Help with delayMicroseconds() and UART init, inside an IRQ_UART0_STATUS function
DMX kinda sorta already has started to move to Ethernet, as E1.31 or Artnet protocol.
The 100 meter length and galvanic isolation of Ethernet transforms makes a lot of sense for lighting, especially compared to the relatively short distance of USB.
@Paul: Thank you for taking the time to update an old man! I know that you are busy with the T4 and I'll try to not to steal you more time with my ignorance.
I was wondering why 8 was better than a mere 5 or 6 UARTS on T_4. Other means can selectively go farther and/or faster and/or with CRC
There was ... some year ago ? ... some wondering about UART lag - though seems that was when active and new data to empty FIFO data went out on the next interrupt IIRC. Also seems some there was noted at that time a change elsewhere (outside PJRC) in AVR or other - a UART code change - but that doesn't remind me enough to find those (probably not relevant) posts.
@Paul: Thank you for taking the time to update an old man! ...
Easy there with throwing insults Thierry :) - AFAIK we are about the same age - assuming you were about 20 while in service ...
I think I found the issue. I'm taking this quote from Teensy 3.6's processor manual:
Setting C2[TE] automatically loads the transmit shift register with the following
preamble:
Basically, I was toggling the transmit-enable state. This explains this whole scenario. When enabling the transmitter on a UART, one character of preamble is shifted out.
I was keeping the transmitter off thinking that would be good practice if I'm not transmitting very often. I've decided to just keep it on.
[Update] I think that whenever the chip shifts something of its own into the shift register, be it a preamble or extra bit after transmitting a break via SBK, the timing is unknown and happens "concurrently" with other instructions.
[Update 2] Now, when I need to time something or delay after a transmitter-enable or using SBK (or anything else that affects the TX shift register), I simply add one character time to my timing parameter. The results are closer to what they should be, often a few bits longer than necessary, but that's what it is, I guess.
