Results 1 to 6 of 6
Thread: LIN bus
    Sep 2015
    4
    LIN bus
    I would like to use Teensy 3.5 as a LIN bus Master.
    Could anybody know if there is any library for LIN bus?
    Thanks.
    Jan 2017
    14
    maybe this can help
    https://github.com/macchina/LIN
    The code seems to be for some kind of Arduino Due clone, but it's using only Serial and digitalWrite. So modification for a Teensy should be possible.
    Don't forget to use a LIN transceiver chip for interfacing.
    Mar 2019
    2
    Did it worked?Actually i was also facing similar issue and i tried above link..But in vain.Any alternative solution to it?
    Mar 2019
    2
    Hey skpang,thank you for providing me with alternative solutions..Will try it and report back if i dont get any solution..I hope it works bcoz i tried everything and now i m frustrated a bit.Thanks mybkexperience
