Results 1 to 3 of 3
Thread: wiznet w5500 Receive all Multicast traffic?
    Senior Member crees's Avatar
    Dec 2016
    Utah
    126
    Using my Teensy 3.2 platform I am Digging via code here and wiznet forums I am looking for a way to listen to all multicast traffic, even traffic destined to other groups (Multicast IP's) .
    Background. I am testing multicasting for e.131 sACN on T3.2 and currently I am only able to receive one universe due to sACN IP multicast address format. Basically each Universe derives its own multicast group IP. What I would like to do is see all multicast traffic even ones destined to other multicast IP's so I can process what I need and ignore the rest.
    Now I do know some routers or switches with IGMP snooping would foil this scenario. however If there is a method to register multiple multicast IP's (multiple sockets?) on the wiznet that would be another direction to consider.
    Also I see things about MACRAW that might be direction I need to look at?
    Unicast no doubt is one way to take care of this and that I have done. However there are some control systems that will only support sACN in multicast mode only. :-(
    Thanks in advance!
    Chris
    19,221
    MACRAW is probably the ultimate solution, though you'll have to parse the IP & UDP headers.
    Some consoles send an Universe Discovery Packet, have a look to the sACN specs at http://tsp.esta.org/tsp/documents/published_docs.php
