Adafruit SSD1305/SSD1325 OLEDs with T3.x
trevinator
New member
Apologies if this is in the wrong section, but has anyone had luck with either the 2.3", 2.42", or 2.7" monochrome OLED displays from Adafruit and a T3.x? The 2.3" and 2.42" use the SSD1305 driver chip and the 2.7" uses the SSD1325 driver chip so I was just wondering if anyone has gotten these displays to work using the provided adafruit libraries. I'll be using a T3.5 and I wanted to check if they were compatible before potentially dropping up to $50.
2.7" https://www.adafruit.com/product/2674
2.3" https://www.adafruit.com/product/2675
2.42" https://www.adafruit.com/product/2719
Thanks!
Bit the bullet and bought the 2.42" monochrome OLED. It uses the SSD1305 chip and everything works great! Highly recommend
Hi trevinator
I'm currently attempting to port from a project i've dev'don a UNO using the U8x8lib.h and I'm struggling to get the 1305 to operate for me - any help you could offer with pinning and library advice would be really appreciated.
This is the header of the UNO code:
/*  OLED Pin      Arduino Pin
 *    GND            GND
 *    VDD             5v
 *    SCK (D0)      13
 *    SDA (D1)        11
 *    RES              8
 *     DC              9
 *     CS             10
 * Typical pin layout used:
 *                   MFRC522       Arduino       Arduino   Arduino    Arduino                Arduino      Teensy
 *                   Reader/PCD   Uno/101       Mega      Nano v3    Leonardo/Micro   Pro Micro      3.6
 * Signal         Pin                Pin              Pin          Pin          Pin                       Pin               pin
 * RST/Reset   RST               9                 5 (2)      D9          RESET/ICSP-5       RST
 * SPI SS        SDA(SS)       10                53          D10        10                        10
 * SPI MOSI    MOSI            11 / ICSP-4   51         D11        ICSP-4                  16
 * SPI MISO    MISO            12 / ICSP-1   50         D12        ICSP-1                  14
 * SPI SCK     SCK               13 / ICSP-3   52         D13        ICSP-3                  15
#include <EEPROM.h>
//#include <Arduino.h>
//#include <U8g2lib.h>
#include <U8x8lib.h>
#include <MFRC522.h>
//#ifdef U8X8_HAVE_HW_SPI
//#endif
//#ifdef U8X8_HAVE_HW_I2C
//#include <Wire.h>
//#endif
//#include "PN532.h"
//#include <PN532_I2C.h>
//PN532_I2C pn532i2c(Wire);
//PN532 nfc(pn532i2c);
//U8X8_SSD1306_128X64_NONAME_4W_HW_SPI u8x8(/* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);     // 2.5" Polish
//U8X8_SH1106_128X64_NONAME_4W_HW_SPI u8x8(/* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);      // 1.3" little
U8X8_SSD1325_NHD_128X64_4W_HW_SPI u8x8(/* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);          // 2.5" ADA
//U8X8_SSD1325_NHD_128X64_4W_SW_SPI u8x8(/* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
constexpr uint8_t RST_PIN = 2;     // Configurable, see typical pin layout above (9),    Uno/Mega(2)
constexpr uint8_t SS_PIN  = 3;     // Configurable, see typical pin layout above (10),   Uno(3),         Mega53
MFRC522 mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance.
MFRC522::MIFARE_Key key;
My bad - Typo
Hi trevinator
I'm currently attempting to port from a project i've dev'don a UNO using the U8x8lib.h and I'm struggling to get the 1325[ to operate for me - any help you could offer with pinning and library advice would be really appreciated.
