Results 1 to 3 of 3
Thread: Simple SdFat write benchmark for T3.5/3.6
    Oct 2015
    Roma (IT, EU)
    379
    Curious about your T3.5/3.6 microSD write speed and write latency?
    Here's a simple benchmark, derived from https://github.com/greiman/SdFat/blo...sySdioDemo.ino
    Shows sequential write speed, average write latency (for given transfer size) and worst case write latency:
    // SdFatSdioEx simple performance test for Teensy 3.5/3.6 onboard uSD
    #include "SdFat.h"
    #define SERIAL_SPEED 115200
    #define BLOCK_DIM 512
    // Check SD free space!
    #define PREALLOCATED_BLOCKS 512000UL  // 256 MB; compromise between statistics and total benchmark time
    #define BUF_DIM 256*BLOCK_DIM // 128KiB: will comfortably fit T3.5/3.6
    #define FILE_SIZE PREALLOCATED_BLOCKS*BLOCK_DIM
    SdFatSdioEX sdEx;
    File file;
    uint8_t buf[BUF_DIM];
    // buffer as uint32_t
    uint32_t* buf32 = (uint32_t*)buf;
    void errorHalt(const char* msg)
        sdEx.errorHalt(msg);
    uint32_t kHzSdClk()
      return sdEx.card()->kHzSdClk();
    // RUNTEST
    void runTest()
      // Fill buffer with 0
      memset(buf32, 0, sizeof(buf32));
      // Zero Stats
      uint32_t singleWriteMicros = 0;
      uint32_t maxSingleWriteMicros = 0;
      if (!file.open("TeensyDemo.bin", O_RDWR | O_CREAT))
        errorHalt("open failed");
      Serial.println("\nPreallocating file (takes awhile)...\n");
      // Preallocate (off cycle)
      for (uint32_t i = 0; i < PREALLOCATED_BLOCKS; i++)
        uint32_t nblocks = file.write(buf, BLOCK_DIM);
        if (nblocks != BLOCK_DIM)
          errorHalt("Preallocation failed");
      file.rewind();
      Serial.println("Starting write benchmark");
      delay(2000);
      Serial.println("\nTransfer size\tWrite speed\tAvg write time\tMax write time");
      Serial.println("bytes\t\tKB/s\t\tus\t\tus\n");
      for (size_t nb = BLOCK_DIM; nb <= BUF_DIM; nb *= 2)
        uint32_t nRdWr = FILE_SIZE/nb;
        Serial.print(nb);
        Serial.print("\t\t");
        uint32_t t = micros();
        for (uint32_t n = 0; n < nRdWr; n++)
          singleWriteMicros = micros();
          if (nb != file.write(buf, nb))
            errorHalt("write failed");
          singleWriteMicros = micros() - singleWriteMicros;
          if (singleWriteMicros > maxSingleWriteMicros)
            maxSingleWriteMicros = singleWriteMicros;
        t = micros() - t;
        // Write speed
        Serial.print(1000.0f*FILE_SIZE/t, 1);
        // Avg write time (us)
        Serial.print(t / nRdWr);
        // Max write time (us)
        Serial.println(maxSingleWriteMicros);
        file.rewind();  // Ready for next write size
        t = micros();
      file.close();
      Serial.print("\n SD clock speed (kHzSdClk): ");
      Serial.print(kHzSdClk());
      Serial.println(" KHz\n");
      Serial.println("Done");
    // SETUP
      Serial.begin(SERIAL_SPEED);
      while (!Serial);
      Serial.println("SdFatSdioEX write benchmark\nSdFatSdioEx uses extended multi-block transfers without DMA");
      if (!sdEx.begin())
        sdEx.initErrorHalt("SdFatSdioEX begin() failed");
      // make sdEx the current volume.
      sdEx.chvol();
      runTest();
    // LOOP
    Results for my Teensy 3.6 overclocked to 240 MHz: card is an old Lexar 4GB class10 (not UHS):
    Transfer size	Write speed	Avg write time	Max write time
    bytes		KB/s		us		us
    512		13227.7		38		94524
    1024		13316.5		76		94673
    2048		13483.4		151		9957
    4096		12967.5		315		97443
    8192		13206.4		620		95952
    16384		13214.3		1239		98412
    32768		13189.5		2484		98668
    65536		13071.9		5013		193157
    131072		13187.0		9939		106151
     SD clock speed (kHzSdClk): 48000 KHz
    Done
    Many thanks to Bill Greiman for his excellent SdFat library!
    May 2019
    133
    Just started test my SD card... for reference I will post my results here:
    Scandisk Ultra micro SDHC(tm) UHS-1 Card with Adaptor
    "A1 for fatser mobile app performance"
    32GB
    "speed up to 98 MB/s** "
    Bought for 8,39 euro at
    https://www.dataio.nl/sandisk-32gb-m...-i-a1-adapter/
    bytes		KB/s		us		us
    512		16304.1		31		32621
    1024		16474.7		62		33666
    2048		16660.3		122		31939
    4096		16734.3		244		33944
    8192		16721.3		489		43084
    16384		16759.0		977		35176
    32768		16751.5		1956		32693
    65536		16866.5		3885		58195
    131072		16851.0		7778		38035
    Done
    Dec 2019
    9
    Quote Originally Posted by tschrama View Post
    32GB
    bytes		KB/s		us		us
    Done
    Which Teensy were you using?
