Results 1 to 3 of 3
Thread: Flash writes take time to stabilize
    Sep 2018
    15
    Not a teensy bug per-se, but a good thing to be aware of with respect to the MK20DX256 controller.
    Flash writes using the program_longword command to the first 16 or so bytes to a sector take a few seconds to stabilize. The data is 0xFF until an indeterminate time.
    The CCIF command complete register cannot be trusted for these bytes.
    I have no idea why this is, but it seems to be a bug in the FFTL controller.
    My test was done at 0x2000 after a sector_erase command.
    19,225
    You need to invalidate the cache, otherwise you're still reading the old data from the flash controller's cache.
    19,225
    When using Teensy 3.6, there's also a larger 8K cache to keep in mind, and of course the same small cache memory inside the flash controller.
