
void _shiftOut(uint8_t dataPin, uint8_t clockPin, uint8_t bitOrder, uint8_t value)
if (bitOrder == LSBFIRST) {
shiftOut_lsbFirst(dataPin, clockPin, value);
shiftOut_msbFirst(dataPin, clockPin, value);
void shiftOut_lsbFirst(uint8_t dataPin, uint8_t clockPin, uint8_t value)
uint8_t mask;
for (mask=0x01; mask; mask <<= 1) {
digitalWrite(dataPin, value & mask);
digitalWrite(clockPin, HIGH);
digitalWrite(clockPin, LOW);
void shiftOut_msbFirst(uint8_t dataPin, uint8_t clockPin, uint8_t value)
uint8_t mask;
for (mask=0x80; mask; mask >>= 1) {
uint8_t _shiftIn(uint8_t dataPin, uint8_t clockPin, uint8_t bitOrder)
return shiftIn_lsbFirst(dataPin, clockPin);
return shiftIn_msbFirst(dataPin, clockPin);
uint8_t shiftIn_lsbFirst(uint8_t dataPin, uint8_t clockPin)
uint8_t mask, value=0;
if (digitalRead(dataPin)) value |= mask;
return value;
uint8_t shiftIn_msbFirst(uint8_t dataPin, uint8_t clockPin)
return value;
// the systick interrupt is supposed to increment this at 1 kHz rate
volatile uint32_t systick_millis_count = 0;
//uint32_t systick_current, systick_count, systick_istatus; // testing only
uint32_t micros(void)
uint32_t count, current, istatus;
__disable_irq();
current = SYST_CVR;
count = systick_millis_count;
istatus = SCB_ICSR; // bit 26 indicates if systick exception pending
__enable_irq();
//systick_current = current;
//systick_count = count;
//systick_istatus = istatus & SCB_ICSR_PENDSTSET ? 1 : 0;
if ((istatus & SCB_ICSR_PENDSTSET) && current > 50) count++;
current = ((F_CPU / 1000) - 1) - current;
#if defined(KINETISL) && F_CPU == 48000000
return count * 1000 + ((current * (uint32_t)87381) >> 22);
#elif defined(KINETISL) && F_CPU == 24000000
return count * 1000 + ((current * (uint32_t)174763) >> 22);
return count * 1000 + current / (F_CPU / 1000000);
void delay(uint32_t ms)
uint32_t start = micros();
if (ms > 0) {
while (1) {
while ((micros() - start) >= 1000) {
ms--;
if (ms == 0) return;
start += 1000;
yield();
// TODO: verify these result in correct timeouts...
#if F_CPU == 240000000
#define PULSEIN_LOOPS_PER_USEC 33
#elif F_CPU == 216000000
#define PULSEIN_LOOPS_PER_USEC 31
#elif F_CPU == 192000000
#define PULSEIN_LOOPS_PER_USEC 29
#elif F_CPU == 180000000
#define PULSEIN_LOOPS_PER_USEC 27
#elif F_CPU == 168000000
#define PULSEIN_LOOPS_PER_USEC 25
#elif F_CPU == 144000000
#define PULSEIN_LOOPS_PER_USEC 21
#elif F_CPU == 120000000
#define PULSEIN_LOOPS_PER_USEC 18
#elif F_CPU == 96000000
#define PULSEIN_LOOPS_PER_USEC 14
#elif F_CPU == 72000000
#define PULSEIN_LOOPS_PER_USEC 10
#elif F_CPU == 48000000
#define PULSEIN_LOOPS_PER_USEC 7
#elif F_CPU == 24000000
#define PULSEIN_LOOPS_PER_USEC 4
#elif F_CPU == 16000000
#elif F_CPU == 8000000
#elif F_CPU == 4000000
#elif F_CPU == 2000000
uint32_t pulseIn_high(volatile uint8_t *reg, uint32_t timeout)
uint32_t timeout_count = timeout * PULSEIN_LOOPS_PER_USEC;
uint32_t usec_start, usec_stop;
// wait for any previous pulse to end
while (*reg) {
if (--timeout_count == 0) return 0;
// wait for the pulse to start
while (!*reg) {
usec_start = micros();
// wait for the pulse to stop
while (*reg) {
usec_stop = micros();
return usec_stop - usec_start;
uint32_t pulseIn_low(volatile uint8_t *reg, uint32_t timeout)
while (!*reg) {
while (*reg) {
while (!*reg) {
// TODO: an inline version should handle the common case where state is const
uint32_t pulseIn(uint8_t pin, uint8_t state, uint32_t timeout)
if (state) return pulseIn_high(portInputRegister(pin), timeout);
return pulseIn_low(portInputRegister(pin), timeout);;
// For TeencyLC need to use mask on the input register as the register is shared by several IO pins
uint32_t pulseIn_high(volatile uint8_t *reg, uint8_t mask, uint32_t timeout)
while (*reg & mask) {
if (--timeout_count == 0) return -1;
while (!(*reg & mask)) {
uint32_t pulseIn_low(volatile uint8_t *reg, uint8_t mask, uint32_t timeout)
if (state) return pulseIn_high(portInputRegister(pin), digitalPinToBitMask(pin), timeout);
return pulseIn_low(portInputRegister(pin), digitalPinToBitMask(pin), timeout);;
