Page 4 of 4 FirstFirst ... 2 3 4
Results 76 to 82 of 82
Thread: USB Audio Clicking Noise
  1. #76
    318
    This works perfectly now that the #ifdefs are added...........
  2. #77
    Germany NRW
    5,679
    Great!
    Does it work with Linux, too?
  3. #78
    318
    Yes, works on Linux Lubuntu 18.04 and windows 10 on Pentium. Both behave similar.
    Tested with setI2S_freq at ..... 44000, 44100, 44112 and all worked no clicks. Tested at 44116 for both and heard clicks.
    Didn't try winXP but should be OK, should be same.
  4. #79
    318
    Tried on Windows XP and clicking is still there. Plays about 6 seconds clear and then clicking starts.
    I am replacing my windows XP so for me not worth pursuing this XP problem any further. Windows 10 and Linux work well now.
    If I compile and program teensy on Windows XP I get clicks when recorded and played back on both windows XP and windows 10 machines.
    If I compile and program teensy on windows 10 I get clear recording no clicks when recorded and played back on both windows 10 and windows XP machines.
    Last edited by Teenfor3; 11-26-2018 at 12:30 AM. Reason: added 2 lines about compiling on either machine
  5. #80
    Germany NRW
    5,679
    Thank you for testing! I don't care about XP.
  6. #81
    20,557
    I have no plans to ever test this on Windows XP or Vista. When I do work on it, which very likely may be late in 2019, the oldest version I'm going to test will be Windows 7.
  7. #82
    Feb 2014
    Colmar, France
    2,530
    Sorry, have been absent for a few days, had to teach music in Germany. Will give FrankB's workaround a try on macOS very soon.
