Results 1 to 3 of 3
Thread: Teensy + BMW E65 iDrive Controller
    Oct 2018
    2
    Hi Guys,
    I'm working on idrive controller mod from my BMW E65 using Teensy 3.2.
    I already did electrical and mechanical test so I'm sure that everything is up and running.
    Button 0 (PIN0) -> Function key
    Button 1 (PIN1) -> Menu key
    Button 6 (PIN6) -> Knob key
    and now arrows:
    UP (Button 4 & 5)
    DOWN (Button 2 & 3)
    LEFT (Button 3 & 4)
    RIGHT (Button 2 & 5)
    Pins 7 & 8 are for rotary encoder (not configure but works)
    Main case is when I push up knob button 4 & 5 should be as "KEY_UP", but I'm not sure how to conifgure two "buttons" to one function.
    Here is a code:
    #include <Bounce.h>
    // Create Bounce objects for each button. The Bounce object
    // automatically deals with contact chatter or "bounce", and
    // it makes detecting changes very simple.
    Bounce button0 = Bounce(0, 10);
    Bounce button1 = Bounce(1, 10); // 10 ms debounce time is appropriate
    Bounce button2 = Bounce(2, 10); // for most mechanical pushbuttons
    Bounce button3 = Bounce(3, 10);
    Bounce button4 = Bounce(4, 10); // if a button is too "sensitive"
    Bounce button5 = Bounce(5, 10); // you can increase this time.
    Bounce button6 = Bounce(6, 10);
    // Configure the pins for input mode with pullup resistors.
    // The pushbuttons connect from each pin to ground. When
    // the button is pressed, the pin reads LOW because the button
    // shorts it to ground. When released, the pin reads HIGH
    // because the pullup resistor connects to +5 volts inside
    // the chip.
    pinMode(0, INPUT_PULLUP);
    pinMode(1, INPUT_PULLUP);
    pinMode(2, INPUT_PULLUP);
    pinMode(3, INPUT_PULLUP);
    pinMode(4, INPUT_PULLUP);
    pinMode(5, INPUT_PULLUP);
    pinMode(6, INPUT_PULLUP);
    // Update all the buttons. There should not be any long
    // delays in loop(), so this runs repetitively at a rate
    // faster than the buttons could be pressed and released.
    button0.update();
    button1.update();
    button2.update();
    button3.update();
    button4.update();
    button5.update();
    button6.update();
    // Check each button for "falling" edge.
    // falling = high (not pressed - voltage from pullup resistor)
    // to low (pressed - button connects pin to ground)
    if (button0.fallingEdge()) {
    Keyboard.press(KEY_ENTER);
    Keyboard.release(KEY_ENTER);
    if (button1.fallingEdge()) {
    Keyboard.press(KEY_ESC);
    Keyboard.release(KEY_ESC);
    if (button4.fallingEdge() && button5.fallingEdge()) {
    Keyboard.press(KEY_UP);
    Keyboard.release(KEY_UP);
    if (button2.fallingEdge() && button3.fallingEdge()) {
    Keyboard.press(KEY_DOWN);
    Keyboard.release(KEY_DOWN);
    if (button3.fallingEdge() && button4.fallingEdge()) {
    Keyboard.press(KEY_LEFT);
    Keyboard.release(KEY_LEFT);
    if (button2.fallingEdge() && button5.fallingEdge()) {
    Keyboard.press(KEY_RIGHT);
    Keyboard.release(KEY_RIGHT);
    if (button6.fallingEdge()) {
    Keyboard.press(KEY_SPACE);
    Keyboard.release(KEY_SPACE);
    Can you help me a little bit how can I setup it please?
    Dec 2016
    Montreal, Canada
    3,070
    Shouldn't you KEY_UP instead of KEY_SPACE for 4 and 5?
    and now arrows:
    UP (Button 4 & 5)
    DOWN (Button 2 & 3)
    LEFT (Button 3 & 4)
    Oct 2018
    2
    Yeah, My bad i took "test" version of the code.
    I did some changes to be sure about issues.
    Btw now my topic is updated to correct code
    Thanks anyway
